1998 buick regal, no owners manual. Rear turn signals flash quickly, front turn signals not working. If it is a fuse problem which fuse gets replace? Also low coolnt indicator is flashing on dashboard.
Hazard Lamps
The hazard warning switch is part of the turn signal switch. The turn signal switch receives battery voltage at all times through the HAZARD SWITCH Fuse. When the hazard switch is placed in the HAZARD position, battery voltage is applied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher sends a turn signal flasher signal to the turn signal switch. The turn signal switch provides all of the turn lamps and turn indicators with the turn signal flasher signal, simultaneously flashing them on and off.
Turn Signal Lamps
The front turn signal lamps are made up of the front park/turn signal lamps and rear turn signal lamps. The front turn signal lamps flash with the rear turn signal lamps when a turn is initiated using the turn signal/multifunction lever. The turn signals will operate only with the ignition switch in the RUN position and will not operate during hazard flasher operation.
When the ignition is turned to the RUN position, battery voltage is supplied to the TURN SIGNAL Fuse. Battery voltage is then applied through the turn signal fuse circuit to the turn signal switch. When the turn signal switch is placed in the LH or RH position, voltage is supplied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher supplies a turn signal flasher signal to the turn signal switch. With the turn signal switch in the LH or RH position the corresponding turn signal indicator, rear turn signal, and front turn signal receive the turn signal switch signal and will flash. The front turn signals receive the turn signal switch signal from the turn signal switch via the BCM. The turn lamps are permanently grounded.
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column - Tilt.
I would get the owner's manual out of the glove box and look up fuse in the index. That will tell you where the fuse box is and often the turn signal and flasher units are plugged in there. With the signals on I would walk around the car and make sure the bulbs are all good.
replace flasher......usually located in fuse block area...listen in this area....select passenger side ...then select driver side...you can hear flasher clicking...you have seperate flashers for each...FLASHERS are small cubes plugged into fuse block....probable bad driverside flasher
I dealt with a similar problem on an 01 Alero (very similar car) and found that the wire that grounds the signal filament of the bulb was broken inside the harness. I tapped into it and grounded it to the chassis and resolved the problem. It's no guarantee but if you have a multimeter, check each wire's continuity to ground as well as the impedance between each of the wires on the harness, on both front signals (for comparison purposes), and it'll show you if you have a problem such as the one I dealt with.
have the same problem, sounds like you will need to get a new light socket (where the light bulb goes into).... it is a easy fix. cost approx $30-$50 at dealership for part
