Question about Dell E172FP 17" LCD Flat Panel Monitor
DONTKNOW WHAT TO DO
I SEEM TO HAVE A PROBLEM WITH MY MONITOR IF I TURN THE SCREEN POWER BUTTON TO ON IT BLINKS (GREEN)AND CONTINUES TO BLINK EVEN AFTER I TURN THE COMPUTER ON I LEAVE IT TO SEE IF IT WILL EVER STAY SOLID BUT IT DOESNT. I PLUG A DIFFERENT MONITOR IN AND THE MONITOR WORKS FINE.
  • 4 Answers
Check transisters Q759, Q760, Q739, Q740. They commonly short out. Do a google search on how to check transisters. You must unsolder them from the power supply
Posted on Sep 12, 2008
  • 114 Answers
Your monitor need repair. Sounds like a power supply problem. The power supply is shutting down due to an overload.
Lou
Posted on Aug 29, 2008
Intex 14
Not even any error message? Do you still see the logo of the manufacturer when you press on the power button?
Jul 06, 2013 | Computers & Internet
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
We get a blinking green light response where the ''On'' button is on our Compac presario SR 1111 NX and cannot get the computer to turn on. Is this a battery problem of some sort? Can I fix it? The...
take out all the cables from the back of computer,press the power button for 1 min and then plug in only keyboard,mouse,monitor and power ,it will work
Feb 09, 2010 | Computers & Internet
Dell 1704 FPt lcd monitor power button blinking green, no screen.
the only thing you can do, is to get a qualified service technician if you are not an electronic expert. because the problem is in your power supply and inverter board. due to heat pressure inside can damage components specially capacitors.
Aug 15, 2009 | Dell 1704FP LCD Monitor
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
Moniter won't turn on/power light blinks green
Yeah, I called Dell yesterday, and they said it was a problem that I could not fix myself. Whether that's true or not, I don't know, but my monitor was still under warranty, so they shipped me a replacement right away. I already got it this morning.
FYI: Their monitors carry a three year warranty.
Oct 28, 2008 | Dell E176FP 17" LCD Monitor
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
Dell E173FP 17" Monitor
I just had the same problem as well - mine happened during a windows update, related? Also, for me the monitor doesn't come one even after disconnecting from computer, nothing, just blinking green light.
Nov 04, 2007 | Dell E173FP 17" LCD Monitor
17" veiwsonic power blinking green
The flashing green power button is a well known electronic problem with this (and other) Viewsonic LCD monitors. There is a YouTube video (do a search) showing how to disassemble the VX924 and find out whether the problem is related to blown capacitors. When I took my VX922 apart I discovered 6 bad capacitors out of a total of 7 on the power supply circuit board.Only recommended for those handy with a soldering iron.
Jul 28, 2007 | ViewSonic VX922 19" Monitor Flat Panel
Dell E172FP 17" LCD Flat Panel Monitor Logo
102 people viewed this question
Alun Cox
