Question about Dell Inspiron 8600 Notebook
Laptop harddrive I want to replace my hard drive for a larger one could you recommend a brand and size
    Genius:
  • 2,028 Answers
Western Digital, Hitachi, and IBM all make good hard drives. As far as the size, that's just up to you, how much space you want and how much you want to spend. I recommend checking pricewatch.com for the drive, they have the best prices. Many times I can get hard drives from Price Watch cheaper than I can from my retail suppliers.
Posted on Aug 29, 2008
  • Ryan Rogers
    Ryan Rogers Aug 30, 2008
    Wasn't me Ekse, I got one too. Been getting alot of tft's lately that aren't locked.
  • Dell Master
  • 13,433 Answers
Hey,
Debends on what is the current size of the HardDrive
For example a ATA 80GB drive here - EBAY
Thanks,
Ekse
  • Ekse Aug 30, 2008
    You may have to upgrade your bios, if the size goes too high and its not deteced, why did I get a tft for this? Pyrhyc?
I need a harddrive for my toshiba laptop-what kind do I get?
Any laptop brand will work.
It is nice to get the same size or larger drive and to get the correct connection, IDE or SATA.
You didn't give your model so you need to google your model number with the words "disk drive" after it. That should take you to a site to purchase a new one. Amazon & NewEgg can walk you through this also.
Aug 24, 2010 | Toshiba Computers & Internet
Can I replace my gateway T-6836 laptop 250 gb hardrive
Yes, it can be upgraded for a larger drive. The important specs to know are the physical size and the interface. The size that this computer needs is the 2.5 inch and the interface is the SATA. These are the typical size and interface used today so finding a drive that fits should not be a problem.
Hope this helps.
Jun 30, 2010 | Gateway T-6836 Notebook
N800v harddrive blew out
It depends upon your needs, the larger the hard drive to higher the cost and the maximun size you can install depends upon the BIOS. The smallest hard drive that is readily available is about 100Gb.
Jun 15, 2009 | Compaq Evo N800v Notebook
I instaled 2cd harddrive but i have problem to set up
STOP! BEFORE you do *anything* else, BACKUP your important documents, files, drivers and programs... EVERYTHING that is important to you.
Now UPDATE your Windows with the latest UPDATES available!
Is your NEW hard drive LARGER in size? Say your "MASTER" is 200GB (example) and your NEW hard drive is 500GB (another example)?
If it's LARGER, GREAT! Consider a program that will CLONE ALL of your data to your new LARGER hard drive! This way you loose nothing your original MASTER has... you just end up with more space!
There is a FREE CLONE program that I recommend called: EaseUS ToDo. The LINK will also include program and CLONE instructions.
Sometimes a VIDEO TUTOR is more helpful so I include a LINK for that as well.
AFTER your successful CLONE I will recommend that you REMOVE your original drive and put it away so IF something goes WRONG at a later date ~ you can always get back to where you are today!
GOOD LUCK and ENJOY your new hard drive.
Anthony
Use Free Disk Cloning Software to Clone Copy Hard Disk
TUTORIAL:
EaseUS Todo Backup is great tool to make backups on all version of windows
Nov 05, 2017 | Toshiba MK1032GAX HDD2D08 100GB ATA-6...
My sony vaio s460 does not detect the hardrive, after I installed new 120 gig sata, I called to sony and they said tha I need the same hardrive 80m gig 5400 rpm, as the laptop comes from factory, it is...
It may be that your machine can not handle a drive of that size. When I replace hard drives I always try to replace them with the size they came with just in case they do not support a larger size.
Dec 18, 2008 | Sony VAIO VGN-S460 Notebook
Hard Disk upgrade
Figured this out...
1)  Flip laptop over, keep front of laptop closest to you and hinges away from you 2)  Remove cover with cylinder/harddrive icon (2 screws) 3)  Remove small single silver screw near the front (close to you) of the laptop in the center of the metal harddrive caddy (the caddy may hold one or two hard drives) 4)  Pull the plastic tab on the left toward the outside of the laptop... the whole caddy with harddrive(s) inside will shift to the left, disconnecting it from the motherboard and lining up the caddy for removal. 5)  Lift the entire bracket straight up
To remove the primary harddrive (the only one present in my model) you must remove the blue L-shaped circuit board from the caddy. 1)  Flip the caddy over 2)  Remove the three screws with slightly larger head diameters around the perimiter of the caddy 3)  Push/slide/jiggle the circuit board so the sata connectors release from the hard drive(s). 4)  Unscrew the hard drive from the caddy
Aug 25, 2008 | Acer Aspire 7720 Notebook
Bios won't reconise 160 gig maxtor harddrive
You could try a BIOS update to increase the size of the Drive the BIOS is able to see.
The second last one indicates that drive sizes are supported over 65GB. It may still not be able to see the 160GB HDD, but this is your only option with this Board. You could always upgrade the Motherboard to support larger drives.
Good Luck.
Apr 24, 2008 | Maxtor HARDDRIVES Hard Drive
Hard drive
The Compaq Armada M700 laptop has a PATA (or IDE) hard drive verus a SATA hard drive which is the newer standard. This computer's factory hard drive could not have been any larger than 20 GBs. However, one this size is not readily available anymore so you'll have to go larger. Here is the type of hard drive that you need: http://www.bestbuy.com/site/olspage.jsp?skuId=8692373&type=product&id=1198286608739
Apr 08, 2008 | Compaq Armada M700 Notebook
Compaq presario 1685 is this particular system xp compatible.
Unfortunately, the Hard Drive size is only 4.3 GB, while WinXP takes 3 GB and requires at least 5 GB to run. Even if you did have an external Hard Drive, the amount of RAM is not enough to let you do anything. Stay with your current OS or get a new PC.
Feb 05, 2008 | Computers & Internet
Dell Inspiron 8600 Notebook Logo
95 people viewed this question
Alun Cox
