Question about Refrigerators
LG refrigerator - Ice Machine is slow making ice
I have an LG side by side refrigerator. Model number LRSC26925TT. After having the Ice maker repaired by an authorized repair service, the unit does not seem to make Ice fast enough. The repairmen replaced the ice cube unit that freezes the water and dispenses it into the ice bin. Is there anything thaqt I can do to troubleshoot this issue?
Regards,
  • caft Oct 11, 2008
    Same, maybe different model but Ice has slowed greatly, almost to a stop. I have checked the water line and that is fine.
  • rlbaltes Feb 10, 2009
    I have the same problem, but mine is newly installed in my new Frigidaire. Not sure of the brand name on the maker since none is given. So is it a Frigidaire too, or generic? I don't know. But after each 24 hours that go by I get around 40 small pieces of ice (at 8 per cycle). that's five cycles per day. WHAT'S UP?
    I was hoping I would find an adjustment. Is that something just build into the thing? A timer of some kind?
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
  • 4 Answers
SOURCE: LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Posted on Mar 21, 2009
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
woodchuck789
  • 4070 Answers
SOURCE: Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
How to repair Refrigerator ice maker that not making ice
Any chance you may have the model number of that refrigerator that you're having problems with the ice maker?
Appliance 911 Sea Breeze there are some ice makers that you can repair but as far as cost is not worth it ice makers wear out after several years there's a lot of work involved in making ice just replacing the part that broke doesn't fix the rest of the Ice maker
Sep 01, 2016 | Frigidaire Refrigerators
My ice machine not making ice
Is there ice in the ice maker? If there is frozen ice in the ice maker, ice maker is probably faultily.
Ice Maker Repair
Dec 05, 2012 | LG LSC26905TT Side by Side Refrigerator
I am trying to replace my ice maker which is broken. I can not find the correct model ice maker anywhere on the internet. My ice maker for model LFC25770SW/05 is a top mount in the freezer, not a side...
Go to your local appliance repair shop, not the big stores. They should be able to steer you to the right icemaker. Most of these (not all) are generic. They should be able to help you for about $100.
Mar 15, 2011 | LG Refrigerators
The lever is stuck on my LG ice dispenser
You'll need to replace the whole ice maker system. Problem exist in the mechanical box connected to the lever which once opened is almost impossible to re-assemble. Cost around $95.00
Aug 06, 2009 | LG LRSC-26922 Side by Side Refrigerator
Ice maker very slow to make ice
there may be some thing stuck in the ice machine try checking it out
Jun 02, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice maker wont shut off
So many different types. lots of info needed. In short, lg have DIPswitches on main board. By adjustment of these switches, the water in can be controlled.I dont think there is a water sensor on these makers per say.Does the water ever switch off at any time and if so, is the inflow time constant?. Assuming the solonoid valve is not defective.
Jan 17, 2009 | LG LSC26905TT Side by Side Refrigerator
Have an LG LFX25960TT refrigerator with in door ice maker. The ice maker only makes 2 to 3 ice cubes at a time. (Too slow for my family's needs.) It appears like it doesn't get enough time to fill. Is...
Check to make sure the water supply to the refrig is good and the inlet screen where the water line connects to the refrig is clean. You can change the amount of water fill by pressing the button on the left side of the ice maker. (indicator lights above button show setting) Selecting "Ice Plus" on front of dispenser panel increases ice production for a 24 hour period. Ice maker should produce 6 cubes per cycle, aprox.. 100 to 130 cubes in 24 hours depending on freezer compartment temp, room temp, number of door openings, etc.
Sep 10, 2008 | LG Refrigerators
LG SIDE BY SIDE - REPLACED FILTER BUT WATER VERY SLOW
You may have ice building up inside the fill tube that is slowing the water flow.  You will have to remove ice maker to see inside the tube.  If the tube has ice buildup, use a hair dryer to melt the ice.  Then is should work fine.
May 23, 2008 | LG LRSC-26922 Side by Side Refrigerator
Icemaker slow to make ice
Tener, sounds like you have a module going bad. Pull off the white cover of the ice maker and take a look at the center white gear. There should be two clips securing the gear on. A lot of times these clips break and cause the gear not to rotate properly. Part number for the module is 628399. Take a look at this first. Catriver..post back
Nov 01, 2006 | Kenmore 53202 / 53204 / 53209 Side by Side...
Refrigerators Logo
1,050 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
