Question about Intertherm Heating & Cooling
Wireing specs for ainterterm electric heat unit [e2eb012-ha ] unit my wires burnt becouse ac water trap was stop up
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Go to a supply house that sells that brand or chek out the website.
Posted on Aug 30, 2008
Wiring from coleman rv ac unit has 6 wires and duotherm rv ac unit has 10--what do you do with other wires
you need a wiring diagram of each to see what they are for. heat pump, auxillary heat, inside sensor, outside sensor, electric heat, gas heat there are many different applications.
Aug 20, 2015 | Coleman Heating & Cooling
Hi,i have a Dualit coffee percolator which has suddenly stopped working,have you any advice as to how I coud fix this - could it be the pump?
Is it the electrical part? Are the lights on? If the lights are on then it is probably the flow of water. Hard water will stop it from working. Sometimes there is a blockage. You can try to put CLR or vinegar through the machine. You may even want to find someone with an air compressor. If you blow air from the "out spot" it can clear a blockage. If is difficult to tell without having it on front of me.
Sometimes the heating element can be burnt out or a wire is burnt off. Examine the wiring on the inside for any burnt wires.
Jan 27, 2015 | General Coffee Percolator Gcp60 60 Cup...
Dryer runs, heat quit this morning while in use. lint trap is clear.
Likely causes, in order of probability are:
1) Heating element has broken in two, needs replacement..
2) A "overheat shut-off thermostat" has clicked open, needing replacement.
3) A wire (likely near the heat element) may have burnt in two, need a repair.
4) A wire in the connection at the back of the machine where the electric cord is hooked up may have failed, needs repair.
5) A circuit breaker in your "fuse box" may have tripped, needs reset.
If you wish to attempt repairs yourself, you'll need tools, a testing meter, and a plea to "fixya" could cause someone to give you step-by-step instructions.
Be blessed.
Feb 21, 2013 | GE Dryers
Tankless electric water heater not heating
If you smell it - look fer it. It may be a bad connection on the AC supply line all the way back to the service panel or inside the heater connection panel. Bad connections cause high heat and discoloration of wires or connectors and a serious voltage drop to the appliance.
Jan 29, 2012 | Bosch PowerStar AE125 AE125 Whole House...
My Goodman CAPF020B2C HVAC unit continues to run, but does not produce any cold air through the vents. It only stopped doing so a few hours ago, and I have not changed any settings today.
If the unit is still running and sounds no different to you - I would bet that that the compressor "is not running."
The fan motor of an AC unit is the sound most people identify with - but, the compressor (which is the heart of the system) makes a different sound which is usually 'hidden' by the noise of the fan.
Therefore, many customers assume that the AC is running normally (when the fan motor is running and the compressor is not).
I would turn off all power (BE SURE IT IS COMPLETELY OFF) and then I would feel the compressor and see if it was hot.
If it's 'hot' then it's probably went off on an 'internal safety.' In which case you could leave the unit off for awhile and let the compressor cool off. While it's cooling off you could make sure the condenser coil is clean. If it's not - now would be a good time to clean it with a water hose. Note: the water would also help the compressor to cool. NOTE: try and be careful with the water hose and to not get excessive water in the wiring or fan motor.
IF the condenser coil is dirty then it's possible that - that was the reason for the compressor getting hot and now (with a clean coil) you will not have any more problems. IF, however, the unit does not cool (after cleaning the condenser) you will need to have an AC Tech troubleshoot the unit.
However, if the compressor is 'cool' to the touch that means it's off for some other reason and most likely you will need someone to troubleshoot the system. However, you could look for loose wires to the compressor or even a wire that is burnt off. If you are electrically/mechanically inclined you can repair/replace a burnt off wire to the compressor.
Also, you could check the capacitor (a large silver/gray in color device electrically connected by wires to the compressor) and see if it's bulged - in which case you can assume it's bad and needs to be changed, which may solve the problem.
hope this has helped.
Aug 05, 2011 | Heating & Cooling
How does the reset work? I am helping a friend troubleshoot his water heater. One of the wires that connected the pig tail to the power block fried inside the water heater cover. I decided to remove the...
The reset button is set up to open the circuit if excess current is drawn by a failed Element. It works by getting hot and switching off due to current above its rating. The burnt wiring more llikely happened over a period of time because of a resistive joint in the block getting hot due to the high current that water heaters consume. It seems that the element has failed if the reset button does not get the system working.
Sep 17, 2010 | Rheem 81VP15S Point-of-Use Electric Water...
Electric dryer won't heat, maybe the heating element but before it stopped heating i cleaned the lint trap and something fell into it and i didn't notice and turned it on and could hear it hiting...
Sounds like you broke the heating element. Go to a local shop and get one. You may have also burnt the timer so after element you may need a new timer as it tells it to put power to it.
Jul 08, 2009 | Whirlpool LER4634J Electric Dryer
Goodman PC060-1B Package AC...Need Wiring Help
Depending on the size of your Electric heat you can use one set of wires because your unit does not run with the heat like the heat pump. The large set of wires going to the electric heat should be used. You may have to jumper a new set to the contactor. On Goodman unit come in L1 and L2 jumper to contactor. Very simple good luck. Rus
Jun 21, 2009 | Goodman Heating & Cooling
Not drying my cloths . runs but there is no heat
Since the unit will run but won't heat...
The following are things that could stop an electric dryer from heating:
bad heating element(s)
loose, corroded or burnt wire(s)
thermostat(s)
thermal fuse ( not all models )
motor heat switch
timer
selector switch
The older the unit the more likely it's heating elements or thermostats
Sorry....this can take some time to diagnose
Apr 10, 2009 | Amana ALE866SB Electric Dryer
Intertherm heat coils won't stay off until breakers off,thermostats are off
it is the heat sequencers. it happens all the time. replace them wire by wire to keep it simple. they are located behind the metal next to the breakers they look like this: cdf7518.jpg
Oct 19, 2008 | Intertherm P3RA-024K Air Conditioner
Heating & Cooling Logo
35 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
