Question about Sony KP-57WS500 57" Rear Projection Television
Convergence ware are they located at so i can change them
  • Sony Master
  • 8,617 Answers
They are located on the D board which is the brown board on the left side of the chassis attached to the large aluminum heat sinks
Posted on Aug 29, 2008
Picture is off center colors off location
Ur tv have a convergence problems,it dead.The convergence board the 2 STK convergence ICS and some or all it resistors are dead.To fixes convergence problems.The convergence board all these parts must be changed to get the onvergence in sink again to get the colors and picture to normal.The tv shop will cost u $300-350 for parts and labors.
May 24, 2010 | Hitachi 50GX30B 50". Rear Projection...
Sony model kp57ws510 rear projection. convergence problem. convergence button on front of tv does nothing
There are a set of convergece chips that need to be replaced. If they have been replaced and you still have the convergence problem you will need to change ceramic fuses in the power supply or on the board where the STK chips are located
Mar 04, 2010 | Televison & Video
Configuration
1st off the convergence is digital on these units when it takes a major change it means there is a hard ware failure
there are a two ics and some resistors that usualy need replacing
adjustments there made through the consumer menu.
adjustments in the service menus are for touch up or a corrupt DCU thats failed and needs to be reset up and the centering magnets on yokes are set for sharpest ctr point of focus .
Nov 01, 2009 | Hitachi 43FDX01B TV
Mitsuibishi WS65809
The only items on your set that should need replacement would be both convergence IC IC801 and IC802 which are both STK392-570 and you will also need to change the two 5 Amp pico fuses which are F9A04 and F9A05 they are both % amp pico fuses. All parts are located on the center Board
Oct 23, 2008 | Televison & Video
Help, Help, Help! Mitsubishi 73" red convergence fiasco
Thats the time you need to replaced the convergence IC.
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry and fuzzy images .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and cannot be adjusted this is the symptom for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Oct 10, 2008 | Mitsubishi WS-73907 TV
I'm experiencing different colors on the tv when displaying an image.
If these colors appear to be like a 3-D image, the problem is in the convergence circuit. Please update this with the make and model and I will provide you with further information and instructions.
Thanks,
Dan
Sep 24, 2008 | Televison & Video
Parts
Which board are you refering to as the main circuit board? The power supply PWB ? The Deflection / Convergence PWB ? or the Signal PWB ? respond to this same post and I can help you out, but there isnt a PWB called " main" In that chassis hitachi.
Jul 31, 2008 | Hitachi 46F500 46" Rear Projection...
Convergence amps
you need to change the ics that are located on the converge board is the one that is screw to the heat sink change both or the closes to the rear is for green vertical and horizontal and blue vertical and the one closes to the front is for the red vertical and horizontal and blue horizotal it starts with a STK number.
Jun 16, 2008 | Toshiba 55HX70 55" Rear Projection...
51PP9303H/17 convergence repair help
I would change all convergence IC not just the one that holds the red. You will need the schematic to get the resistors location.
May 01, 2008 | Televison & Video
Convergence problem
did you try to do convergence thru the menu system?
Feb 21, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
