Question about Estate TEDX640JQ Electric Dryer
What part is bad
Heats for one minute then just spins without heat and the timer dosn't move
  • 943 Answers
HI thanks for your question. i would look at the timer between contacs B & C check the timer. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 11, 2008
Does not heat up and timer not working?
send brand name and model number so i can help you,also if it's on time dry it should count down even without heat if you have it on more or less the timer will not move without heat.heat comes on until heater cycles off when the heat is off the timer will advance a little,when the heat comes back on the timer stops advancing,it will do this until the clothes are dry.
Sep 15, 2013 | Dryers
Dryer wont stop buzzing
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
I have a Avanti dryer and after its on a few minutes it also cuts off. Can you tell me why or what to do to fix this problem?
see this causes and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and needs replacing. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub.Replace the Heating Elements
Oct 17, 2012 | Avanti D110 Electric Portable Dryer
Dryer tumbler for a short time then shuts off,will not run a full cycle like it stuck
Timer
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace the Heating Element.
Sep 27, 2012 | Amana ALG331RAW Gas Dryer
It dosn't wash my dishes well
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 25, 2011 | GE 24 in. Profile PDW7800 Built-in...
No heating
Hi maurice852, If it spins and moves air but doesn't heat then it could be a bad thermostat, burnt out heating element, or possibly burnt switch contacts in the timer. Hope this helps.
Please rate my response.
Jan 14, 2011 | Frigidaire Dryers
I have a roper electric dryer model # rex3514pqu. The dryer doesn't heat at all and the timer will not move, it stays where I set it. What could cause this problem?
If you have a TIMED cycle,the timer should advance heat or not. In the AUTO dry cycle the timer will not advance without heat. Unplug the dryer. Remove the rear panel of the dryer and check the heat element, relays and thermostats with a volt meter set for ohms. No reading indicates a bad part. Remember to remove at least one wire from each component before testing.
Nov 03, 2009 | Whirlpool Dryers
No heat, timer not advancing
If the timer advances in timed cycle but not automatic, you have a bad heater thermostat.
Apr 10, 2007 | Kenmore 62622 Electric Dryer
Estate TEDX640JQ Electric Dryer Logo
53 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
