Question about Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum
Hoover widehead bagless vac
All debri stays on filter and wont go to the cartridge i checked for blockage and see none.
  • pfuller Nov 15, 2008
    all debris stays on filter. Cannot find blockage
  • 281 Answers
Is your brush roller and hadlight working.if not call me at 314-628-9153 and i can help you
Posted on Apr 23, 2009
WHEN I PUT FILTER IN THE VAC GOES ON AND OFF WHEN VAC
Hi there Jacqueline, it's Jack at Dyson.
If your Dyson cordless vacuum is pulsing on and off with the filter in place, the filter may need a wash. I'd also strongly recommend checking the bin inlet, wand and motorised floor tool for any blockages, following the steps shown in our video guide:
When you check the bin inlet, make sure the bin inlet flap is able to open and close freely, and that no debris is jamming it in place.
I'm confident this will resolve the issue. If you'd like further assistance from our experts after giving this a try, please call the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We'll be able to talk you through some simple diagnostic checks when you have your machine fully charged and easily to hand.
Jul 22, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
Vaccum seems to cut off after short use like its hot,,once it cools off i can use again
Check filter. Clean if needed. The filter should be cleaned when it appears dirty. Simply remove filter, rinse thoroughly under warm running water until clear, then allow to thoroughly air dry. The drying is very important. Additional filter cleaning instructions are on page 13 of the manual.
Check the pleated exhaust (HEPA) filter. If dirty, cleaning is necessary. Instructions for removal and cleaning are on page 14 of the manual.
Check hose, wands, and power nozzle for blockages.
Hose: detach at both ends. The ends of the hose are the most common areas for a blockage. Check visually and clear as much as possible if present. If not visible, hold one end up and drop a coin in. Lift the end until the coin falls through. If it doesn't, there's a clog.
The easiest way to unclog a hose is to use an air pressure hose, or a canister vacuum that has an exhaust blower that the hose can be held too. If enough pressure, it will blow the dirt out. Make sure to put a plastic bag around the loose end to hold the dirt.
Visually check wands and power nozzle. The bend in the power nozzle connection is another common place for clogs. A wooden spoon handle, or similar blunt object, can be used to push the debris back toward the brush to clear a blockage here.
If none of these are the problem, contact a vacuum service center, preferably Hoover, for assistance.
Manual:
http://www.hoover.com/pdfs/manuals/S3865.pdf
Thank you for providing the brand and model info. It helps a lot.
Mar 05, 2011 | Hoover Platinum Cyclonic Bagless Canister...
The air flow indicator on my hoover elite rewind bagless vacuum shows mostly yellow. we have followed all the directions in the manual - empty dirt cup, cleaned filter, checked two locations for blockage,...
Hi, sounds like you may have a small leak in the vacuum body. After changing the filter etc. turn machine on and run your hands alond vac. body. If there is a leak you will feel or hear it. If leak is found the light should change when you cover it. I hope this helps you./ Its hard to give advice without seeing it. Give it a try then let me know how you are doing. Chris
Feb 09, 2011 | Hoover U5507900 Elite Rewind Bagless...
Hoover Mach 5 turns off after 5 minutes of using. Can you advise the problem?
5 minutes everytime? If so, raise brush all the way, and vacuum next to nothing. in fact, tilt vac up so the brush touches nothing. wait 5 minutes. If it doesn't shut off, your brush is set too high. if it does, the motor is over heating. make sure bag is empty, no debris in brush, filters clean and make sure you're not plugged into an outlet that a breaker on the outlet can pop too.
Sep 28, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
I have a Hoover Wind Tunnel Self propelled 12amp. There seems to be very little suction. I have cleaned the hoses and filters but still not much suction. any ideas? thanks.
Make sure all filters are cleaned out and entry ways are clear of all debris. Remove hose and check for blockage. Usually the low suction can be remedied when all filters are cleaned. Hope this works for you.
Jul 17, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Hoover 1900W bagless vacuum that only blows out - does not **** in - what is wrong?
check for a blockage. start at the bottom and work your way up thru the hose all the way up to where it goes into the body of the vac. also check your belt.
Nov 02, 2009 | Vacuums
Hoover U8147-900 WindTunnel V2 Bagless Upright has sparks coming from motor housing
Most bagless uprights are exposed to dirt being drawn through their motors and filtered afterwards. As a result when you see sparks the motor has generally suffered its final breath... Today's uprights often run with high RPM disposable motors where older bag type uprights used lower speed rebuildable motors.
So the short answer is you likely need an entire motor as a minimum. If the unit is a higher end model mover $200 , in great condition and less than 5 years old, take it to a Hoover service center and either buy and install a motor or have them rebuild it. But also consider this...
What most people don't realize is they spend more on high priced consumable filters for many cheap bagless vacs than they ever would spend on bags and in the end the bagless is dirty to handle and has a shorter life span. Mass merchants sell the vacs cheap because their profit is in the filters
Remember a vacuum is the hardest working appliance in your home in the toughest possible conditions
If you replace this vac do so at a pro shop and see the options they have. You will get good advice , you will spend a bit more with better results and less frustration because you will build a relationship .....and always know where to go for service.
Oct 08, 2009 | Hoover U8147-900 WindTunnel V2 Bagless...
My hoover mach 6 bagless overheats, shuts off for about an 1 hr will run again, all filters are clean, no blocks in hoses, how can i fix this problem
This is telling you that there is poor air flow or a blockage somewhere. To simply check for proper suction, remove the accessory hose to see if there is normal suction, if not then your problem is further in the unit. Troubleshooting from there will tell you where the problem is. Another possibility is that your thermal overload circuit is faulty. in this case a pro vac shop needs to service the issue.
Feb 28, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Kicking out debris
Your vacuum will kick back dirt if there is a clog of anykind, or if the filters are dirty. First check the suction lines for any clogs, if none are found, take out your dirt cup, and take off the filters. Normally there is a foam prefilter covering a paper filter - replace both filters. The reason this happens, is that the filters allow the air flow at a specific rate, creating the suction and they cyclonic action you see when you are picking up debris. I hope this helps.
Jan 20, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Hoover Light on
ALTHOUGH MOST FILTERS SAY WASHABLE THEY DO STILL NEED TO BE REPLACE AS WASHING THEM SHRINKS THE FILTER AND EVENTUALLY CLOSES THE AIRWAYS. WHICH ALSO IF NOT REPLACE WILL OVER HEAT MOTOR IN MACHINE AND CAUSE MOTOR FAILURE.
Mar 27, 2008 | Vacuums
Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
