Question about Tappan TGF320 Gas Kitchen Range
Tappan gas stove
When i turn it on the pilot lite comes on and then you smell gas and no heat even if you let it sit for a while?
  • 943 Answers
Yes the igniter can come on telling you its ok but these igniters break down they light up but not hot enough to ignite the gas replace the igniter thankstheappliance doc
Posted on Sep 16, 2008
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
Turn oven on and smell gas will not light
I had the same problem when I bought a house with a gas range. If you wait ten seconds or more there is a unit that heats up and ignites the range instead of a pilot. You will hear a click every few seconds then while it ignites the stove. I was afraid to wait because I smelled the gas. But after paying someone $100 for a service call that is what happened.
It is electrical and in the back of my stove there is a cord that goes in the wall. make sure it is plugged in. It also affects the burners however they have a light option on the dial, the oven does not.
Hope that helps.
May 31, 2009 | Tappan TGF320 Gas Kitchen Range
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
OVEN PILOT WENT OUT
hopefully the gas smell isn't too strong and posing a hazard to you. If it is, reach behind the range and turn the valve until it is across the gas line and not parallel to it. You should be able to raise the top of the range from the front and see all the workings underneath. There you will find the pilot light.
Feb 14, 2009 | Tappan 24 in. Freestanding Gas Range...
Oven won't lite
you have a bad ignitor. it may light up a little but it is not getting hot enough to light the gas. replace the ignitor
Nov 27, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Smell gas no heat
hi thanks for the question yes this problem is very popular in gas ovens even though theigniter lights up its not hot enough to ignite the gas and also with this problem it wont reach the set tempeture thanks the appliance doc
Aug 29, 2008 | Tappan TGF320 Gas Kitchen Range
Oven gas
For safety purposes call gas technician to check your gas pipe. If stove turn off supposed not to smell gas.
Jul 23, 2008 | Frigidaire FGB24S5A Gas Single Oven
Tappan Stove 5 burner with Oven
does the pilot seem low?you can remove the pilot then clean it out,let me know.
Nov 10, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
139 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
