Question about Refrigerators
Error code hrs is blinking, frig is not running.
  • 1 more comment
  • tbone707 Nov 03, 2008
    I figured that since the ice cream was melting.
    Actually, the main board failed and had to be replaced. It was a snap to do and only cost $100.00 for the part. Beats paying $80.00 for a service call and $100.00 plus for the part.
  • msargent76 Nov 07, 2008
    I have the same problem with my GE Profile Refrigerator. Did the new motherboard solve all your problems?
  • MIchael Nyman Nov 11, 2008
    Light on water/ice dispenser goes out when you press the lever to dispense. All of the digital displays are blank except the hrs is blinking on the custom cool display.
Posted on Nov 03, 2008
    New Friend:
Hrs error in front panel of ge refrigration
Posted on Dec 14, 2012
I Have the same problem the fridg is not running it is making a clicking sound from the main board location and is blinking Hrs. please help.
Posted on Apr 24, 2010
Kitchenaid superba frig.past 2 days high pitched over temp light alarm goes off every few hrs in between reset we cleaned coils temp in freezer seems fine but frig is not please help
May be frozen up or plugged up. Remove all food. Unplug it and open the doors. Leave for 24 hrs. Clean up any water. Clean out the tray underneath. Usually access from the front if you can pop off the trim panel under the doors. Pull it out. Remove the back. Inspect for large amount of debris. Check any cooling fins etc. use a vacuum with a hose to clean it all out. Plug it back in and try it.
Sep 15, 2015 | KitchenAid Superba KSRG25FK Side by Side...
Maytag top load washer lights blink twice and stops working
Probably a error code. Check your Owner's manual, Troubleshooting section. No answer, try MFG customer service.
You may try unplug for several hrs. Black box may reset.
Feb 27, 2015 | Maytag Washing Machines
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Flashing red temp and lamp lights
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 22, 2014 | Dukane 8912 Projector Lamp 200-Watt...
Vs-60703 turns off after couple of hrs
Two common issues with this set, one is bad solder connections that develop with age and the other is a possible Glycol leak which usually just gets gradually worse.
This set MAY have the self check feature, when it shuts off do not unplug it, press menu and input on the front at same time for at least 5 seconds and release both buttons, if it has the self check the power light will blink a two digit error code like 2 blinks, 3 blinks and pause and then repeat the code for a total of 5 times.
Let me know if you find an error code what it is, if you unplug the set it clears the error code and you must wait for it to fail again before repeating the test.
Dec 11, 2012 | Mitsubishi VS-60703 60" Rear Projection...
The tempature on my refrig. panel continues to blink on the frig.side. I have it at the lowest settinng which is 34F. The Freezer has not moved nor is it blinking. The freezer is still holding its temp. ...
The computer has detected an error in the system and needs to be addressed by a Samsung qualified technician. They have a list of error codes that they can figure out what's wrong with the unit.
Jul 18, 2011 | Samsung RS2630SH Side by Side Refrigerator
Does this fridge have auto defrost?
all friges or units like this one are auto defrost . the defrost system on most of todays units are controled by aditive defrost systems . but the do fail . generaly the frig will defrost every 8 hr's of comp run time . . this could be every 8 hrs or every 16 . just depends on how hot it is and how often you get in frig . . mm
Aug 25, 2010 | Kenmore 63222 / 63224 Bottom Freezer...
Frig stopped running.
Maybe over pulling more amps the the GFCI curcuit can handle. Check all the GFCI plug and verify if there are anything else plugged in. Including hair dryers and / or flat irons.
Sep 02, 2009 | LG Heat cool Window Air Conditioner
We left the frig door ajar for 6 hrs, now the frig isn't working but the freezer is... where is the reset button? Thanks!!
Hi, No reset button. Check and make sure the evaporator fan motor inside the freezer is running. While checking that, look and see if there is any frost build up on the rear panelin the freezer. Please let me know if any of these are the case so I can asist you further.
May 23, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
My Shaver battery doesn't fully charged
Hi... I have the same problem, I got my shaver 2 days ago, and it is written that you need to charge it for 4 hrs in the first time and then the light willl start blinking as an indication that the batery is ful !!! I noticed the following :
1- After 15 Mintues the light simply turn off without any blinking !!!
2- The shaver is charged and runs for almost 1 hrs !!!!
Is this is a fault ??? shall I bring back ...
Please answer me what was your case ??
Mar 20, 2008 | Braun Cruzer 3 Electric Shaver
Refrigerators Logo
884 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
