Question about Saeco Incanto Classic Espresso Machine
Incanto Calssic Hi My incanto classic is 2 years old. The add bean light comes on when I try and make a coffee. The grinder goes on but no coffee comes out and some ground coffee goes into the dreg drawer. I found in the past if I moved the beans around while the grinding started it did help a little and a coffee was made. Now I do this about 6 times and no good. Help please Mirran
  • Anonymous Mar 30, 2014
    machine grunts and groans but no coffee comes out. It grinds the coffee beans and dumps them into the dreg drawer unused.
    HELP
  • 515 Answers
First, make sure you not get any damp into your grinder.
If you get damp into the grinder then it will not grind the beans.
To check the grinder you have to loosen the three screws in the beanhopper and lift it up.
The jagged plastic in the machine you will see when the beanhopper is off, turn it anticlockwise to you can see
the claque is free, then you can take out the jagged plastic and you will see the grinding wheel, make sure the wheel and the jagged plastic is clean.
Before you mount all again, use a vacuum cleaner to clean it.
Put back the jagged plastic again and turn it clockwise to it stop, then you turn it anti clockwise 14"click".
Set the number to 8 on the beanhopper and mount it again.
Hope this will help you.
Best regards
/Mirran
Posted on Aug 30, 2008
On my saeco incanto I get a red light showing no coffee but there is coffee.I'd be much obliged if you have any ideas Regards Frank
HI
Grinder adjustment set too low. Increase the setting to 18 and try again, after it grinds and starts to brew push the brew to stop the cycle. Repeat the steps again. If it works when it is grinding turn the big knob back down but to a mark 2 higher than you had it before. When the grind gets to fine the ground coffee compacts in the grinder and passage way then you get the message bean hopper empty. Making the grind a little coarser prevents the grinds from compaction. If you are using oily beans (Shiney) they can glue themselves together and cause the same symptoms but the fix is the same. Make it coarser. If it didn't fix the problem you will have to dissassemble the grinder and clean, then readjust.bansheracer_14.jpg
Jan 31, 2011 | Saeco Incanto Classic Espresso Machine
The plastic shield in the coffee container on my saeco incanto de luxe broke yesterday and fell directly onto the beans, but I was still able to make my coffee this morning, but this afternoon, the...
Vac out the bean chamber, then remove the 2 or 3 screws and carefully lift the bean hopper off the machine, then continue cleaning the grinder, careful not to lose the gasket around the top of the grinder. When done reassemble and try to brew but do not add beans to hopper as yet. Until you are sure all the plastic pieces are out.
Sep 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
My bean light won't stop blinking red!
Hi
Turn you big knob in the bean hopper up all the way to the largest #, then try again. If it clears the and makes a coffee do it 1 more time then turn the big knob back down while the grinder is running but don't turn it down as far as you had it before,(1 to 2# higher)
Mar 30, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic - Bean feed problem
Hi Zlatko,
Ok, i get wrong answer to you. I did a mistake with the model:-(
Yes, you have only one screw in the beanhopper, and to get this cleand you have to take off the top.
This grinder you have to turn anticlockwise to the claque is free you can take it out and clean.
When you put it back you have to turn it so the red mark is together.
If you make a cup of coffe and it grind but not take in water then you have to mount a resistance on the power board.
What serial number do you have on the machine?
/Mirran
Sep 03, 2008 | Saeco Incanto Classic Espresso Machine
Stuck grinder
make sure you not get any damp into the grinder. If you have damp in the grinder then it do not grind the beans.
/Mirran
Aug 30, 2008 | Saeco Incanto Classic Espresso Machine
Best regards
/Mirran
Aug 29, 2008 | Saeco Incanto Classic Espresso Machine
Saeco grinder
What kind of Saeco machine do you have, and how old is it?
Jun 27, 2008 | Saeco Incanto Classic Espresso Machine
Incanto-classic coffee beans do not flow to grinder
The machine automatically stir the beans since the blade make vibration and doing that shake the bean all around.Make sure the the tank is half full so the weight will help on that.If the container is almost empty the bean will fly around and don`t get in the grinder.Back up the machine to the original factory grinding and try to adjust again the wheel
Jun 07, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
70 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
