You need a 15mm wrench. Right pedal is threaded as normal. The left pedal is threaded backwards. (righty loocy lefty tighty.) there should be wrench flats where the pedals go into the crank arms. When istaling new pedals, put some white lithium grease on the threads. Be careful not to hit your knuckles on the ground when it comes undone.
There are so many types
of pedals. I recommend that you'll get a pair that you know and you are
comfortable with. Or you can also check for reviews on pedals and take the ones
with the highest rate. However, you should remember that what's fit some people
will not necessarily fit you...
Check this link: http://www.vitalmtb.com/product/category/Flat-Pedals,20
