Question about Dell Inspiron 1000 Notebook
Installing memory on a Dell laptop
How do I get the keyboard off so I can install memory on my laptop?
    Scholar:
  • 87 Answers
Are you sure you have to access memory via the keyboard. Most dells have a compartment on the underneath
The following link on the Dell site shows you how to install additional memory. I'm sure it will show how to unclip the keyboard.
http://support.dell.com/support/edocs/systems/ins1000/en/index.htm
Posted on Aug 29, 2008
2 Suggested Answers
CowboysFanZ
  • 99 Answers
SOURCE: installing ram
You need to go into the bio and update the memory there and the Yellow ! will go away. Boot the PC, select the F8 key during post, go into the setting for Memory and accept the change and you should be good to go. Let me know //D
Posted on Apr 25, 2008
Computer beep codes
Installing Memory), and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • Installing Memory).
  • Memory Installation Guidelines).
  • Replacing the Battery).
  • If the problem persists, contact Dell.
  • 6
    Video BIOS Test Failure
    Contact Dell.
    7
    CPU cache test failure
    Contact Dell.
    Nov 11, 2013 | Dell Computers & Internet
    Where dom i insert new memmory in a dell latitude d820 computer?
    1. Remove the keyboard bezel with a flathead screwdriver.
    2. Remove three screws securing the keyboard
    3. Unplug the keyboard cable from the motherboard and remove the keyboard. The internal RAM (memory) slot is located under the keyboard, right above the touch pad buttons.
    -How to remove keyboard ( with pictures ) -
    http://blogs.microsoft.co.il/blogs/tamir/archive/2007/11/16/diy-how-to-replace-your-dell-latitude-d820-keyboard-for-only-13-99.aspx
    Aug 21, 2011 | Computers & Internet
    How do I install memory that's under keyboard on d830 latitude
    Lift up 1 side of the keyboard cover with a small flat screwdriver.
    Remove keyboard cover.
    Remve three screws securing the keyboard.
    Lift up the keyboard and placed it on the display panel or palm rest, so you can accss the memory slot A. The keyboard is attached to the mboard via a flat ribbon cable.
    The memory slot A is located just abve the touch pad buttons.
    In order to remove the existing memory module carefully spread latches on both sies of the memory slot.
    The memory module will pop up at a 30 degree angle.
    Pull the memory module from the slot A by the edges.
    Install new ram and put everything back together.
    Done!
    Sep 10, 2010 | Dell Latitude D830 Laptop Computer PC...
    Dell D 600 Cursor locked can not do anything - even after power is turned off and on
    Try booting up after installing an external USB mouse. This may give you a mouse to install new keyboard drivers. If the problem is the keyboard/tracking pad, (hardware) installing another keyboard may eliminate the issue.
    Jun 14, 2009 | Dell Latitude D600 Notebook
    Dell Lattiude D600 cursor locked in middle of screen - even after we turn on and off - no way to do anything because cursor won't move - not even little blue mouse in the middle of the screen
    We have a Dell D600 Micrsoft XP and the cursor is locked
    Does the keyboard work? If so, you'll need to do your best to use the keyboard to download and install these drivers here.
    Error message after installing memory ram upgrade.....
    The memory appears to be the right kind.
    Try installing just one 1GB module, and run the diagnostics (press F12 at boot time and select diagnostics).
    Dec 20, 2008 | Dell Inspiron E1505 Notebook
    Installing memory in dell lattitude c400
    I have one of these myself, love it. The other memory chip is under the keyboard. Remove the plastic strip that has the power button on it, and you'll see the four screws holding the keyboard. Once you get the keyboard off you'll see the other memory chip.
    Jun 25, 2008 | Dell Latitude C400 Notebook
    Installing Memory
    Hi
    Yes, you can replace/upgrate the memory module under the keyboard.
    Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
    Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
    Read "Preparing to Work Inside the Computer" before committing to the above procedure.
    Let me know how you get on.
    Mike
    May 24, 2008 | Dell Inspiron 2650 Notebook
    Dell Inspiron 1000 Notebook Logo
    60 people viewed this question
    Alun Cox
