Question about Quinny Dreami - Black Bassinet
Button for hood
Please,
How can I make the hood goes down? I don´t know hoe to press the buttonfor hood.
Thanks.
  • Anonymous Oct 24, 2008
    Us too!
  • Anonymous Nov 24, 2008
    and me
There are two little lighter coloured buttons on the outside of the carrycot, where the hood hinges. These are near the buttons that allow the carrycot to clip and unclip from the buggy frame. They are flat on top and sort of rounded at the bottom.
Press them down (on mine they seem a bit loose, and wobble slightly as you press them). You have to press them quite hard, but should then be able to push the hood down.
I find I have to nudge the hood with my head to get it started, it can be a bit fiddly.
Hope this helps.
Posted on Mar 10, 2009
Hoe to auto search without remote control aiwa color television at215
Depending on the model sequences can be slightly different, firstly you must be able to access the "Menu" button on the TV, as well as the arrow and "Enter" buttons. These buttons are typically located on the left side panel of the TV.and may be the buttons for Prog + or - or Volume up or down . Generally speaking the same sequence of buttons you press to scan for channels are identical to those you press when using a remote. Play around with combinations and see what they do but dont dont hit the enter button until your happy that you know what it is doing, write down the sequences and button combinations so yo remember them for next time. Step 1: Press the "Menu" button, press the "Up" and "Down" arrow buttons to highlight "TV" menu and press the "Menu" button again to enter the TV menu.
Step 2: Press the "Up" and "Down" arrow buttons to select "Tuner Mode" and press the "Left" and "Right" arrow buttons to select the frequency band depending whats connected to your TV. (digital box or aerial)
Step 4:Press the "Up" and "Down" arrow buttons to select "Auto Search" and press the "Menu" button to scan for all channels that are available in your area.
May 10, 2014 | Televison & Video
I just change the lamp but still the lamp hours shows the old timing
HelloYou have to reset the lamp time after lamp replacement. To reset lamp time follow these steps.[1] Press the power button, so that a picture is projected onto the screen.[2] Press the 'menu' button to display the 'main menu' screen, and press 'up' or 'down' buttons to move the cursor to select 'options-2'.[3] Press the 'enter' button to display the 'options-2' screen, and then use the 'up' and 'down' button to select 'lamp runtime'.[4] Press and hold 'enter' button for approximately 3 seconds. The 'lamp runtime' will change to 'time reset [power off]. Note: If the 'menu' button is pressed the lamp time resetting screen will be cancelled.[5] Hold down the 'power' buttonfor at least [0.5] seconds or press the 'power' button twice to turn oFF the power. This will reset the cumulative usage time for the lamp unit into Zero. OK.
Dec 20, 2011 | Panasonic PT LC75E Multimedia Projector
When I press shut down, the laptop screen gets off but the power button stays on and the laptop stays warm too. I have to press power button for 5 sec to turn this thing off. When I start it I don't...
hi, when you press the power button it'll goes to sleep mode only. You can change it by accessing control panel -> power option...
thanks & regards Anas K A
May 29, 2011 | Dell Inspiron 1545 Notebook
Nokia c3 how to make a signature on messsage
1. Open your Nokia . Go to the main menu. The buttonfor the main menu is at the top right of your phone, just underneath thescreen. 2. Move the "Right" arrow until you reach"Messaging." 3. Move the "Down" arrow until you reach"Message Settings." Press the "Center" button to enter thismenu. 4. Choose "Signature" from this menu andpush the "Center" button again. Move the "Down" arrow untilyou reach "Custom," then push the "Center" button. Thiswill open the Signature menu. 5. Write your text signature in the text box on theSignature menu. When you are done typing, press the center button again andthis signature will show in every text you send.
May 23, 2011 | Cell Phones
I have memorex radio/cd/cassette player model MP3226. The PLAY button on the cassette tape does not stay in the down position when pressed when a tape is in the housing. If I remove the tape, and press...
