Question about Sewing Machines
Elna serger sewing machine model pro 704 dex
The needle clamp release button which is red and which alows the needles to swing forward for threading is stuck and will not swing back into place. it seems that the spring (has red button to release) has come loose . I have removed the needles so they wont catch on the face plate but still no help.
  • 192 Answers
SOURCE: Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Posted on Nov 14, 2007
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Posted on Aug 13, 2008
Michaelle
  • 65 Answers
SOURCE: Replacing needle on Elna Pro 905 DCX serger
Try and loosen the screw, and use a magnet to pullout the broken piece. It likely slightly bent in there so you may need a pair of tweezers as well
Posted on Jan 24, 2009
SOURCE: needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Posted on Feb 21, 2009
  • 323 Answers
SOURCE: The foot in my elna 704 broke. Where can I take
go to Elnausa.com and check out dealer locater.
sewman7
Posted on Jun 09, 2009
Elna Pro 4De serger thread breaking
Be sure to thread each in the ORDER specified--for most machines (but yours may differ) upper looper, lower looper, then needles. Follow (closely) the threading diagram on the machine. Missing one guide or hitting the guides out of order will throw you machine into a tizzy! On my serger, the lower looper has to lay over the top of the upper looper/thread before it all gets pulled under the presser foot toward the back of the machine.
It also may help to RAISE the presser foot when threading the machine.
Having problems threading my Elna Pro DE 4 sewing discussion topic...
Threading elna lock pro 4 DE green knob
Oct 06, 2017 | Elna Sewing Machines
Elna 745 serger won't sew
the motor could have gone out or the machine could have jumped time, you may want to have the machine checked at a sewing machine shop
May 14, 2012 | Elna Sewing Machines
Elna 704 dex skipps stitches in cover hem.
The timing could be off. First make sure you are using EL needles. This machine is set up for these needles only.
Apr 24, 2011 | Elna 1010
Needle hits
Does not matter what machine you have from a 50's straight stitch to a newer model right out of the box. If your needle is hitting you are out of time. It needs to be reset and on that I can not help you as it is mechancal on the underside. What the needle is hitting is the bobbin arm.
When the bobbin arm swings around it picks up the top thread and loops it over the bobbon thread then releases the threads together for the loops and swings again for the next thread. When you hear the needle hit it is hitting this swing arm. That needs to be adjusted and that is called timing.
Open the bobbin case and turn the needle down by hand. You will see the needle as it goes through the throught plate down the catch the bobbon thread. You will see it hit the arm.
This needs to be backed off or set forward. Takes a trained person as I have never been able to do it myself. This happens when you sew to thick of a fabric, or go over several seams from light to thick. Or is you are pulling the fabric. If you head a CLUNK when it started then that is what I think it is.
Dec 18, 2010 | Euro-Pro Shark 9110 Sewing Machine
Cant make the auto threader work on an elna 2007
Do you mean the auto needle threader?
Mine won't work on very small needle sizes so I resort to the old manual needle threader for these. Ditto for twin needles.
Otherwise its a case of pulling the auto threader down so the hook swings into the needle eye, then pulling the thread over the face of the needle and catching it into the hook, then release the threader so it pulls back through the needle eye, taking the thread with it.
The only other thing that springs to mind is "is the needle at the top position in its stich cycle so that the threader lines up with the needle eye?
hope these ideas help a little.
Dec 03, 2010 | Elna 2007 Mechanical Sewing Machine
Hi, I broke a needle on my Elna 704 Dex (whoops,) and while my looper seems fine, I have been struggling with the tension ever since. The stitch will only balance if the differential is tightened further...
You may find that you need to re-thread the entire machine.
Raise the presser foot and set the tensions to zero.
Refer to the manual for threading order.
Mar 04, 2010 | Sewing Machines
Elna Pro 5DC Serger
Sound to me you should get it serviced. Your timing is off. It also could be your needle make sure you use serger needles
Aug 08, 2009 | Sewing Machines
Sewing Machines Logo
314 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
