Question about Insignia NS-DV2G MP3 Player
Insignia wont turn on or charge. battery is new. I have found nothing to b loose. One guy said it might b a piece came loose above the battery, but that wasnt the problem. Can some one pease help.
  • Jleec1992
    Jleec1992 Aug 30, 2008
    ok how do i upgrade it if it wont turn on.
  • Insignia Master
  • 1,800 Answers
Hi
this problem occurs when the firmware is damaged try to give it a firmware upgrade.
click here
this page might help u ^^
if u want more instructions tell me so i can help u further
plz rate this post.
Posted on Aug 29, 2008
Olympus Tough 8000 wont charge
Rechargeable batteries will fail if stored for long periods in a partly charged or in a zero charge state.
You need to replace this battery with a new one.
Sep 27, 2012 | Olympus Stylus Tough 8000 µ Tough 8000...
Garmin nuvi 2595 will not take a charge
I found my brand new nuvi 2595lmt repeatedly power cycling and loosing its charge when I tried to charge it (for the second time as well). I was using a different USB cable. When I switched to the supplied cable with the "Garmin" insignia on it, the problem resolved. Hope that helps, good luck.
Feb 17, 2012 | Garmin GPS
My Insignia NS-BTHDP headphones don't have a red charge light anymore. The first charge out of the pack had the red light on. But now the red light doesn't come on anymore. I wonder if it is really...
The LED may have just gone bad. Keep using it untill the battery dies, then try charging it and use it again. If it works as it should it means the LED died and there is nothing to worry about, if not you may need to replace the battery.
Jun 16, 2009 | Insignia Bluetooth Wireless Headphones...
I have a 1995 kawa. ninja zx-6, i bought a new battery and junction box for it. i took the new junction box off because the head light would not turn off, so it is running w the old box and the new...
Hi and welcome to FixYa,
Your description indicates that the battery is not charging when the engine is running. This could be:
  • faulty regulator;
  • loose/corroded connector/terminals at the regulator;
  • loose wire/terminal from the regulator to the battery + terminal;
  • loose battery ground to chassis/harness;
  • loose ground from regulator.
Check and correct based on the above.
Good luck and thank you for using FixYa.
Feb 23, 2009 | 2001 KTM Supermoto 125
Insignia 5.0 mp hd camcorder. How do I charge the battery?
Make sue the text side of the battery is facing up. Not the pure black side... I was having this problem until I decided to flip the battery around and it worked just fine...
Jan 09, 2009 | Cameras
Frozen/wont charge/turn on
when your mp3 player freezes hold the power switch like your going to turn it off and holdit for roughly 10 seconds. that should reset the mp3 player
Aug 24, 2008 | Insignia Sport MP3 Player
NO POWER!!!HELP
Is the voltage meter directly on the Battery?? What model Dell is it?? I have found that on the D800 models for some reason the connection from the power button to the Motherboard comes loose. You need to remove the Keyboard cover to check this.
Jun 06, 2008 | Compaq Evo N610C Notebook
Sony ericsson k800i
we will approach the problem this way
1) your battery might be the culprit , first charge your battery in a different piece, and then replace ans see.
2) if the above doesnt solve the problem clean the connectors of the battery that shiny golden part of both your battery and mobile piece , with nail p[olish remover or alcohol.
3) last resort now will have to open the piece and check for the on/off switch .
4)lastly software reflashing, but if the piece aint detecting, need to clean the datacable connectors with nail polish remover or alcohol.
the above should bring your pice to life.
Apr 23, 2008 | Sony Ericsson K800i Cellular Phone
Insignia NS-DV2G MP3 Player Logo
47 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