I can imagine 2 cases for your problem:
Either there is a mechanical problem and something is not allowing the "play mechanism" to go all the way up to the clip position when the cassette is in the housing,
Or the tape isn't rolling up properly. Some of these deck's have some kind of protection and when the tape isn't rolling properly a system stops the play procedure. Check if both of the rollers for the tape are spinning around properly. In case of not spinning, run the cassette fast speed forward and backward in order to come to the proper state. Also check without any cassette is any roller spinning around or not?
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 15, 2011 | Memorex MP3126 Cassette/CD Boombox
I have a Lexmark X4875 printer/scanner. I don't have the know-how to use the scanner. the printer is connected to my desk top and works fine but i don't know how to scan and save the image
Hi There and Welcome to Fixya.
Here's how to use the scanner for your Lexmark X4875 (Basic scanning) :
  • Ensure that both the computer and printer are connected and turned on
  • Load a document facedown on scanner glass
  • From the printer control panel press down or up arrow until "Scan" is highlighted
  • Press the "Action" button
For your convenience, I have included Lexmark's user guide through the below link:
Lexmark Manual
You will find comprehensive and detailed processes to make the most out of your AIO printer.
Thanks for using Fixya.
Apr 12, 2011 | Computers & Internet
My pt-ax200u runs for about 15 mins then turns off. The replace bulb light is on but otherwise vents are cleaned and and cooling fan is running.
hi,
try one thing reset ur projectors lamp hour and the try
follow the procedure for lamp reset
1. power on the projector
2. press the menue button
select options and then press enter
select lamp rutime
press and hold enter buttonfor 3 seconds
confirmation screen will display and select ok
press power buttonfor turn offfor resetting the duration of the LAMP RUNTIME
confirm theduration of time in lamp run time
Jan 06, 2011 | Panasonic PT-AX200U Projector
I dont Know what i need and how to get online
Hopefully this will help solve your problem:
1. Press and hold down the power button located at the front of the PS3 console, until you hear a first beep, then eventually a second – before the console shuts down, then let go of the button;
2. Now press and hold the button again until you hear a first beep, then a second beep then eventually a quick double-beep, then let go of the button;
3. The TV screen should now display a six option menu, where you can select what’s required, i.e. `Restart System`, `Restore System` etc. `Reset System` should only be used after other attempts with the other options, as your game saved data may be lost. If you play Modern Warfare 2 online, then this won’t be affected as your data is saved on the Sony Server.
4. During any of the above actions, your best having your handset controller connected to the PS3 via the USB cord, which includes pressing the `P` button when required (located between `Start` and `Select`).
These actions should help solve `freeze` problems and others such as update errors etc – which restrict you starting up or playing your console.
Don’t hesitate to contact Sony UK if required, who are very helpful. Their UK number is: 0844 7360595
Good Luck!
Jul 04, 2010 | Sony PlayStation® 3 (60 GB) Console
Date Settings
Hi there and thanks for coming to FixYa.
To put the date and time stamp on the images do this:
1) Set the Mode dial to Setup.
2) Hit the Up arrow on the control button to Camera and hit the right arrow on the control button.
3) Select Date and Time with by hitting up or down arrow on the control button then press right on the control button.
4) Hit the conrol button up or down to select Date and Time, then press the center of the control button.
5) Return the Mode dial to the camera postion to start taking pictures.
Rob
Feb 28, 2009 | Sony Cameras
Sleep mode
If u use Windows OS go in control panel - performance and maintenance - power options, and u'll find there the settings for shut down/stand by/hibernate ...etc
U probably don't have to press the ON button, but the sleep button to come up from that state (probably Fn buton and sleep button (it has to have a pictogram on it ....))
Jan 16, 2008 | Toshiba Tecra T9000 Notebook
Quinny Dreami - Black Bassinet Logo
543 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Al Toledo
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
