Question about GE JBP90 Electric Kitchen Range
Baking element GE stove (baking element caught fire and was replaced w/new element. When cleaning the oven, the bake element was lifted up and shorted out (lots of fireworks). Replaced baking element again but element won't heat up. Broil element works fine as well as glass stove top elements and clock etal. What else could have been 'fried' when the short happened. Much thanks!!!!
  • 1,543 Answers
Oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Posted on Aug 29, 2008
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
I have a GE spectra JBP24 model. I turned on the oven and in a few minutes noticed a funny light inside. When I opened it up the element was burning. I unplugged the stove and when it cooled down, I went...
This is a common but spectacular occurrence when a bake element fails. You can go to your local appliance parts store with your model # and they may have a replacement element in stock.
Remember to rinse the baking soda out prior to using the oven.
Aug 29, 2010 | GE Spectra JGBP35 Gas Kitchen Range
The coil in my oven caught on fire
You will need to replace the element, If it was just the lower bake element, it is a very easy repair, two screws and two wire connectors. UNPLUG the stove FIRST!!
Jul 01, 2010 | GE Spectra JBP78 Electric Kitchen Range
Jenn-Air SVE47100 Oven Won't Heat
are you still getting power to the oven? breaker ok? there may also be a fusible link somewhere on the circuit
Nov 21, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Electrice oven not working
Hi.
You are quite correct in saying that a new element will solve the problem.
It is usually located at the rear of the oven compartment behind a removeable cover.
Please rate my comments.
Thanks.
Nov 20, 2009 | Frigidaire Ovens
Troubleshooting failed bake element
What exactly do you mean when you said element caught on fire?
Jul 31, 2008 | Ovens
Oven fire
wrong call ge@ 100-851-6200 and they will help you have the model number handy before you call
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
GE JBP90 Electric Kitchen Range Logo
756 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
