Question about Plumbing
Mixer taps My ceramic disc mixer is very sticky and hard to turn on. What can I do to unstick it?
  • 44 Answers
You didnt mention which side hot or cold?
it sounds like its scaled up & the o ring has dried out so it could be a case of replacing o ring & regreasing. ifits when you turn either hot or cold & its stiff then a replacement cartridge will required
Posted on Dec 15, 2008
Need to replace American Standard A951470-0070A - Cartridge for American Standard # 4242 Chrome Single Control. I need to replace the cartridge but after removing the set screw I can't budge the handle. How do I descale the stuck handle without ruining the finish—I am afraid WD-40 will harm the chrome.
Posted on Jan 25, 2009
Oliveri mixer taps
turn off the hot and cold water supply, place a container under the sink where the hose meets the Sink mixer.
release the pressure from the tap by opening the tap to let the water out.
use a suitable tool to undo the flexible hose from the underside of the tap, there should be a small "O" ring on it which you will have to replace as the "O" ring is possibly the cause of the leak.
Oct 01, 2013 | Home
I have a mixer tap in the kitchen sink. The hot water tap runs fine but I am not getting any cold water. I also have a bath downstairs and the cold water tap there is fine
You will have to turn off your water mains and strip your mixer tap. It is possible that the seal (if it is an older tap with a rubber seal) has become stuck or the threaded part that turns it has gone faulty. If it is a modern tap with ceramic seals, check the operation of the mechanism and see why the ceramic seal is not being opened.
Mar 26, 2011 | Microwave Ovens
Water pressure has dropped off with pressurised water system
hi Peter if you have a mixer tap there are no washers there is a ceramic cartridge in the centre but that should't be the fault
the most common rectification is to undo the airrator which is the filter that the water comes out of and clean any forein matter from it
May 10, 2010 | Grohe Chiara Neu Lavatory Centerset ...
Mixer has come off of stand
It will go back in if you back off the screw that was supposed to lock it in place. Look at the mixer part of the unit and make sure that the pin slides thru the hole. If not then turn the screw ccw a turn of so. Now make sure the pin slides easily thru the two holes in the stand part of the mixer.
Now carefully line up the top and bottom halves - look thru the hole in the stand until you can see the mixer's hole line up, then slide/tap the pin into the hole
Now turn the mixer on its side and look for the screw in the mixer casting. Turn it clockwise until tight and the pin will not come out again . . . . for a longer time hopefully . ..
Mar 22, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
I have mixer taps on my bath, hot water tap doesn't work
you may just have to replace the hot/cold stem
Mar 11, 2010 | Home
Change tap washer
hi first turn of your water to the tap open the taps to empty water your mixer tap con now be pushed down and twisted to come out
Nov 10, 2009 | Home
We have two 16 year old shower faucets (house was built in 1993 by Del Webb). Can't tell what model they are. We are guessing they are Moen Legend 3175 (one handle). Problem seems to be pressure balancing...
This is a common problem with this type of shower mixer valve. They are not very good at regulating with pressure change. Your options are somewhat limited to not flushing the toilet or using any other taps when in use, repalce the mixer valve for a modern ceramic unit or installing a 2 vane hot & cold shower pump.
Nov 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
I have a antique hamilton beach stainless steel stand mixer. there is a date on the bottom of mixer 1938. i uses this mixer at least 3 times a week. it works well and is in mint condition other than...
Use DeBruce Polish. DeBruce will remove the rust and pacify the surface. DeBruce also works great on ceramic cook tops grills, chrome windshields and more. We buy DeBruce Polish at debruce
Mar 06, 2009 | Hamilton Beach 63221 Stand Mixer
Mixer attachment
make sure attachment is turned full counter clockwise to release point give a good tug if doesnt work try a light tapping with a rubber hammer or lobster wooden hammer
Nov 20, 2007 | KitchenAid KSM150PS Artisan Series Stand...
Plumbing Logo
992 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
