No tumble just spin faults on Hoover WDM 120
Machine suddenly started to spin after filling with water at the beginning of each cycle and during drying cycle when tested. Found burnt out connections on motor control board and replaced it but still has same fault. No tumble just spins instead. I think the contacts in the controller may have stuck together but would like any help if possible before I go down this line. Brushes checked and OK no other obvious faults
  • bustersmail Sep 01, 2008
    Which connections are you talking about? The motor connections or the motor PCB connections? I have checked just about everything possible and to no avail.
  • bustersmail Sep 02, 2008
    All connections checked decided to replce the machine as I can be sure that spending a small fortune on a part will clear it. Thanks for yur help.
  • 2,785 Answers
Plz recheck you connection and clean the connecting points otherwise you have to call a service person for the servicing
Posted on Sep 01, 2008
  • Rajkumar Bordoloi
    Rajkumar Bordoloi Sep 02, 2008
    i am taking about the wires which are connecting to circuit board
For about a month my LG WM3677HW began to not dry my clothes. I noticed that the water was not shutting off in a timely fashion during the initial wash cycle, as it previously had. My drum was also not...
Hello, My Name is Mike, please do me a favor and check out this link I gave you below to see if you can dissect some of your issue of the symptoms, and this might in its self help you with this problem. Please let me know it this helped some. Thanks Mike
Please copy and paste this link into your browser.....
Sep 29, 2011 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Hoover hpe 236. water not draining, stops mid cycle, lights flash
    Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
    If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
    Hope this is of some help to you.
    Jan 16, 2010 | Hoover Washing Machines
    Codes and holes
    Hi mandystreet,
    I’m an owner like you; from what you describe I feel you have a clutch issue if you’re machine is a FAV6800AW or FAV9800AW. I'll bet it completes the spin cycle with no clothes in the wash basket. Here is what is happening
    See this post for a step by step process to remove the clutch. Try a maintenance clean up of the One-way Roller Clutch bearing and see if that will get you back in service, if not I would do a Clutch replacement.
    Your machine is shutting down the spin cycle with dc and UC errors so your Tub Displacement Sensor is working as designed.
    From the Service Manual page 12;
    During fill cycle – If machine tumbles and spins simultaneously replace clutch assembly.
    During spin cycle – If machine tumbles and spins simultaneously replace clutch assembly.
    You can check this out by turning off the water supply lines if you check during water fill cycle. Lift the washer top from the base and observe the action during water fill or spin cycle. The Service Manual will show you how to raise the washer top from the base.
    This is happening because the clutch One-way Roller Bearings are sticky, slightly rusted. When the machine enters spin cycle the agitator shaft is slightly engaged because the one-way roller clutches are dragging this will cause the agitator shaft to rotate in spin cycle spinning the tumblers slightly. In this condition the wash load is tossed about while the wash basket begins to spin up. This will cause the Tub to become unbalanced and the tub starts making greater swings.
    This continues until the TDS (Tub Displacement Sensor) signals an unbalance condition to the Control Board and shuts the cycle down with a dc or UC unbalance errors. If the TDS fails in this mode the machine would likely walk across the floor until it unplugged itself or ended in a self-destruct.… :)
    A WD-40 clean up and re-lube may get you back in service. Just follow this posting step by step. If you are not a DIY type direct your service repair to this e-mail to help speed you to repair and control cost. You can redistribute the wash load until the cows come home and you will continue to fail with UC or dc unbalance errors…. Fix the clutch issue and your machine will be happy and so will the owner.
    Sep 14, 2009 | Maytag Neptune FAV6800AW Top Load Washer
    Basin will not fill with water during rinse cycle but will agitate and spin.
    most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
    Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    I have a bosch wfk 5730 washing machine has been very reliable but now continuously keeps taking water in to machine, at timer position "F", just before the final spinning cycle begins, till it...
    Could be an iffy valve/ solenoid. One test is to see the empty machine slowly fills up with water, if you leave it for a few days. You can isolate teach valve by turning each feed off in turn. i t could be leaking all through the cycle. If it is flooding during the spin I'd check your pump at well. Hope this helps.
    Sep 02, 2008 | Bosch Washing Machines
    Spin cycle issue
    if this is a frigidaire as in the healine , then see if the tub turns over at all. if not then it may be the inverter board located on the bottom right rear. If there is water left in the tub now that water should drain before it will fill again. check drain pump for obstruction/operation.
    for the inverter, there is a techsheet in the bottom attached to the wall, It gives info for checking it. Have a multimeter handy.
    Apr 23, 2008 | Frigidaire GLTR1670A Front Load Washer
    Washing Machine Hoover H100M fills too much water in the drum.
    this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
    Mar 05, 2008 | Hoover AAA140 Front Load Washer
    Frigidaire washer machine #FWTBB30DS0
    check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
    Jan 17, 2008 | Frigidaire FTF2140ES King Size Front-Load...
    Washing Machines Logo
    59 people viewed this question
    Top Washing Machines Experts
