Hi thanks for the question yes this problem is very popular in gas ovens even though theigniter lights up its not hot enough to ignite the gas and also with this problem it wont reach the set tempeture thanks the appliance doc
HI, Try using a needle to clean out the pilot orfice. Most models have an adjustment for the pilot light. It would be located near the manifold under the top panel. I hope this helps you. Please let me knwo if I can assist you further.
I had the same problem when I bought a house with a gas range. If you wait ten seconds or more there is a unit that heats up and ignites the range instead of a pilot. You will hear a click every few seconds then while it ignites the stove. I was afraid to wait because I smelled the gas. But after paying someone $100 for a service call that is what happened.
It is electrical and in the back of my stove there is a cord that goes in the wall. make sure it is plugged in. It also affects the burners however they have a light option on the dial, the oven does not.
hopefully the gas smell isn't too strong and posing a hazard to you. If it is, reach behind the range and turn the valve until it is across the gas line and not parallel to it. You should be able to raise the top of the range from the front and see all the workings underneath. There you will find the pilot light.
Look inside the oven where the burners come into the oven. Right at that point you should find the pilot light. Here is where you light the pilot.If you smell a lot of gas when you open the door, turn off the gas altogether and let it dissipate. Then turn ot on and then you can light it.
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
yes the igniter can come on telling you its ok but these igniters break down they light up but not hot enough to ignite the gas replace the igniter thankstheappliance doc
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
