Question about HP iPAQ RX3115 Pocket PC
Set up VPN
I am trying to setup VPN on a new rx3115. To be used over wireless. Can anyone please help? Thanks,
    Master:
  • 450 Answers
If you already have your wireless connectivity setup, you can go to start->settings->connections tab, connections again and add a new VPN connection.
Posted on Sep 11, 2005
SOURCE:
Every time i go to oovoo it keep getting this error Error 101 (net::ERR_CONNECTION_RESET): Unknown error.
DON'T USE GOOGLE CHROME ITS FULL OF TROJANS!!! WINDOWS DEFENDER ON MY MACHINE DETECTED IT!!!! TRY FIREFOX!!!! HOPE HELPS :D
Feb 15, 2010 | Google Chrome
I bought an unlocked G1, Im in the UAE, how can I set up my phone it is not connecting to the 3G network of etisalat
Here is how to set G1 3G and MMS for UAE Etisalat separately (u can enjoy mms or 3G alone by deactivating settings for either one). First you need to setup 1 access point for each service, sttings is as follows:
-----------------3G----------------
Name: Etisalat3G (could chos any name)
APN: Etisalat.ae
MCC: 424
MNC: 02
APN type: default
--------------------------MMS----------------------
Name: EtisalatMMS (chose any name)
APN: mms
Proxy: 010.012.000.030
Port: 8080
Username: mms
Password: mms
MMSC: http://mms/servlets/mms
MMS proxy: 010.012.000.030
MMS Port: 8080
MCC: 424
MNC: 02
APN type: mms
Enjoy the ultimate G1 services!!!
Feb 20, 2009 | Google Android
Printing with Dlink DI-624S and VPN connection
I am guessing this VPN is something work related and not a VPN you setup yourself?? If that is the case your company's VPN access will not allow you to pass from there network back to yours which is why you are unable to print to your local home printer when connected to VPN. You might could run it by your IT staff and see if they will allow connection and help you set it up. If not then simply email the docs to yourself and then print them out after you are finished using VPN connection.
Hope this Helps
TankMurdock
Jan 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I cannot access internet when connected to VPN.
1. Please assign an IP address to your computer using the IP Address Reservation.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. On the setup page, please click LAN IP Setup under Advanced tab.
e. Click Add under Address Reservation then you will be brought up to a new window.
f. On the Address Reservation window, please select the radio button of the computer you wish to add.
g. If the computer you want is not on the list; click the Refresh button to update the table.
h. If the computer is still not on the Address Reservation Table; please enter the IP Address, MAC Address, and Device Name of the computer you wish to add.
i. Please click on the Add button when finished.
2. On the Set Up page of the router, select on Port Forwarding/Port Triggering under Advanced tab.
3. Click Add Custom Service and type VPN on the Service Name box.
4. Set the Service Type to TCP/UDP and input the VPN port numbers under the Start and End Port field.
5. Type in the last digit of the IP address of your computer. Then, click the Apply button.
Example: The IP address of the computer trying to establish the VPN connection is 192.168.1.2.
Service Name Start Port End Port Server IP address
VPN1 47 47 192.168.1.2
VPN2 50 51 192.168.1.2
VPN3 500 500 192.168.1.2
VPN4 1723 1723 192.168.1.2
Dec 01, 2008 | NetGear WGR614 Router
I want to create site to site vpn with sonicwall tz170+ 2003serv
Complete documentation is available on the below link
http://www.sonicwall.com/us/support/3134.html#heading_3139
Nov 17, 2008 | Sonicwall TZ 170 NFR (01-ssc-5564)...
Cisco VPN Client won't connect
You'll want to enable the VPN transparency. In the router's administrative web interface, click the Security Tab, then the VPN Passthrough sub-tab. Cisco VPN's usually use IPSEC, so enable the IPSEC Pass-through and click "Save Settings". If this doesn't work enable the PPTP Pass-through as well and give that a shot.
Dec 31, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
Connecting VPN using Netgear 624
This is no small undertaking. You will first have to decide if you are going to use software or hardware vpn. Software vpn is free and only requires that you install it (the client) on whatever remote system you are using to connect to the 624. I can say that you want to have your internet connection point (DSL modem or Cable modem) set to "bridge" mode. This will pass through all traffic to the netgear directly. Some (like a speedstream 5200 DSL modem) allow this or they have a DMZ feature which will accomplish the same. Either way you want to ensure ALL ports and all traffic are getting to the netgear. Once that is done you simple create a string at both ends that match for your security phrase and an authentication that matches and you should be good. It's really a lot more than what could be provided here. (Several lengthy documents worth) but I can provide you with a useful link that will give you an a-z about VPN and has specific walkthroughs for Netgear users only. http://www.vpncasestudy.com/index.html Hope this helps a little.
Aug 22, 2007 | NetGear WGT624 Wireless Router
Not able connect to VPN from my new Netgear WGT624v3
Uncheck the "disable SPI firewall" option in the wireless settings for the router.
Aug 20, 2007 | NetGear WGT624 Wireless Router
Sort out my VPN issue
On my 4350, if I go Settings -- Connections -- Tasks, there's a task "Set up a new VPN connection," which will walk me through network IDs and authentication. I worry that that isn't there in WM2003SE, but have a look. As to your second question, one serious flaw to the current communications software is that there's no way to save multiple settings sets. So when you're home or go to a public hotspot you'll likely have to empty out all your office settings, then re-input them when you're back in the office. Good luck.
Sep 11, 2005 | HP iPAQ HX2750 Pocket PC
HP iPAQ RX3115 Pocket PC Logo
96 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
