Question about HP iPAQ hx2410 Pocket PC
Power Hello, my hxX2410 keeps turning on by itself. Can any one tell my how to set it up not to do this. It keeps runing my battery down.
    Master:
  • 450 Answers
Mike, Most PocketPC's will turn themselves on in certain situations: - A taks reminder is initiated - An apointment reminder is initiated - You syncronise your PDA with your PC These are just a few examples. However the PDA should turn itself off after a given amount of time, unless set to do otherwise. Go to your system settings, power, and change the time in which your device turns off. It may very well be that it's set to never switch off.
Posted on Sep 11, 2005
My phone constantly shuts itself off. Sometimes even after I've logged in and just put it down for a few moments.
My phone keeps turning off by itself. ' Android Forums
androidforums.com > Android Phones > HTC EVO 4G
Sep 22, 2015 - Um my phone keeps turning off by itself. And its really really starting to get annoying. IDK if it was some app or an update. Anyone else having ... Phone Randomly Shuts Down and Battery Level Gone Crazy
Oct 13, 2015
help.my phone keeps turning on and off by itself
May 14, 2015
Self shutting-down/restarting?
Apr 17, 2015
Phone keeps shutting off by itself
Mar 26, 2015
More results from androidforums.com
My Phone Keeps turning off and then turning itself back on ...
https://www.ifixit.com/.../My+Phone+Keeps+turning+off+and+then...
iFixitwhen i turn on my phone and it does its power up, i wait for my service to come on. before the service gets turned on the phone restarts itself everytime. it ...
Cell Phone Keeps Turning Off ' Guaranteed Fix - YouTube
? 3:16
https://www.youtube.com/watch?v=1Rm0L_eh0wY
Oct 15, 2013 - Uploaded by Get My Tips
Does your cell phone keep shutting off? ... http://www.getmytips.com show how to fix any cell phone that is ...
Dec 16, 2015 | Cell Phones
My computer keeps switching itself off and won't swtich back on again? What can be the problem?
Hello
By know you should of fixed the problem .
1. keep the inside cabinet clean.
2.If the unit keeps shutting down by itself after a certain time and it is not dirty inside the cabinet .Also all the intact screens are clean . Check your Personlization settings By right clicking on your screen . then right click Screensaver and then power settings . Then check to make sure all the settings are turned off unless you want the computer to shut down after a certain amount of time
Oct 30, 2012 | LG Computers & Internet
Computer powers up by its self when first plugged in
Most BIOSes have a setting for what to do after a power failure--stay off, turn on, resume last state. If the user is unplugging the unit before a total legal and proper shutdown, then that might explain why it turns on 'when plugged in'. Disconnecting before completely shut down is detected by the BIOS as a power failure.
Also, killing power to a running system can cause file table corruption, corrupt files, a destroyed operating system, even in rare cases a total loss of everything on the disk.Although, If you mean the computer turns on by its self after it's been turned off (so he unplugs it to keep it from powering on), then it might be "auto awake" settings in the bios, I've seen some bios' have "auto-power on" settings so that signals from network cards or peripherals can power the computer up.
Also It turns out the CMOS battery went out and that probably reset the BIOS so the computer itself was set to turn on by itself when it was plugged in. With a new CMOS battery and a quick setting change the computer is ready to go.
Dec 27, 2010 | Gateway 310 S PC Desktop
ON and off itself every few seconds.
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive HV were detected.
Take Care.....
May 21, 2010 | Toshiba 52HMX84 52" Rear Projection...
My RCA 32V550TYX1 turns itself off and on - flickers. The only way to stop it is to unplug the set. Any ideas?
Hello, The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
May 19, 2010 | RCA 32V550T 32" TV
Hello, My PS3 just keeps turning itself off. I have tried to reset the system but it keeps flashing red and yellow lights and then turns itself off into standby mode? HELP......
Try removing the game inside your disc. then try removing other external hardware and slots and try again. If problem persists it might be a system problem. Please go to the shp from where you bought it and ask them for a replacement.
May 16, 2010 | Sony Playstation 3 (PS3) Console
Phone keeps turning off and on by itself
hello try restoring the phone to the default factory settings
if this doesnt work, get a new battery
Mar 20, 2010 | Samsung SGH 600 Cellular Phone
My nikon coolpix s570 keeps giving me a waring that says "battery temperature too high" and the camera won't even turn on
The camera will turn itself off if it thinks the battery is too hot.
The manual just says to turn the camera off and allow the battery to cool down.
It is not right for this to keep happening.
If possible I would return the camer to the store and tell them about it, it may need a repair.
You may like to see if it is better with another battery.
Hope this help a bit.
Mar 05, 2010 | Nikon COOLPIX S570 Digital Camera
Turning On and Off
Is your panel actually powering down or is the back light going on and off? That would be a more serious issue but let's try the simplest thing first. Make sure your Remotes Power button isnt stuck down. I have seen this happen before and it will just keep sending out power commands toggling the set On and Off.
Take the batteries out of the remote and see if it continues to do that. Sometimes the button pads get stuck down.
Jan 06, 2010 | Fujitsu Televison & Video
Mustek DV-3500 DV Digital Camcorder /keeps turning off
Be sure the batteries are not the rechargeable types.  I had this problem when I first got my camera about 4 years ago.  Also, try adjusting the quality settings for the functions.  For example, set the photo function at normal rather than fine.
Dec 14, 2006 | Mustek DV-3500 DV Digital Camcorder
HP iPAQ hx2410 Pocket PC Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
