Can't program my aiwa NSX-AJ100 on to my Universal Jumbo Remote Control from Journys EDGE.
I tried all the codes and tryed code search and its not working! help!
SOURCE: Ilo remote control code
Yes the Emerson code 198 worked for my jumbo universal remote made my Innovage. I also have the ILO 32' TV and could not find the code but this one worked!!! Hope it helps
Posted on Dec 22, 2007
  • 4 Answers
SOURCE: Remote Control Codes for Phillips TV using Jumbo Remote Control
TRY THESE CODES FOR PHILLIPS:
062 204 184 208 205 206 207 004 288 003 008
068 075 086 087 141 189
Posted on Jan 06, 2008
SOURCE: remote control not working and need programming code for cable television/universal remote control
remotes.com says oerseas item-not available?
Posted on Feb 24, 2008
  • 123 Answers
SOURCE: Aiwa tv/vcr/dvd combo mfg. 2003
http://www.urc.philips.com/
Have you tried going here and looking for your codes? Good Luck.
Posted on Apr 10, 2008
SOURCE: Emerson Jumbo Universal Remote and Directv
i got my Magnavox combo VCR/DVD to work by doing the clicking power on and off for both of them
Posted on Jul 05, 2008
Code to program magnovox converet with a jumbo universal remote
There isn't a code listed for a Magnavox STB. Try using CODE SEARCH to find something that works. If a search through all codes stored in your jumbo remote fails, you may have to try a different universal remote, such as Philips, RCA, or GE. All universal remotes do not store all possible codes.
Aug 26, 2016 | Televison & Video
How do i program the innovage jumbo universal remote
Jumbo universal remotes are essentially the same regardless of the name at the top. If you have a device you want to control, start by turning on that device. Press and hold CODE SEARCH until the red indicator stays on, then release the CODE SEARCH button. Press and quickly release the device button, e.g, TV. Point the remote directly at the device. Press the power button (in the upper right corner) repeatedly until the device responds, e.g., changes channel. Press ENTER and release to install the code. If no result, your Innovage jumbo remote may not have a suitable code available.
Oct 23, 2014 | Innovage Jumbo Universal Remote Control
REMOTE CONTROL FOR aiwa model no. NSX-K950
If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. If you wish to get more details about this, try the sites linked here. It has set-up code list, and set-up procedure to many popular brand universal remote controls. http://electrohelponline.blogspot.com/
Dec 30, 2013 | Televison & Video
Need to find code for Jumbo Universal Remote to use with Aiwa S2011 MTS television. Thanks for any help!
Hello
Aiwa TV is not lited on Jumbo Universal Remote codes. Anyway try out with these codes. Sometimes may help you.
Three digit codes for Aiwa TV with universal remote are:
195/ 196
Four digit codes for Aiwa TV with universal remote are:
0195 0196 0227 0269
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch OFF and switch ON your TV with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
OK
Jan 27, 2011 | Aiwa TV-S2011 20"
How do I program my innovage jumbo universal remote control to my dish network service?
Hi my name is Mike Houston of DISH Network and I see you're trying toprogram the Innovage Jumbo remote to the DISH receiver. The best way would beto use the DISH Network remote and have all units programmed to our remote,however if you want the universal remote programmed to the DISH receiver thefirst thing you want to do is press the Code Search button for 5 seconds, whenthe Red Light is on release the Code Search button and keep pressing the ShutDown button until the unit turns off. When it turns off press Enter to lock itin.
Jan 11, 2011 | Innovage Jumbo Remote Control
Can't get my jumbo universal remote to work with my sam sung tv model #LN22B350F2D
You can use CODE SEARCH SETTING for the Jumbo Universal Remote. Have you tried it?
This is an alternative method to programming your device without using the code list. The remote control will scroll through the list of codes to identify the correct code for your device.
  1. Turn onthe device that you want to set.
  2. Aim the remote control at the device and press and hold down the CODE SEARCH button for at least 3 seconds until the red LED lights up solid red.
  3. Press the device button for the item you wish to program, e.g. TV,DVD,VCR, etc. and the LED light will blink once and then remain solid red.
  4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to program shuts off. (Note: LED will blink once each time you press ON/OFF button).
  5. Once this occurs, press ENTER button to store the code and the LED light will turn off.
Thanx
Jul 20, 2010 | Innovage Jumbo Remote Control
I cant control my AIWA TV WITH A jumbo universal control.THE CONTROL NUMBER DOES NOT WORK that is given with the instructions
Have you tried the auto-code search?
Unfortunately, you can't teach this remote new codes, so if none of the AIWA codes from the manual work, and you run through this auto-program sequence and it doesn't work, there is no other solution for your TV.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Nov 19, 2009 | Innovage Jumbo Remote Control
Need programming code for Aiwa NSX-MT920
Your Comcast universal remote control may not contain the code for your Aiwa system. All universal remote controls do not contain all possible codes.
Nov 24, 2017 | Aiwa NSX-MT920 System
CODE FOR TDE SYSTEMS UNIVERSAL REMOTE CONTROL
CANNOT PROGRAM THE TDE SYSTEN=MS JUMBO REMOTE WITH CODES FOR A CITIZEN TV
Mar 01, 2009 | Universal Televison & Video
Codes to program Innovage Products Jumbo Universtal Remote
H have the jumbo universal remote from innovage pruducts. can you e-mail me all the codes? thanj you. jtorres663@aol.com
Dec 15, 2007 | RCA RCU600M Remote Control
Televison & Video Logo
Top Televison & Video Experts
