Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
My brush assembly fell off!
It won't snap in anymore, I can place the floormate over the brushes and they will spin but as soon as I pick it up, it just falls out
    Problem Solver:
  • 10 Answers
They lock into that blue arm with the two holes in it. The erm is plastic and has the spring loaded latches that hold the brushes in. If the latches have failed the brushes won;t stay in. The other option is the latch pins on the brushes have brocken or worn out. Turn the machine over and try to make the brushes latch, also push the brush release buttons several time to make sure they are working. Good-luck.
Kirk Thompson
San Juan,PR
Posted on Oct 29, 2008
The brush part doesn't spin anymore. I checked it and a little blk rubber piece fell out
For the brush to stop spinning, this suggests the belt has snapped or come off the motor. The little black rubber piece which fell out may be the remains of a chewed up belt. I suggest checking the belt is where it should be, may be hidden under a removable cover, and that it is stretched round the motor spindle.
Oct 17, 2014 | Vacuums
Why are the brushes not spinning?
Hi Liz, if your brushes are still in good shape and do not need replacing then I would see if something else isn't broken or busted. You can always check for an obstruction in the brushes or remove the brush assembly & then reseat the brush assembly. Before doing so you should remove both Tanks from your Hoover. Then there are two buttons on top of the Nozzle Assembly that holds the brushes. You will need to release these two buttons on top, then tilt the handle of the unit backwards and this should let the brush assemble fall out of place. Inspect the brush assembly for any obstruction and even check to see if all the brushes still spin okay. If all looks good then align the post on top of the brush assembly with the hole on the bottom of the nozzle assembly and then snap the brush assembly back into place. I know this might sound crazy but did you first check to make sure that you did not have the switch set to "Wet\Dry Pickup." This will stop the brushes from turning as the switch needs to be in the other position to turn.
Aug 11, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
How do you change the scrub heads on a Floormate SpinScrub 500?
Hey there! To change out your brush heads simply follow the instructions below.
1. Remove the nozzle by pulling the two nozzle release buttons.
2. Tilt cleaner back so handle rests on floor.
3. Push two brush release buttons and remove the brush assembly.
4. To replace brushes align post on brush block with hole on bottom of cleaner. Turn brushes slightly until post fits easily into hole. Press brush assembly firmly to snap into place.
Hope this helps!
Jul 05, 2014 | Hoover H3030 FloorMate SpinScrub 500...
Spin brush will not spin. local repair man said one gear stripped and motor would need replacement. is this correct??
There is a plastic rod that sticks out of the back of the spin brush, this makes all of the brushes rotate. The motor would need to be replaced if it was not turning on anymore. this doesn't sound right...?
I think it is just a broken piece of plastic on the block brush which will need to be replaced.
You can find a schematic and the parts you need on this link
H3000 Link
http://www.usavacuum.com/category-s/85.htm
Feb 02, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
The brushes are not spinning at all. I have checked them and they are snapped in securely. It was working fine last time I used the machine. I have cleaned them and they spin manually just fine.
you probably got a piece of foreign material jambed in there for a moment and it "smoked the belt" that spins the brushes,it will either have the belt on either side of the brush housing cylinder or like kirby vacs the belts around the cylinder and if broken it will be hanging there.good luck
Jul 10, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Steam Vac with Clean Surge model #F50905-900
All you need for your item is the belt.dissassemble the unit and you will se the track where the belt was, or even the old ne snapped an trapped somewhere inside. brush assembly purchase will not solve this.
update me about your progress.
Good luck
Jun 24, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes won't spin on FloorMate
you need to replace the belt or make sure the brushes are locked into place.
Jun 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Floormate will not **** dirty water.
Check the hose coming out of the floor assembly. It tends to split, keeping it from picking up the water
Apr 20, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Brushes stop spinning after one minute
Check any filters that may be clogged, try running a mix of water and vinegar thru it, to clean out the lines and brush block. Brush block may be bad.
Apr 23, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
170 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
