Question about HP Computers & Internet
My computer is having problems loading up I just cleaned all the dust inside it and rebooted it with the original software but things keep popping up.Like software is not installed right. What should I do
    Brigadier General:
  • 5,158 Answers
When you were in there cleaning... check to make sure you didn't unhook anything.
Posted on Aug 29, 2008
Unfortunately the process with google.process.gapps has stopped
FIXED ! Well almost... This problem is appening with the 'old' Android devices; Software if changing every day and most of the updates are barely tested on all devices and Android versions. The spyware, malaware, adware, are then becoming day after day more aggresive and sophisticated. So, the clean solution if format/clean/reinstall Original software, no updates.
Another helpful hint is clean all software cache, saved data, for each application , one by one, and then...
install Avast antivirus free and block behaviours, "APP LOCKING" option, at least of "Play Store" and "Downloads".
You won't see anymore the annoying message, and device will work like a charm.
Thank you, Bye. FIXED !
Apr 23, 2014 | Tablets & eReaders
I have to hold the start button in in order to keep it running
The switch might be faulty also could be dust clean your computer of all dust .
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Have a close look at the power switch for secure dust free connections you might even remove the switch to have a close look the replace it sometimes just cleaning and replacing things to there original positions gets them working again
Jan 07, 2013 | Computers & Internet
My computer runs window 7 and it keeps shutting down for no reason and also it keeps freezes for sometime.
Reboot the computer in "Safe" mode and run it for a while and see if the same problems occur. If it doesn't, then I would suspect it is a software and not a hardware problem.
If you think it is a software problem, reboot the computer into safe mode again. Now click the start button and in the search box type MSCONFIG
When the window pops up click the "Selective Startup" button and then on the startup tab. Deselect all the checked boxes, click apply and ok, reboot the computer normally.
Now only the essential services will load and no programs will automatically load. If the computer continues to run normally, then you can go back into MSCONFIG go to the strat tab and start checking a few boxes to start again, like antivirus and malware first. Reboot the computer and see if it freezes with those programs running....if it does then you know one of those is the culprit, if not click a few more on and reboot until you find the trouble software.
Jul 01, 2010 | Computers & Internet
Fatalerror message keeps popping up that printer hasnt loaded aaa
Completely uninstall the software then reboot and reinstall. This message is usually the result of a failed or incomplete install, and while it won't affect the drivers, it WILL affect the additional software bundled with the printer. Remember to reboot.
Mar 07, 2010 | Computers & Internet
My Gateway GT4010 PC keeps rebooting itself before
Try replacing the hard drive cable. If that doesn't fix the problem, then you may have bad RAM, bad motherboard or a bad power supply. Sounds like a hardware issue and not software. try booting your computer in safe mode since it doesn't load all the device drivers. If it still reboots then you'll have to keep swapping parts and booting up the computer to isolate the problem.
Oct 06, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Have you run an Anti Virus scan?
Goto Task manager.
From there you can see what processes are running. Norton and Symatec will hog your resources.. End the process that is causing the problem.. careful here.. Some of the Microsoft processes are essential for operation..
After you locate the culprit..
Start>Run> msconfig>startup
Disable the program that is causing the problem and reboot..
Sep 11, 2009 | HP Pavilion Elite M9250F Desktop PC
Rebooting a toshiba equium laptop
First thing to do here since the computer has a lot of virus is to clean the computer if you can still oig in to the computer better install some good anti virus and anti malware software like Avast and Malwarebytes that can clean the computer systme for virus and malware and that should fix the problem. But if you cannot log in to teh computer the next thing you can do here is to format the computer so it will be clean and reinstall everything back...
Oct 20, 2008 | Computers & Internet
My computer keeps rebooting after if reaches windows xp logo
I also have this same problem about a constant reboot of computer and what I did is I replace the Power Supply and everything is already working , becauise this problem can be link in failing power supply already...
Hope that helps..............
Oct 05, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
HP product assistant
Contact HP for Care at 1-800-585-2494
Feb 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
Computer reboots
Hi cool,
Is your Computer keeps on recycling from booting and never finish to load your OS?
As far as i know you got a problem with you CPU, your computer processor is overheating inside that's why it keeps your PC recycling it's power.
Try to go to the BIOS setup menu, and go to the cpu temperature and you will that your PC is heating up.
Hope it helps & give you an exact reason.
Feb 10, 2008 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
