Question about HP iPAQ h6315/h6365 Pocket PC
IPaq 6365 WiFi Wont Shut Off
Hello, Evertime I do a soft re-boot, on completion, the WiFi indicator light starts flashing and the Wifi button turns amber (brown). I try to tap the button but it goes grey for a few moments and then back to amber and I cannot turn it off. The only way I can turn it off is if, by chance, I go near a Wifi network, it is then detected and I can then see an "I" antenna at the top of the Today screen - I tap it and I can then tap "turn WiFi off". Is there any other way? I have not installed the Bios update because I am in Australia and it is not one of the countries listed. Appreciate your help.
    Master:
  • 450 Answers
There's a little utility I use (just because it's quicker than the usual iPaq Wireless screen buttons) called WirelessSwitcher. http://www.aspecto-software.com/WiFiFoFum/Utilities.htm Maybe this would do the trick for you.
Posted on Sep 11, 2005
Shut computer down properly
hello my asus dont completely shut either i have to hold down the power button for 10 seconds. i did browes the net for fair while and none of the answers worked for me , i think my problem started after a windows update ????.( wifi stays on)
Apr 23, 2016 | Computers & Internet
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
How do you reset it to factory settings
To perform a soft-reset (if the device has locked), briefly insert the stylus or a paperclip into the reset hole on the bottom left of the 3715
To perform a hard reset (losing all data!), insert the stylus or a paperclip into the reset hole on the bottom left of the 3715 while holding down the far left and far right of the four main buttons. Information in the iPAQ File Store will not be lost, but data on the Internal memory will be wiped.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 30, 2009 | HP iPAQ RX3715 Pocket PC
HP Ipaq 2910 wont finish the boot
Hey :), I'd be happy to help. I honestly don't think that you've physcially damaged your Ipaq, so you should probally hard reset your Ipaq. To do this you must hold down the reset button and the power button at the same time for like 5 seconds. This will get rid of data on your pocket pc, but It might solve your Ipaq's problem. Thanks! and I hope this helps, if it doesn't I'd recommend for you call Hp where they will repair it or give you a new one :)
Sep 01, 2008 | HP iPAQ H2210 Pocket PC
IPAQ 6365 hard reset
I Also Had The Same Problem. Now I Fixed It. Go To Power In Settings. Click On The Advanced Tab. Uncheck The Box Which Says "Turn Off The Device If Not Used For" Box. This Will Solve The Problem. It Solved Mine. Thereafter Once, My Backlight Did Not Switch On. Fix This By Going Into Backlight Settings And Uncheck The Box Which Says "Turn Off The Backlight If Not Used For" Box. This Will Solve It. Then Soft Reset The Device To Change Settings. To Soft Reset, Find A Small Hole In The Left Hand Side Of The Device. Put Your Stylus In And PRESS ONLY ONCE. If You Keep It Pressed, Your Device Will Hard Reset. Don't Do That. Just Press ONCE.
Mar 31, 2008 | HP iPAQ h6315/h6365 Pocket PC
Locked out of my ipaq
  • press and hold the Calendar and WiFi buttons
  • while holding those buttons down, press and hold the reset button for ~2 seconds
  • When the HP iPAQ screen begins to fade, release the Calendar and WiFi buttons first, then remove the stylus from the reset button.
  • Press reset again.  (Or, plug the device into the AC adpater.)
  • The Pda is now hard reset and restored to defaults stored in the rom memory. the password and everything else should be gone and it should work as if you had just opened it for the first time.
    Jan 16, 2008 | HP iPAQ rx1950 Pocket PC
    HP iPAQ 6365
    Please perform following steps.
    Take the back up of data.
    Clean the battery.
    Hardware reset.
    Perform the Hard reset
    1. Press and hold the Answer/Send, Power, and End Call buttons.
    2. While holding these buttons, use the stylus to lightly press the Reset button until the device restarts.
    3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
    Sep 12, 2006 | HP iPAQ h6315/h6365 Pocket PC
    IPAQ 4150 & WiFi
    hi i've never known them not come back on after going off, but have noticed they do switch back on, on their own when the wifi is enabled. when i want mine to stay off i tap the arrows at the top of the screen and select "turn on flight mode" this will then stop the device searching for a network and will shut down. when you want wifi again turn the flight mode of in the same way.
    Sep 08, 2005 | HP iPAQ H4150 Pocket PC
    Ipaq 4705 wont connect to internet
    Try running through this WI-FI setup tutorial, its very helpful. http://wifi.aximsite.com/
    Sep 08, 2005 | HP iPAQ HX4705 Pocket PC
    HP iPAQ hx4700 Pocket PC
    if your PCs connect wireleslly, then I assume you have set up a home network with a router/modem. Sometimes the modem comes combined with a router. If this is the case, then the 4700 has all you need to connect it to this network and access your emails and internet. This is an example of my setup with my 4700... Go to Start > Settings > Connections > Connections > click on Advanced tab at the bottom click on "Select Networks" button Both entries on this page should be set to "My Work Network". Click "OK" > "OK" back to Settings screen. Go back to Today Screen. Now click on the iPaq Wireless icon at bottom right of this screen. If the WiFi button has an 'x' on it then click it to turn it on. A blue light should now come on at the top of your ipaq to indicate that wifi is on. Click on the 'Settings' button You should be able to see your network on this screen - "Configure Wireless Networks" Networks to access should be set to "All Available" Check the box to 'Automatically connect to non-preferred networks' If the Network is available but not connected, then click on it's name. On this next screen you should select next to 'Connects to' - "The Internet" Then click OK If the Network shows 'Available' and not 'Connected' then click and hold on the name of the network and then you can choose 'Connect' Then under 'Network Adapters', on that screen it should say ... My Network card connects to 'Work"
    Sep 07, 2005 | HP iPAQ HX4700 Pocket PC
    HP iPAQ h6315/h6365 Pocket PC Logo
    160 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
