Question about Linksys RangePlus WRT100 Wireless Router
Unable to Connect to Internet
I am pretty sure the cables are connected right. But my internet will not connect once my Ethernet cable is moved from the computer into the wireless router Port one. DSL cable comes from the modem to the router. tell me what i am doing wrong.
eyluldeniz_06@hotmail.com
  • 1 more comment
  • dingie2 Oct 01, 2008
    Verizon Model 6100 modem being used . Verizon online support told me and the Verizon Tech Sever. person that they did not deal with Linksys Wrt100 Router. When I bought the router Verizon at that time told me to get this one. Why now do they not accept this and help me fix it. I am now using the modem only that is the only way that Serv. could get it to work. and the other pc that I have can not get on line with out using a router.
  • quiquee Nov 26, 2008
    router install ok, but windows cannot communicate with primary DNS server
  • Aris C.
    Aris C. May 11, 2010
    Who is your internet service provider and what is the brand name the DSL modem that you're using?
When I connect my WRT110, I get a valid ip address when I run ipconfig. But the error report says cannont read the http. My old WRT546 still works. Tried on two computers - no luck. Also, the software that came with unit says cannot setup the network.
help
Posted on Oct 31, 2008
    Novelist:
  • 173 Answers
Make sure that the cable/dsl modem is connected to the blue port on the Linksys router that say's internet and your computer to any of the yellow ethernet ports. Check what is the IP address of your computer by typing ipconfig on the command prompt(assuming your using Windows, to open command prompt click start and go to Run and type cmd, a black windows will open normally it will say C:\Document\Settings\Owner>. Your computer should obtain an IP address of 192.168.1.x, open Internet Explorer and type this address on the address bar http://192.168.1.1 when you get a prompt for a username and a password, leave the username blank and type "admin" for a password from there you can now check the entire settings of your linksys router, check the Status and make sure your router is getting a valid Internet IP address if not you may require manually setting up the configuration of your ISP on the router.
Posted on Sep 27, 2008
Establish connection with my internet router
If you are unable to connect to the internet wirelessly, my suggestion is to do two things:
1) Move your router and your XBox as close as you can. This will help your signal strength.
2) Purchase an ethernet cable. They usually run around 10 bucks and will provide you the best possible connection. You plug one end of the ethernet cable into the back of your XBox and one end of the cable into the back of your router.
Jan 16, 2012 | Microsoft Xbox 360 Console
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
How do you set the router up!!! no diagram to hook up to desktop
How you connect it depends on how you plan to use it. Let me explain:
Some people have a dsl line (high speed internet connection) and their modem from their internet provider only has room for one computer cable to connect and use the internet. If the customer has more then one desktop computer they want to connect to the internet, they will need to buy a router. A router provides multiple ports for several computers to connect to the internet at the same time.
If you have a dsl modem already and bought a router to add additional computers to your network - then follow the instructions below to set it up:
Connect your phone cord from the wall into the dsl modem. Plug in the power cable from the dsl modem to the wall and turn it on. Connect an ethernet cable to the dsl modem (ethernet cables are the ones that look like a regular telephone cord but the ends are a little larger) and connect the other end to your router. Make sure you plug this cable into the port marked "ethernet" on your router. There is only one port for your internet connection line coming into the router, the rest of the ports are for adding computers only. Some routers say the word "ethernet" near the port for the internet connection. Others have a picture near or or brackets around it to show that it is different then the others. Plug in the power cord to your router and turn it on. Make sure you turn on your modem first and let it warm up before connecting your router. Modem power on first, then router power on - always.
Now connect an ethernet cable to your router and connect the other end to the pc you wish to use on the internet. Do not turn on your pc until the ethernet cord is attached. Your dsl modem has to be powered up first, followed by your router and then your pc. All in that order.
