Question about Umax ActionBook 333T Notebook
Adaptor Hey Ekse, That was quick! Maker: ILAN Model: F1650L AC input: 100-240V~1.2A Max. Fuse rating: F2A/250V DC output: 20V-50W Max. (The symbol between 20V and 50W is actually something like two parallel em dashes, the upper one solid and the bottom one broken. my keyboard doesn't do that!) Hope that covers it, Ekse. All Greek to me. -eve
  • Umax Master
  • 13,433 Answers
Hey,
Have a look is this the power adapter,
CLICK HERE EBAY PRODUCT
Posted on Aug 29, 2008
  • Ekse Aug 29, 2008
    Accidentally clicked post too early.
    its a
    ILAN F1650L AC Adapter 20V 50W Max , seems to be the one you need.
    Let me know if you need anything else.
    Thanks,
    Ekse
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
What is the power output of ac dc adapter in jensen jta 460? Can this adaptor be changed with 220volt ac dc adapter with required dc output?
For Any Adapter:
As long as the Voltage and Power output of the power supply (wall outlet or other) matches the input requirements for the adapter whether 110V or 220V.at enough amp output; and
IFF the dc output of the adapter is exactly the same voltage and has for amps at a minimum matches the maximum amperage requirement for the input of the device, any of them will work, as long as it has the right connector with the correct polarity needed for the device!
Or, in other words...
Supply Output V = Adapter Input V
and
Adapter Output V = Device V
Adapter Output A(min) >= Device A(max)
Aug 27, 2015 | Computers & Internet
Need a replacement power supply for a Evernote scanner
Sorry Gregory, gave you the wrong number.
You could try something like this. Various voltages and currents with different adapter plugs. This is on Ebay UK but I would think there are others, don't know where you are.
Ebay item number: 201154296095
Specs:
1.Rated Input Voltage: AC 110V or AC240V
2.Vibration Input Voltage Range: AC95V-265V
3.Input Rated Current: 0.4-0.6AMP
4.Input Power: 90W
5.Efficiency: >88%(TYP)
6.Out Power: 90W
7.Output voltage: 15V/16V/18V/19V/20V/22V/24V(0/+0.5V NOLOAD): DC15V-24V
8.Output voltage: 15V/16V/18V/19V/20V/22V/24V(-0.4/0.5V@rating load): DC15V-24V
9.Output current: 15-20V/4.5A@22V-24V/4.0A: 4.5AMP(max)
10.Overload protection: YES
11.Short Circuit Protection: YES
Dec 17, 2014 | Office Equipment & Supplies
What kind of fuse does my mio moovr503t use in its charging unit
The fuse is to be found in the power adaptor
Fuse type : 1.0A / 250v
input: 10-30V/ DC , Max.1A
output: 5V / DC -- 1A
Len..
Oct 14, 2014 | Mio Moov R503T 5" GPS Receiver
Cannot start up tabet and ac charger transformer is cold when plugged in
You will need an adaptor of at least the same output in both voltage and power. The only level that MUST be the same is the voltage. The power level must be the same or higher.
Jun 28, 2012 | Computers & Internet
Lenovo laptop(8932) will go into a sleep like mode (you can still see the screen, very dim) when plugged into ac adaptor. Doesn't do it with battery power. Changed system board, power adaptor - no...
Good Day Psmith!
It looks like the AC adaptor is not making the right supply voltage needed for your laptop.
If you have a multi tester, you can test your ac adaptor to see if it has stable 20V voltage output supply needed for the laptop to make it work.
Set your tester to DC range. Plug the ac adaptor to your wall socket. Hold the other end of the ac adaptor (the one you connect to your laptop. Insert the red (positive) lead into the center of the adapter pin, then touch the black (negative) lead to the outside metal part of the pin.
Read the display in your tester. If the adapter is working properly, the meter should read between 19 to 20 volts of the rating. If the adapter is faulty, the meter will read below 18volts.
If that would be the case, I'm afraid you will need to replace your ac adaptor.
You can purchase online a replacement ac adaptor for lenovo 8932.
1. From this site, it costs $34.99 + $8 https://www.ebuybatteries.com/product/models/2_IBM-Lenovo-AC090W008T15_IBM+Lenovo+ThinkPad+R61+8932.htm
2. From this site, it costs $39.95 http://www.eznsmart.com/p-31667-lenovo-thinkpad-r61i-8932-laptop-ac-adapter-replacement-20v-45a-90watt-charger.aspx
Please accept my answer if this is the information you need.
Don't forget to give a four thumbs up rating!
Thank you for asking Fixya.
Jun 23, 2011 | Computers & Internet
Need a ac adaptor for a Protron PLTV-32. MODEL LU32A1A3. INPUT 100-240V 50-60Hz 3.0A MAX.Output +24V-6A +12V-3A
I found one through Powerpayless.com at http://www.powerpayless.com/ac-dc-power-adapter-for-protron-pltv-32-pltv32-lcd-tv.html. It works great!
Mar 01, 2011 | Protron Ac / Dc Power Supply For Protron...
I CANNOT FIND A REPLACEMENT FUSE FOR THE VECTOR VEC024B INVERTER.i HAVE OWNED IT FOR LESS THEN 3 MONTHS . IS THERE AN ALTERNATE FUSE THAT CAN BE USED?tHIS IS THE CIGERETT LIGHTER CABLE FUSE. F8VL250V.
Go to any Appliance parts store with your fuse in hand and walk out with a replacement. The 250V fuse is AC OUTPUT and "not" a DC input fuse. That is an 8 amp 250V slow blow fuse.
Mar 23, 2010 | Vector Maxx SST Power Inverter
Defect in AC adaptor
Traggio,
It's seemd you need a new AC Adapter. You can get a new Universal AC Adapter for your LCD monitor. Check out this website @ www.3rd-rocks.com
Sep 07, 2008 | X2Gen MG19MY 19" LCD Monitor
Umax ActionBook 333T Notebook Logo
190 people viewed this question
Top Umax Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
tdk1988
Are you an Umax Computer and Internet Expert? Answer questions, earn points and help others
