Question about Kicker 06ZX750.1 Car Audio Amplifier
Blowing fuzes fuzes blow when power is connected
  • 631 Answers
If the fuses blow before the remote voltage is applied, the power supply FETs or the reverse protection diode has likely failed.
Let me know if you have any other questions.
Posted on Aug 30, 2008
4X4 BLOWING FUZES CHANGED ACTUATOR
look for a pinched leed from the sensor or maybe actuator is shorted . with power off check each wire for direct ground
using a vtvm to find the gremlin,
just don`t feed it before dark!
Apr 20, 2015 | Cars & Trucks
Hi. Could you tell me which fuse controls the electric aerial. Nissan terrano ll 1996 import.
typically the fuze is under the hood. It is a inline fuze attached to the antenna motor.. I may be hidden under the fender, so find the motor for the antenna and follow the wires till you come upon the fuze holder. It comes apart with a twist, be sure to replace with the same value fuze. 2 amp usually. It has been my experience that these fuzes blow because of a short in the wiring or a short in the motor itself. so if your replacement fuze blows right after you put it in, you have more than a fuze problem.
Mar 03, 2015 | Nissan Cars & Trucks
I cant open
Push the power switch up as far as it will go and see if the blue ring on the front of the player lights up.
The Fuze's power button is not a traditional button but a slider, so if you did not push the slider up all the way, this may be the only reason it was not powering on.
Reset the Fuze by pushing up on the power switch and holding it in the up position for 10 seconds.
Try to power on the Fuze again after it has fully rebooted.
Connect the Fuze's USB cord from the Fuze to a USB port on your computer.
You should see a yellow charging light illuminate and the battery symbol blinking on the Fuze's main display.
Once the battery stops flashing, the Fuze is fully charged and you can try to power it on again.
hope this helps
Sep 27, 2012 | SanDisk Sansa Fuze MP3 Player
Blows a fuze when turned on--have tried sevreral times with new fuzes..hasnt been used in months, only used 3-4 times..
every time you put a new fuse you just do more damage to your amp, and by now probably the whole power module is probably fried.
Jun 12, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Hi, I'm having a problem with my new dryer. We got this dryer about a year ago and for some reason in the last couple months, almost every 2 weeks the fuze blows. The dryer turns on but it doesn't...
Makecertain that your wiring is not exposed to anything. Be sure to turn the power off to the dryerand check the outlet. Also check to seeif your dryer cord is connected to the dryer right. Usually the outer prongs on the dryer are thehot and in the inner one is the ground.
May 11, 2011 | Dryers
Fuse box what fuses are for ? what do they protect and do they have anything to do with the coils?
main fuse protect sthe whole system from power surges caused by a bad stator or regulator,then the other fuzes are for lights,horn, and are usually marked. if the main fuze blows it will shut down the ignition to prevent damage to wires,coils, and anything else. your answer, no there is no fuze just for coils,only the main.
Aug 07, 2010 | 1979 Suzuki GS 750 E
Microwave appears to have no power. Display is blank. Checked and found internal fuze blown. Replace the fuze with 20A ceramic fuze. Display works. When try to cook something, microwave runs for about half...
You have a short somewhere. Possible causes, defective interlock switches for the door,shorted capacitor, shorted diode, defective triac. More than likely its one of these.
Oct 01, 2009 | GE Monogram ZE1660SA Microwave Oven
Pb1281x pyramid crystal 2ch mosfet amplifier 1600w what size fuze i got a 20amp in it it blows when i got it terned up
Hello sunshanel,
You did not say what you have the amp connected to and what the impedance load is. It is only stable at 4 ohms and if a lower impedance is connected, say 2 subs in parallel, it would try to produce more power when you turn it up and would most likely blow the fuse. 20 amp sounds right for the amp. The power rating of 800 watts per channel is peak power, not RMS, and many low-end manufacturers tend to state bigger numbers in the ratings.
Hope this helps.
Apr 26, 2009 | Pyramid PB1281X Car Audio Amplifier
Kicker 06ZX750.1 Car Audio Amplifier Logo
53 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
