Question about Carrier Heating & Cooling
Air conditioner a pump with a small hose keeps spitting out water what do i do.
  • 95 Answers
Probably nothing, the evaporator coils need to drain off the condensed water
Posted on Aug 29, 2008
Water condensate tanks keep filling up. Never needed to empty them before with many years of use.
Rick, check the hoses are not clogged or plugged. There is probably a small pump which may have quit and will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Air conditioner leaking in your basement Condensate pump Reliable Heating...
How to repair check Condesate Pump Little Gaint VCMA 15UL
How To Unclog Condensate Pump Tube
Jun 04, 2016 | Heating & Cooling
When water runs off the condenser, is there a path it follows to the back of the unit that cold become blocked?
ac units are designed with a small trough at the back of the unit under the evaporator fins
this trough drains out a small hose to outside the building
It can become obstructed by gunk from the inside of the house ( same gunk that blocks the air filters) or the hose attached to the drain outlet can become blocked
check for a mud wasp nest in the drain hole as well
Jul 12, 2015 | Filter Heating & Cooling
Hi Water is spitting furiously out of the front of our 3 month old air conditioner... what should I do?
Wow i thought i just answered this one. Check the filter and be certain its clean then If it has a hose for a drain make certian that it is not kinked . if not just make certian that he unit is tiled to the ouside about 1 inch or so. also this is a small unit so close the doors to all unused rooms and check to be certain that the fresh air vent is closed . some times called outside air as well. Hope this helps let me know.
Aug 07, 2011 | Haier Mechanical Air Conditioner HWF05XC7
My ac is spitting out water in the front and making a loud noise
Your noise is probably your fan hitting water. First try to tilt the ac to slant to the outside. If this is done water should drain to the outside if not your drain hole is blocked from the front to the back you can see this if you remove the unit and look at the front coil housing you will see a very small weep hole clean it out and use a water hose to clean the front coil and the back coil. good luck
Aug 08, 2010 | LG Electronic Window Air Conditioner
Air condition leakes water
you can get a small condensate pump, and run the hose to a drain like a sink or toilet, you may have to trick the switch if you have to put the pump inside, where the bucket would fit.
Jul 08, 2010 | Amcor PLM-14000E Portable Air Conditioner
My LG window air conditioner is spitting out water on the floor and I can't seem to find any hoses or water pan to clean it out
randobrad had it exactly for me, the port to the outside was cleared but the one from front to back was clogged. Once I found the small port (using a wire hanger) it was easy.
May 18, 2010 | LG Electronic Window Air Conditioner
(Tilted) Plasmaire spits water into room....
What your problem is is that water coming back into your face is condesation. Appearently there is a clog preventing your condensation water from draining out the back side of the a/c You can remove the a/c from it's sleeve, take it outside and with a pump sprayer (Type used for spraying insecticide) filled with water spray around the base of the a/c where the condensor coil sits (you should see a small drain channel in this area) If this drain channel is clogged water will back up and the squirrel cage will pick it up throwing it out into the house.. Good Luck on your repairs
Dave
Sep 03, 2009 | Kenmore 76100 Wall/Window Air Conditioner
Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
Jul 08, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Dehum
Dehum is short for dehumidify. This setting is to remove the humidity from the air without doing any real airconditioning. Also, if the a/c is spitting water out the front, then the a/c is leaning forward too far. The a/c should be at least level or maybe leaning toward the outside a little bit to help facilitate drainage.
Jun 25, 2008 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
