Model number d52w27d when turning on tv the powe light will flash about three times but dose not turn tv on
  • 8,617 Answers
You need to replace the flyback, you need flyback number 259296 you can get a replacement at the following link with free installation help so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Posted on Aug 29, 2008
Tv won't turn on. All three lights flash in sequence power heat then bulb. The bulb appears to be in tact.
I will need the model number of the set in order to assist with the issue as the three lights blinking is an error code which would be different based on which model number TV you have.
Oct 30, 2012 | Hitachi Televison & Video
Hitachi Ultravision tv model number: P50S602 When I turn it on the blue power button comes on and the sound comes on for about 2 seconds then the sound turns off and the blue light flashes three times...
Lights flashing is code talk .So call a TV repair guy and ask him good one will tell u what the light code means over phone cause he'll wanna sell u parts or get your business for service .
Jul 12, 2012 | Hitachi P50H401 50 in. Plasma HDTV
When i turn on the tv, it clicks on and the fan fires up for about two seconds then the tv turns off. then the red power light flashes three times, and continues to flash in that sequence. i have a sony...
Did you replaced/ took out lamp from tv to inspect it?
3 times red light flashing shows that lamp cover has not been fixed on tv, lamp cover is first thing that needs to remove to take out lamp from tv.
Please check lamp cover and make sure it is fixed properly on tv.
Thanks.
Mar 28, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Pow lite flashes three times it tries to turn on then shuts down
LED 3 times blinks shows problem with convergence out section in TV and may requires convergence out ICs replacement.
If you are familiar with TV repair and can solder parts on PCB then let me know to provide you more technical info.
Thanks.
Jul 23, 2009 | Panasonic PT-53WX53 53" Rear Projection...
POWER LIGHT FLASHES 3-4 TIMES AND SOUNDS LIKE TRYING TO COME ON B
This will need a capacitor replaced on the power/deflection board. (CP150) This is a very common problem on these sets. Service man will probably charge at least $200
Jul 05, 2009 | Televison & Video
Tv's green light comes on then off three times
Check capacitors cp150 ,114, 120 ,if cp150 is puffed up on top it is bad.2200uf 16v and the other 2 are 220uf 35v.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W27D The Three Blinks of Death
Check 3 capacitors on deflection board cp150,cp111,cp114 most of the time this is the problem 2200uf16v /330 uf 35v /220uf 35v.
Oct 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 65 inch HDTV TV tries to turn on but the light flashes on and off three times (and will try to turn on again after 1-2 minutes) and repeat the flashing on and off three times. Is my favorite TV...
yes what your describing is possibly a flyback which is very inexspensive and easy to fix. But I will need the model number of your RCA to be positive and tell you which flyback you need. So please respond to this same post with the model number and I will provide the proper info so you can repair the set without alot of exspense.
Jul 04, 2008 | RCA Televison & Video
HELP NEEDED!
need to know the model number as I have access to many different screen assemblies and also the 3 flashes is most likely a diagnostic code, so if you post the model number I will be able to help you out with both problems.
Mar 29, 2008 | Televison & Video
Televison & Video Logo
154 people viewed this question
Top Televison & Video Experts
Electro Med Services...
