Question about HP iPAQ HX2415 Pocket PC
How to get a CD-ROM program to run?
Hi there! does anyone know how to get a CD-ROM program to run on the iPAQ?...
  • 102 Answers
It depends if the Autorun file has an executable that can run on iPAQ !! Then you should share the CD-ROM (if the exe file works on iPAQ Platforms) then run the CD-Rom from the share resource.
Posted on Mar 29, 2007
    Master:
  • 450 Answers
You're probably going to have to set up an ActiveSync connection between your PC and your 2415, then run the program installer on your PC while you're connected to the iPaq.
Posted on Sep 11, 2005
SOURCE:
Purchased but language and cd rom is in german
hi all you need to do is go to the person how selt you the phone and change lanuages
Dec 25, 2009 | HP iPAQ HX2490 Pocket PC
Change from Spanish to English?
You will need to download the english rom and flash the phone. It can be found here.
Mar 17, 2009 | HP iPAQ H2210 Pocket PC
Not Loading Up
You may be in need for a ROM update/reinstall. It is pretty easy to do that. You can either go at HP's web site and download a ROM update for your specific model. Make shure you select your operating sistem rigt. Or you can browse the internet for a specific ROM update for your model. I recomand the HP site, and if you have problems regarding the ROM update process, or the ROM and OS version you need, please reply here and I'll guide you throught. Good luck.
Jan 18, 2007 | HP iPAQ H4150 Pocket PC
Some programs not running
Take a look at this similar post - http://www.fixya.com/problems-solutions/t115221,p477250/HP-iPAQ-hx4700-Pocket-PC.aspx Let us know if you resolved your problem Good luck
Jun 27, 2006 | HP iPAQ HX4700 Pocket PC
Outlook 2002 Reinstallation
The default e-mail client on pocketPC 2003 is the "inbox" which is merly a utility for retreiving & sending e-mail. There is no "outlook 2002" on pocket PC's. The Outlook 2002 installation cd comes with most iPaqs and is intended for your pc, not your ipaq.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Data erased from iPAQ hx4700
If an ipaq loses power , then all data in RAM is lost. It's important to keep it charged. It's also important to do regular backups..... so there are two backup options - one is thru Activesync which will backup to your PC and one is the IPAQ's own backup program which will backup to the IPAQ FILE STORE (area in ROM) or a SD card. I do the Activesync backup every time I sync and then the IPAQ backup about once a week or immediately before a system change. Activesync backup ------------------------ Here is a guide which best explains it http://www.cewindows.net/faqs/activesync/backup.htm this guide suggests doing a full backup, but it's fine to do an incremental backup each sync - this means that only changes will be added to your backup and makes the whole process much quicker. IPAQ Backup ----------------- So under Programs is a program called IPAQ Backup. The default location is IPAQ FILE STORE which is an area in ROM and is not lost thru a power failure nor hard reset. You may also choos to backup to a SD card - a full backup will need roughly 20MB. So in this backup procedure, if you click on 'Browse' you can choose a SD card. A restore can then be performed from the IPAQ FILE STORE or SD card (depending on which location you chose) and so if you are away from your PC, this will be no problem. A restore this way , rather than thru Activesync is also much quicker, so if you have a choice go this route.
Increasing Memory
The bad news is that many of the programs you might like to do away with are built into the ROM, and can't be deleted. The good news is that most programs will run perfectly well if installed on the storage card, so if you've got programs installed in main memory, you can realize some savings by running them from the storage card instead.. If you go that route, be sure to Remove the program from main memory and then re-install it to the storage card.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ HX2415 Pocket PC Logo
125 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
