Question about HP iPAQ H3670 Pocket PC
Putting Windows back on a h3670
I have an iPAQ 3670 with Opie/Familar (Linux distro based on Debian) on it. I am having a very difficult time getting it to work on the LAN/Internet, even with a CF 802.11b card (USB cradle has very limited success). I would like to put Pocket PC for 2002 on it. How can I acquire PPC2002 and for how much?
4 Suggested Answers
adib
  • 450 Answers
SOURCE: Cannot copy large files to my SD card
Yes , the Activesync connection is not reliable for large files. You really would be best to get a USB card reader, also it would be MUCH, MUCH faster.
Posted on Sep 11, 2005
pingping
  • 111 Answers
SOURCE: Detect camera in Hp Ipaq hw6515 PPC
I have been working on Camera cell phones and see these kinds of issues. I am afraid that your camera interface was bad and the phone main board is not recognize the connected camera. I don;t think this is a software isue when it error message said connect the camera or reset pc.. If you are not think my suggestion is correct, you may try the other way by flashing the ROM as updating the new ROM version, it may also hlep to solve this issue and if it is still not, then I am sure th efaulty is from your camera. This is an comment issue in most camera phones I have been fixed before. I hope it help.
Posted on Mar 30, 2007
  • 6 Answers
SOURCE: My HP iPAQ hx4700 Pocket PC will not start up. It
Slider switches ok and pointing at the right place in the bottom?
1. Main battery possibly needs replacing.
2. Replace backup battery..
http://www.youtube.com/watch?v=cYwc_-ISnsA
Posted on Aug 31, 2009
  • 36 Answers
SOURCE: Tried to update iPAQ ROM, iPAQ died in middle of Install. Help!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1.) Make sure battery is charged
2.) Locate the rom you want to use
3.) Remove machine fro cradle
4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
5.) Make sure your USB connection to the Cradle is hooked-up.
6.) Place your PDA in the USB Cradle.
7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
8.) Highlight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from your Vendor in step 3.
10.) The PDA should now begin Flashing the iPAQ's ROM BIOS.
Posted on Jan 22, 2010
0 characters
1 Points
Online with a Compaq iPAQ H3835 Pocket PC
The 3835 did not have WiFi capability so you can't get online. Probably not worth messing with unless you're a real techie. I think there is a distro of Linux that can run on it if you want to play with that.
Nov 08, 2009 | Compaq iPAQ H3830
Hi. I've been given an Ipaq 3670, but have no user manual for it. Is there anywhere I can download one from, or can anyone tell me how I can get hold of one? Is there a way to upgrade it? Thanks
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=215348&prodSeriesId=96479
Get your manual HERE
Apr 25, 2009 | Compaq iPAQ H3650 Pocket PC
Installation of softwares
i hope the ipaq is a windows based mobile, or what is also known as pocket PC. If am right, then it will not support .exe applications. Google your requirements specifying that your's is a Windows based mobile..
please revert back for clarifications..
Jan 30, 2009 | HP iPAQ H6340 Pocket PC
I can't configer net in linux
What's the name of the linux you have? I used to have a GRPS modem from sprint that I got to work but I got it working with Ubuntu/Debian. There are a lot of PPP programs out there for Linux. All of them that I know about are free. In most distributions, if you look up PPP in the place where you can download programs, it will have a free PPP program to download. If you have one of the major distros like Ubuntu or Fedora, there should be a program named symantic where you can automatically install software for your computer. If you don't know what I'm talking about, be sure to write me back and tell me what the name of your linux is and I will be able to walk you through.
Dec 03, 2008 | Motorola Mobility A1200
Upgrade to windows mobile 5.0
1 answer - 2 links:
http://blogs.msdn.com/windowsmobile/archive/2005/10/06/477999.aspx
http://handhelds.org/moin/moin.cgi/HpIpaqRX3715
Aug 04, 2008 | HP iPAQ RX3715 Pocket PC
Hp iPAQ h1945 won't start
Hello and sorry for the delay.
the h1945 series is a very intresting pda. I have seen all sorts of problems relating this one. There are some things you may want to try. Based on that knoledge I may be able to find what's rong with your unit.
First, check if the back cover fits tight on the back of the unit. It's important because on some ipaq models, there is a small micro-contact that doesn't allow the unit to power on if the back cover isn't attached. I'm not sure if the 1945 has one, it's been 2 years since i've last phisically repaired one of these, but you may look for one yourself. It's a small contact near one side of the back opening, check to see if it can be pressed. If you don't have anything like this just ignore this tip.
Second, leave the pda connected to the charger for about 6 hours. Even if it doesn't do anything. Then try to start the bootloader by pressing the 2 outer keys near the D pad (simillar to the hard reset procedure) then, while keeping those pressed, press the power button and in the same time press the soft reset button with your stylus. You must do this with your charger connected to the pda. It may be difficult to achieve in the first try. Just try to do this a few times and if the pda doesn't respond even now, please post back. Furthermore, if you need more info about these 2 tips please reply.
Mar 21, 2008 | HP iPAQ H1945 Pocket PC
How to change the backup battery of ipaq 1940?
http://www.pdasmart.com/products/19927ipaqparts1900.htm
This PDA is relatively difficult to take apart. I've done it myself and it was very difficult. It is not recommended by any means because you can seriously mess up your ipaq by taking it apart. On the site I gave you after you buy and receive the replacement backup battery, if you do it yourself, will give you a site to get instructions from. You can also send it in to have it done professionally.
Nov 01, 2007 | HP iPAQ H1940 Pocket PC
Doesn't start up
Hi, Based on your post/description, your iPaq 2210 will not power on. It is possible that your battery is deactivated. To reactivate, plug it to the AC power supply/adaptor, press reset at the back of the unit. Assuming no other problem, the unit will initialize back to default factory settings. It's very likely that all your previous/personal settings, files and applications will be also gone. Good luck and pls post back how things turn up. Kind regards.
Jul 21, 2007 | HP iPAQ H2210 Pocket PC
Ipaq windows mobile 2003 upgrade
This is a VERY general question. There are many many software upgrades for the ipaq rx3715.
If you mean upgrading the OS, then nothing short of Linux is available.
Otherwise, please ask a more specific question.
Jul 12, 2006 | HP iPAQ RX3715 Pocket PC
Using Axim with Linux?
I think the official answer from Dell is that Linux is not supported (as they don't include a conduit for it)....though I have a feeling it can be done.... As for running Linux on the Axim, there hasn't been anything developed yet. Chances are most of the stuff for running Linux on the iPAQ would work for the Axim, though there would have to be some tweaking to account for the hardware variance.
Sep 14, 2005 | Dell Axim X5 Pocket PC
HP iPAQ H3670 Pocket PC Logo
20 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
ka4iup
ka4iup
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
