Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer does not stay full of water
I HAVE A WHIRLPOOL CARE THE WASHER KEEPS FILLING AND NEVER GETS FULL THR WATHER JUST DRAINS OUT . AND YES THE DRAIN HOSE IS HIGHER THAN THE WASHER? WHATS UP WITH THAT?
  • Anonymous Mar 16, 2014
    Please help me. M'y washer doesnt start runing or spining once ils full of wather. Seems to be a sensor probllem wehnelt i close it.
    Genius:
  • 1,028 Answers
But is the end of the hose fitting snug in standpipe?? if it is water may be siphoning out due to no air break once 1st drain takes place ..stand pipe needs to be slightly larger tah end of drain hose to allow air to break the siphoning action
Posted on Aug 30, 2008
My whirlpool washer seems to be letting water back flow from the drain line.
sounds like the drain line is too low it needs to be higher than the water level when running a full load...you can check this buy filling with water and stoping the cycle and see where the water stops draining im sure it will stop at the level of your drain line in the back of the washer. the drain line in the back of your washer should come out of the bottom of the washer and then go up to a drain pipe..if its lower than the full water level of the washer then gravity will take over and drain the water... i hope this helps
Sep 09, 2011 | Whirlpool Estate TAWS750PQ 27-Inch Washer
My whirlpool ultimate care 2 washer was leaking underneath while running, I removed the back panel and dropped the drain hose to the floor and extended it out the door to the yard and while filling the tub...
The drain hose must be at least level with the top of the actual tub in the washer. The water pump is only bad if it is leaking. If it is leaking from the front you either have a cracked outer tub, but it sounds like your water pump, easy to change out just get the model # and order it through an appliance parts distributor. The cost is about 40 to 50 bucks. good luck!
Aug 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water runs continuously tub never fills My Fisher & Paykel top loader keeps filling and draining at the same time. It never gets full of water. The hose is way higher than the machine, but still drains...
where is water draining into? have u got grey water hose attached to it?make sure u can see end of drain hose, put into bucket at lid level, if it still drains as it fills u have a faulty control module.please reply for more help
Apr 06, 2010 | Fisher and Paykel IWL12 Top Load Washer
Washer keeps filling up with water and it will not stop
the main drain hose may be stuck to far down inside the drain tube.if the machine is not over flowing and flooding your plaace.then pull the drain hose up to the level of the control head.with the machine off,you should here water running out once that has stopped restart your washer put keep the hose up and it should stop filling when it gets full.
Sep 19, 2009 | Washing Machines
Water keeps filling the washer
If the washer keeps filling and overfilling then unplug the machine and see if the water still continues to come in. If this is the case, you have a bad water valve. If the washer just keeps filling and never gets to the top then your drain hose is shoved too far down into your house standpipe and must be pulled up and an air gap established.PART NUMBER 285805 @ 30.00 FOR WATER VALVE
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Yes if its filling slow do to a blockage in a screened hose it will .If it never stops filling and doesnt over flow than its syphoning the water and you need to elevate thr drain hose higher than the water level and it will kick into wash. Please rate This !!
Jul 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal De
