Question about AEG Favorit 50500 Built-in Dishwasher
Drain pump keeps running AEG oko favorit
The drain pump on the AEG oko favorit 6050 keeps running even when the on/off switch is off or the door is open.
  • 1 more comment
  • Anonymous Dec 19, 2008
    I have the same problem. An engineer visited and told my wife that it was caused by a leak. The machine needs to be pulled out, but the engineer didn't have the gumption to remove the panel at the bottom to allow the machine to be pulled out. Hence why I am looking at this site ...
  • Anonymous Mar 22, 2014
    Hi I have a oko favorite 875 dishwasher but if I put it on the dishwasher does not want to go through the whole sicle what can be wrong
  • Anonymous Mar 25, 2014
    drain pump keeps running AEG oko favorit The drain pump on the AEG oko favorit 6050 keeps running even when the on/off switch is off or the door is open.
  • 192 Answers
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
    New Friend:
Hi
I am looking for the following AEG dish washer Favorit 65080Vi part: The control panel motherboard( motherboard for the button section) is dead. Where can I get it
Posted on Jun 11, 2013
    New Friend:
Same problem with my aeg favorite 445 i checked and fixed the pipe again and again but is still leaking, any idea;
Posted on Apr 01, 2013
  • zaros Apr 01, 2013
    seal has been changed.
2 Suggested Answers
TheMazz
  • 78 Answers
SOURCE: The drain pump on the AEG oko favorit 6050 keeps
This can only be the controller.
Only the controller (timer) turns the pump on and off.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Posted on Oct 17, 2009
Testimonial: "very quick, thankyou"
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher?
It should first be checked for correct water inlet hose with safety valve. After connecting the double-walled water inlet hose, the safety valve is next to the tap. Therefore the water inlet hose is only under pressure while the water is running. If the water inlet hose starts to leak during this operation, the safety valve cuts off the running water and the draining pump in the dishwasher is switched on. If the inlet hose with safety valve working correctly than could be some of following faulties.
  • The door of the dishwasher is not closed properly.
  • Mains plug is not plugged in.
  • House fuse in defective.
  • In the case of dishwasher models with start delay
    timer: A start delay is selected.
If you look at the lower electrical diagram then you can see that all electrical components are located in a circuit inlet valve which can be also faulty.
  • ON/OFF Switch
  • Door switch
  • Program controller (Timer)
  • Pressure switch
  • Inlet valve
  • Float switch
  • Wiring between all this components
Dado
Sep 15, 2015 | AEG Dishwashers
I have a AEG OKO Favorite 675 dish washer and if you start it or open the door it sounds as if it is just draining all the time, what can be wrong?
Hello Barbara, I have one of these dishwashers and this is what happens. There is a drip tray in the bottom of the machine that catches any leaked water. There is a float switch in the drip tray that detects water in the tray. If there is water in the tray, the float switch turns on the drain pump. This will immediately pump all of the water out of the machine and keep the pump running until you remove the water from the drip tray. The pump only pumps out the machine but does not pump from the drip tray. Also the pump will keep running even if the door is open or if the machine cycle is stopped. The only way to stop the pump is to turn off the electricity supply. But also turn off the water supply at the same time, because if the valve that feeds water into the machine is faulty, it will fill the machine till it overflows and if the power is off the float valve cannot turn on the drain pump. On this machine, the solenoid valve that let\'s water into the washer is at the end of the inlet pipe when is connects to the water supply. It is powered by line voltage (230 volts in our case). If this is faulty, it can be replaced with a commercial solenoid valve. The is a two core cable running inside the outer plastic pipe on the inlet pipe. This carries the power to the solenoid valve.
To empty the water from the drip tray, remove the panel from the front of the washer. It is below the front door and has two screws on each end. When you remove this you will see a hole on the left that is big enough to put your finger through and feel if there is water in the tray. If there is, push through a small plastic pipe and suck out the water. It does not take much water to switch on the float valve, maybe the door was not closed properly and some water leaked into the bottom of the unit.
I gained the above knowledge by bitter experience.
Dec 27, 2012 | Washing Machines
Aeg oko favorit 40300 service manual
Please help
Jan 11, 2012 | AEG Dishwashers
What is the most usual reason for leakge on the AEG 6050?
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified..
Jan 16, 2010 | AEG 24 in. Favorit 60830 Free-standing...
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
Empty all the water from the salt resevoir, (I used a turkey baster), then rock the machine backwards and forwards a few times and empty the last few drops from the resevoir again.
Oct 17, 2009 | AEG Favorit 50500 Built-in Dishwasher
Aeg dischwaher model oko favorite
Nov 15, 2008 | AEG 18 in. Favorit 64800 Free-standing...
AEG Favorit 50500 Built-in Dishwasher Logo
5,249 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
