Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Ice maker production
Wanted to know your recommended solution? Thanks.
    Sergeant:
  • 409 Answers
what exactly were you looking for?
please provide the model # off your fridge.
Posted on Sep 17, 2008
Rude Customer Service
Try Ice-o-Matic ... they are very similar to Scotsman machines
Aug 06, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman dce33pa1bc not making ice
I will be here on Fixya or HERE if need. click here to download adobe acrobat just make sure you uncheck the Google toolbar download if not wanted. Many Answers are in this Service Manual and should you have questions please let me know, Thanks Sea Breeze
Scotsman DCE33PA1BC Service Manual
.PDF
If helpful please rate this solution..Thanks
Oct 19, 2011 | Scotsman DCE33PA1BC 15in Built-in...
Hello - I am trying to find a replacement part for a SNO portable ice maker - it is the rotating plastic plate that collects the ice as it comes off of the freezing nubs then pivots and dumps the ice into...
Hi Scott and welcome to FixYa, I am Kelly.
Your talking about either the T-1A or the T-2M portable ice makers by Whynter. The only think I can recommend is that you contact them directly here:
Phone: 866-WHYNTER Email:info@whynter.com
or use this link to use an on line contact form:
http://www.whynter.com/contact_us
I do not know of any external sources for the part you need.
Their ice maker products are here:
http://www.whynter.com/product/refrigeration/ice_makers
This information is from their product guide:
To obtain service or information, contact
Whynter Innovations Group via Email at service@whynter.com or call 866-WHYNTER
Thanks for choosing FixYa,
Kelly
Jun 12, 2011 | Vacuums
I have a model ed2nhgxtq00 whirlpool refrigerator. The problem I am having is that it doesn't make ice as fast as it used to. What do I need to do? Thanks!
Hi and welcome to FixYa, I am Kelly
First off check the freezer door switch for operation. Depress the plunger and make sure the light goes off when the door switch plunger is depressed. Light stays on = bad door switch / no ice production as the door switch provides power to the ice-maker when the door is closed.
Additionally in your case make sure that the evaporator fan is running at full speed. A slow running evaporator fan will cause the freezer compartment cooling to suffer.
Another thing that can cause the freezer temps to start rising is dirty condenser coils in the bottom of the unit. Make sure that the coils are free of lint and that the condenser fan is running at full speed. Usually when there is a problem with the condenser coil air-flow the cabinet of the unit will be VERY warm to the touch on the front in the door seal area. It is supposed to be warm.... just not VERY warm.
Here is a link to the steps on how to troubleshoot an ice-maker.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Let me just add that many ice-maker related problems are due to the freezer temp rising above 16 deg F. The freezer starts warming up due to ice build up on the evaporator coils and then the internal air-flow is blocked by the ice build up causing the temps to rise. Look closely at the back of the unit for any signs of ice build up.
If you see ice build up......
1. Unplug the unit
2. Remove the freezer contents
3. Place a fan directing air into the freezer for just over 2 hours. (Water mess!)
4. Clean up the excess water and restart the unit. (Add freezer content)
5. After 8 - 10 hours check for NORMAL ice production.
If after doing the above you have ice NORMAL production then most likely you have an automatic defrosting problem.
If it still does not make ice, the steps in the link above will isolate what has failed in the ice-maker.
Before testing the ice-maker using the steps in the link.. I recommend you peform a manual defrost with a fan. If 8 - 10 hours after the manual defrrost you do not have ice production,, use the link and troubleshoot the ice maker.
Here is a 2nd link for ice-maker troubleshooting that includes testing the optical system of the ice-maker:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Your ice-maker parts and refrigerator can be found here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5135173&diagram_id=28114824#d28114824
The above link goes directly to the ice-maker but, using the diagrams on the left side of the page it will bring up all other sections also if you click on them.
Kelly
Jan 31, 2011 | Whirlpool Refrigerators
The fridge is all working ok the freezer is all working ok but the ice maker is not working i have removed the tube that goes to the water part at the back and blew down it an it is not blocked
First off check the freezer door switch for operation. Depress the plunger and make sure the light goes off when the door switch plunger is depressed. Ligt stays on = bad door switch / no ice production as the door switch provides power to the ice-maker when the door is closed.
1. Unplug the unit
5. After 8 - 10 hours check for ice production.
If after doing the above you have ice production then most likely you have an automatic defrosting problem.
Kelly
Jan 31, 2011 | Refrigerators
I have a Whirlpool gold french door model # GI5FSAXBY02. The icemaker stopped making ice -please advise. Thanks. Charles Mara chrlsmara@yahoo.com or cjmara@cox.net
Could you double check your model number. I am unableto pull that model number up. You mentioned that your ice makehas stoppedworking. This could be several things, like water control valve,defective ice maker, defective ice maker thermostat and more. Let me know,Thanks, SeaBreeze b8e6bdd.jpgWHIRLPOOL PRODUCT MANUALS
Sep 26, 2010 | Whirlpool Refrigerators
Brand new ice maker, water fill to tray will not shut off
The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
Jul 14, 2009 | Whirlpool ET8WTKXK Top Freezer...
I have an il gelato ice cream maker and it does not get cold enough ,what can I do if anything.Jack It cools down but it will not get cold enough to make ice cream. it appears that the compressor works but...
Unfortunatel for what it will cost to repair you can buy another on ebay for way less, i know thats not what you wanted to hear but its the simple economics of our high priced repair world. Happy hunting S/B around 40.00 plus shipping
Apr 22, 2009 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
What freon 134A
The freon in most ice makers are R 410a at this time. You will be able to find the type of freon your model has listed most times on a data plate on the rear of the ice maker cabinet and on or near the compressor. R 134a is not always used in production ice machines because it does not freeze water as productive as
R 410a. The type oil in the compressor also will lead you more in the direction of the type of gas. Now If you need to replace the freon or compressor I can help you determine the exact type of freon gas was existing before the change, Let me know if this has answered your question. Thanks, Sea Breeze
Feb 06, 2009 | U-Line Icemaker
Gran Gelato ice cream maker by Girmi
I have the instructions for use for a Girmi Ice cream Maker GL14. I could scan it and send it to you. Do you have an email address - or I could post it. Lou
Jun 12, 2007 | Girmi GL14 Gran Gelato 1 Quart Ice Cream...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