Your computer should automatically sense the internet connection upon start up. You can verify that your connection is installed correctly and that your pc is sensing it by looking at the bottom right side of your screen near the clock area. You should see a picture of a computer monitor that represents your internet connection status. Sometimes they glow green when they are healthy. Sometimes they show a red X on top of them if they are disconnected from the internet. If you can't find the Icon for your internet connection on the bottom right side of your screen, unplug the ethernet cable from the back of your pc - while watching the bottom right side area and plug it back in again. Watch for a change to locate the icon. Sometimes there is a downward pointing arrow near the clock which needs to be clicked on to open up the area and view the icons.
Thats all! One line from the modem to the router - another line from the router to the pc - and the internet should be up and running fine.
If you bought a router combination modem - then its the same as above - just without a separate dsl modem. (i.e. Connect the power cable from the router/modem to the wall. Connect the ethernet cable to the port marked "ethernet" for your internet connecton and connect the other end of the cord to your pc. Then turn your pc on. Router/modem power on first and pc power on second in that order)
All the lights on your modem should be green and steady - except for the one marked internet or connection which is usually flashing and moving. If you have any red or yellow lights then you need to troubleshoot and correct the problem before your internet connection will work.
Mar 03, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
How to set internet on it
if you are using IP phone, make sure that you connect the Ethernet cable (yellow cable) from the modem or router to the LAN part of it whereas another Ethernet cable (blue cable) is connected from the IP Phone to your PC Desktop.. This connection will surely connect your phone to internet and to your PC...
Feb 15, 2011 | Lands Phones
How do i get my hp pavilion a320n to connect to the internet through charter
Usually Charter will supply the modem necessary to connect your computer- you will need an ethernet cable as well. Once you have the cable modem connected- connect the ethernet cable to your pc. At that point, you should be able to connect to the internet
Oct 03, 2010 | Computers & Internet
I just moved into a new apartment and I am currently attempting to use the same linksys router that I used at my old place (without difficulity). My lap top in the bottom right corner displays...
> excellent connectivity
This refers to the wireless connection between your computer & your router, not to the connection from your cable-modem (or DSL-modem) out through your ISP to the Internet.
If you use an Ethernet cable to connect your computer directly to the cable/DSL modem, do you still have "intermittent" problems?
If so, then your router (or other wireless devices, such as your neighbours' router, or your neighbours' wireless telephones that are trying to operate on the same broadcast frequency) is the problem.
Aug 21, 2010 | Linksys Wireless-G WRT54GS Router...
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
I f I connect hotel internet via Apple USB 2.0 Ethernet Adapter to my MacBook Air, internet after few minutes disconnected, to connect again i take out the cable, and then plug in, usually internet start...
Try turning off Airport. Your computer may be finding a wireless network and automatically switching to it, and getting an intermittent signal. Just a guess, but for a good ethernet connection you want to disable the Airport searching feature anyway.
Open the System Preferences application, select "Network" and right on the top left of the resulting window there's a pretty big button that will either say "Turn Airport On" or "Turn Airport Off" - just turn it off if it's not already ...
Hope this helps!
For help with Public Address Systems see my new How To Video, available as a DVD at www.whamuniversal.com
Feb 15, 2010 | Apple USB 2.0 Ethernet Adapter for MacBook...
LOST DRIVERS
Here is the download page.
For wireless install all versions te system will use only the right driver.
Mar 11, 2009 | Fujitsu LifeBook C2340 Notebook
Cant connect my G5 to the Router to get internet
two things to consider. There are two different types of Ethernet cables out there. Perhaps you have a one way cable for the second one. To test this, unhook the working cable from the mac that gets internet and then hook that one up to the one that doesn't get it. See if it sees the network after a minute. The other issue might be in the Operating System. You might need to make sure that they are both up to date with all of the latest updates installed. (I know, hard to do with out an internet hook up.)
Lastly, make sure you are plugging in the cable to the right place on the back of the router. Seems silly, but some of the best have accidentally put it into a link plug to connect several routers rather than an actual Ethernet plug.
Dec 22, 2008 | Apple iMac G5 Desktop
Linksys RangePlus WRT100 Wireless Router Logo
251 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
