Question about Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C)
Notebook wireless adapterwpc54gs ver 2 has been working fine, but is now inactive
Has been working fine, but is now inactive
  • niffer1 Aug 30, 2008
    Perfect answer. The device was disabled, and was easily enabled. Thanks so much.
  • 39 Answers
Try going into device manager and finding it in the list and making sure it is enabled and then go into device properties and click update driver
Posted on Aug 30, 2008
After adding ddr3 to my samsung rv511 its not starting
Hi!
I just got my Samsung RV511 laptop up and running with OS X 10.6.8.
The specs of my laptop:
Intel HM55 Sandy Bridge
Intel Core i3 2.53 GHz
4 GB DDR3
Nvidia Geforce 315M 512MB
Currently I've got ethernet, QE/CI, Bluetooth, Integrated Webcam, Trackpad with 2 finger scrolling, keyboard, Sound and HDMI with Audio working.
For people who want to try it, this is how i installed it.
  • Change the ACHI settings in bios to "Manual" and "Enabled", as having it on auto won't work.
  • Install OSX using iBoot
  • Update to 10.6.8 using the Combo Update
  • Install MultiBeast, List of drivers to select below
Multi Beast:
EasyBeast Install
System Utilities
Drivers & Bootloaders -> Kext & Enablers -> Audio -> Universal -> VoodooHDA 0.2.1 (Newer version WON'T work)
Drivers & Bootloaders -> Kext & Enablers -> Miscellaneous -> VoodooPS/2 Controller
Drivers & Bootloaders -> Kext & Enablers -> Miscellaneous -> VoodooPS/2 Trackpad
Drivers & Bootloaders -> Kext & Enablers -> Network -> Lnx2Mac's Realtek RTL81xx Ether...
Some issues when i installed, with the fix:
After entering sleepmode, system won't boot "Still waiting for root device"
After i've entered sleep mode and forced shutdown the computer, the BIOS settings are reverted to ACHI auto. Change it back to Manual and Auto. The sleepfile is still laying somewhere not making it to boot, use the boot flag Wake=n to get it back running.
Can't boot using iBoot after the first boot.
Boot using the parameters -x -v and it should boot up fine.
Things that needs to be fixed:
However, the "tapping" of the trackpad is not working, so i need to press the button to click on a link, open a program etc.
The F5 key is not working on the keyboard, but the F12 for Dashboard and the special FN keys are indeed working.
Sleep is not working at all, the screen gets black and then im stuck.
Wireless is not working either, tried adding the IO80211Family kext but when i copy it to the extensions folder, i get an error message saying that the kexts we're not installed successfully.
I have details from CPU-ID Cpu-z from Windows 7 which should tell the PCI-ID etc. Of the Wireless card, however i can't really find the maker and model of my wireless card.
It seems like they got it with 3 different types of Wireless cards. This is from the driver download section from Samsung:
Wireless LAN,BROADCOM (Driver) (ver.5.100.82.95)
Wireless LAN,ATHEROS (Driver) (ver.9.2.0.439)
Wireless LAN,INTEL (Driver) (ver.14.1.1.3)
Is there any way to figure out the make/model from the cpu-z specs?
Any help would be really appreciated!
Jan 21, 2013 | Samsung RV511A01 Notebook
Card is inactive
You might want to make sure that your wireless adapter is enabled. Depending on what operating system you will need to go into your network connections area and enable it.If you have a laptop make sure that the switch has been turned on. It is usually located on the front side of the laptop.
Jul 24, 2010 | Linksys WPC54GS Wireless Adapter
Where do i fine the software for my laptop
I have found the Linksys site very good for finding the drivers and instructions for it's products.
May 26, 2010 | Linksys WPC54G Wireless-G Notebook Adapter...
How can i connect to enternet f i have a linksys wireless g notebook adapter with model no. WPC54g ver. 2
hi
this is a connector to the laptop and now you'll need a source...
a source can be a service provider with wireless connection or a free hotspots or
a home based wired internet connection with wireless router
if you have a wireless router then you may have to call the ISP for the DNS server settings if any required but for others i think the auto IP configuration settings should work fine
cheers
pls rate if this was any help
Jul 07, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Fn+F8 hotkey dose not work but the remain FX go fine
Another Alternative is to check your BIOS to see whether or not your Wireless is turned on, if it is not pressent in your BIOS then update your BIOS Driver on the Internet to ver 1.4, Double check your version Compatabillity. Next if the adapter driver is installed, follow the following intructions: start -> settings -> control panel -> system -> hardware -> device manager -> now look for the wireless adapter, see if it is operational or marked with an error -> if it is marked check that it is configured for automatic, and also the resources. Set the configuration manually if so. restart the system.
1) Resource conflict = change resource settings
2) No adapter = check if the adapter is enabled (Y) then see if there is any conflicts (y) correct the settings e.g. resources and see if windows shows that the device is enabled (N) try to enable this device. If (N) then goto BIOS settings to correct it.
Hope this helps
May 24, 2009 | Toshiba Tecra M6-EZ6611 Notebook
Pcmcia slot nor recognizing wireless card
there is no sopport for anything under windows xp now
if your to get it to work you have to go to linksys and download the drivers for your operating system (if they still exist)
Mar 21, 2009 | Panasonic Toughbook 72 Notebook
WPC54Gv3 is inactive
El control de SM-IR es para la transferencia infrarroja. Este no tiene que ver con inalámbrico excepto la utilización de 1 dispositivo IR al otro. ¿Es puesto en una lista su dispositivo inalámbrico en el Hardware / el gerente de dispositivo / bajo el adaptador de red?
Sorry about translation as I haven't done Spanish in 40 years.
Mar 21, 2008 | Compaq Armada M700 Notebook
Open Questions:
Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C) Logo
228 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
