Question about Sony Playstation 3 (PS3) Console
Playstation3 problem Hi...I'm doing an update on playstation3 but it's not obtaining my IP address for some reason. Do you know why?
    Problem Solver:
  • 37 Answers
PS3, The amazing device by sony also has some common problems like Xbox and Wii have. But good news is that these all problems can be repaired with the help of many DIY Guides, one such guide available at PS3 Repair Blog
Posted on Feb 27, 2009
Can the management IP address of an ONT be configured?
ONT management IP addresses are classified as LAN-side management IP addresses and WAN-side IP addresses.
· The LAN-side management IP address can be configured. To do so, choose LAN > LAN Host Configuration from the main menu on the web page.
· The WAN-side management IP address is based on WAN port configurations.
§ If the WAN port statically obtains an IP address, the WAN-side management IP address can be configured. Ensure that the configured management IP address can communicate with the upper-layer device.
§ If the WAN port obtains an IP address in DHCP or PPPoE mode, the WAN-side management IP address can only be obtained from the DHCP server.
May 16, 2016 | Computers & Internet
My hp mini will not obtain any ip addresses and i don't know what to do. i need help fast!
hi ' it does need to set it as obtain , but if you want to create an IP address click start botton-click control panel-click my network connection open network connection then right click - --- -- then click properties then type the address what you want then click sub mask and press apply/ok.
Jul 12, 2011 | HP Mini 1010NR Notebook
Buffalo router setup
You have to change the DNS servers on your PC's internet connection.
Instead of using DHCP, type in the two IP addresses from your account at dydns.com.. Right click on your connection icon and choose, "properties".. In the panel presented, choose Internet Protocol (TCP/IP) the last item in the panel. Next click 'properties' and remove the dot from "obtain IP automatically". Next, type in your new DNS server IP's. The top panel is for you PC address which has to be between 192.168.1.2 and 192.168.1.224. It doesn't matter what IP you choose as long as it is not an address used by another device). The subnet mask will fill itself in. Default gateway is 192.168.1.1. In the bottom panel fill in your new IP's. That's it.
Apr 13, 2010 | Buffalo Technology AirStation Nfiniti...
My playstation3 is able to obtain the I.P address but is unable to connect to the internet. why is this happening?
check the rj cable
check the router for the internet connection
check u give right D>N>S address in connection settings
or just click automatic detect
Mar 15, 2010 | Sony Playstation 3 (PS3) Console
2 Pc's with same IP
AT either desktop or laptop:
[Start]
[Run]
[cmd]
A dark "DOS" windows will appear
At the prompt, type: ipconfig
press [ENTER]
Note the "IP Address" (probably 192.168.1.2)
type: ipconfig /renew
press [ENTER]
Note the IP Address
If it has changed, then you are ok. Type: exit and press [ENTER]
If it did not change, then try this on the other computer.
If that didn't change either, the go to the Control Panel
[Network Settings]
Find the wireless or wired network adapter and Right-Click
Choose "Prpoerties"
In the Properties window, double-click "IP Address"
See the IP Address assigned? change the last digit by one number.
Example: if the IP Address is 192.168.1.2 then change to 192.168.1.3
[OK] [OK][OK]
It should work now...
Let us know!
Sep 17, 2009 | Linksys Wireless-G WRT54G Router
PHYSICAL IP ADDRESS NOT RECOGNIZED, IT JUST SAYS FF-FF-FF-FF, AND DOESN´T RECOGNIZED THE IP ADDFRESS FOR THE INTERNET CONNECTION?? PLEASE HELP, DO I HAVE TO FORMAT MY COMPUTER OR I JUST NEED A DRIVER?
Update the O/S first
Check the connection is DHCP
control panel,network connections, right click your connection to the internet, properties,
TCP/IP VER4, highlight this in grey, click properties,
should be set to
( obtain I.P. automatically ) tick this box.save it.
Reboot the system.
hope this helps
Regards
Apr 19, 2009 | Toshiba Tecra M2V-S310 Notebook
Playstation3 can,t pickup ip address
If you have your internet to your computer and the PS3 you need a router to provide an IP for both. Otherwise your ISP will only provide an IP for what ever was hooked up first most of the time. If this is the case try only the PS3 and do the auto setup. Linksys is a simple router with great support. If there is already a router hooked up please clarify.
Mar 21, 2009 | A.L.S. Industries Messenger Bag for...
TRENDnet TEW-432BRP router cannot obtain IP through DHCP
it seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
Mar 19, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
No ip address
when you say ip/config you mean wifi properties and internet protocol properties right ?
if so select obtain ip address auto and select obtain dns auto.
if thats not what you mean...goto control panel ..open network connections...click on ur network connection ...in the list at left select change settings for this connection...in network properties scroll to internet protocol..double click to open..select obtain ip auto and obtain dns auto.
there are other ways to fill in fields but you need relevant info..
there are programs which can show u ip's but most require a special driver.
incidently if you choose ip and dns auto you will not see ip address but when connecting to network you will see aquiring ip address please wait.
if for some reason you still cant connect go to a place where you know have free internet access and connect there then net connection will be configured
Jan 25, 2009 | Computers & Internet
Internet Exporer
"Obtain ip address automatically" indicates that it will use DHCP. DHCP will also provide the Internet Gateway address, which is required to access anything outside your local subnet (like the internet). You can set your IP address manually, but you also have to enter the Internet Gateway and DNS server addresses ( and you have to know what those addresses should be for your pc ).
Feb 17, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
113 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
