Question about Umax ActionBook 333T Notebook
333T's AC/DC adaptor broken
The adaptor can't be used. Three of the four wires are broken off next to the plug which fits into the computer. Someone told me it could be soldered -- but only by a person who knows how the wires should be arranged in the four holes. Where can I get it fixed, or replaced? (I'm in New York City & would rather have it done locally if possible.)
  • 6,487 Answers
You can check this link for this repair http://www.fastlaptoprepair.com/city.asp?st=New%20York
Hope that helps.......
Posted on Aug 29, 2008
  • Umax Master
  • 13,433 Answers
Hey,
I would get a replacement ac adapter from www.ebay.com if you post me the details on the apdater I can look it up for you
Thanks,
Ekse
  • Ekse Sep 03, 2008
    Comment as requested.
  • Ekse Sep 03, 2008
    Please accept my solution as we have solved the problem.
    Thank,
    Ekse
    PS. if you still require futher assistance feel free to contact me.
Wire my ac jack for my samsung np365e5c
The AC adaptor goes into the AC socket, NOT the computer connection. The Computer connection is DC and comes from the DC side of the Adaptor. If you mean the DC socket has broken, then you need someone to replace it inside the computer.
If the AC adaptor has failed, you can buy a replacement ( 19V 3.16A 60W AC Adapter).
See the Manual
http://downloadcenter.samsung.com/content/UM/201408/20140829115137641/Win7_Manual_eng.pdf
Feb 23, 2015 | Samsung Computers & Internet
My computer a 1905-s301 will not run on just ac power
It means either the AC adaptor has failed or the DC socket on the laptop is broken. Check the AC Adaptor's output DC voltage using a multimeter first.
Dec 18, 2013 | Toshiba Computers & Internet
Which AC adaptor to use with New Balance Elliptical 9.0e
if u have a lot of ac adaptor then find thesame voltage output to ur gadget..if you don't have the exact voltage dc output for ur gadget better buy one....what is your machine need? ac power or dc power? if your machine is electronicaly operated so u need is dc power...but if your machine is like a motor so u need is ac power....tnx
Jun 19, 2012 | Computers & Internet
Can i use AC Adaptor that has input: 230V-50Hz output: 9VDC to Creative SBS 2.1 370 Speaker?
The Creative SBS 370 Works on 11.5V AC (IT IS NOT DC) 1600mA (Means 1.6 Ampere) and 18.4VA. So, the Power Adaptor which you connect to the power socket behind the woofer is an AC ADAPTOR and NOT A DC ACAPTOR.
Nov 02, 2011 | Creative Labs SBS 370 Computer Speakers
Dc jack of labtop getting vey hot
A common weak spot on most laptops is the DC power jack. If someone trips on the wire while you have the power adaptor plugged into your laptop, chances are that the power jack will get damaged.
On most laptops the DC power jack is soldered directly to the motherboard and there are only three or four small pins holding it in place. Unfortunately that makes the power jack quite weak. Any sideways pulling of the DC power cord while attached to the laptop will usually dislodge at least one of these pins, breaking the solder around it. Modern laptops use quite a lot of power, from about 70W to 120W or even more. The bad electrical connection from the dislodged pin will cause sparks and heating that will eventually burn a hole through the motherboard and can even be a fire hazard.
The usual signs of that are:
  • The battery is not charging properly or stays at half charge despite that you have been using the power adaptor.
  • The screen flickers (the brightness is changing) while the power cord is plugged in. This is caused by the laptop switching between DC power (screen is brighter) and battery power (screen is dimmer).
  • The DC plug gets hot after a few minutes of use and may even smell of burning.
  • There are "scratching" sounds coming from the DC jack.
You need to take the unit apart and check/resolder the DC jack on the system board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 15, 2011 | Computers & Internet
My ibm think pad t40 is not switching on
Hi
Assume you are trying this on battery and mains?
1st thing is to check if the AC power adaptor is giving out any power, which you can do by obtaining a multimeter and setting it to 50 volts DC. Place the positive probe in the centre of the adaptor plug and the negative against the outside of the adaptor plug and see if you get a reading. this will confirm that there is power getting to the laptop
(NOTE: THIS IS TO BE TAKEN FROM THE DC END of the power adaptor NOT from where the kettle lead AC source enters the adaptor.. if in doubt, get someone who is competent with using a meter)
2nd, is to check that the power button is not sticking and that the small plastic pin between the laptop body and the screen ( I think these have one) is not stuck, preventing it booting
3rd, If you are getting power by AC to the laptop, check the condition of the DC jack socket, if it is loose, appears to spark whrn the jack is plugged in or crackles, this will need replacing
4th, If the above do not work, it is possible that the main fuse in the laptop has gone...specialist repairers job.
Dec 28, 2010 | IBM Computers & Internet
What voltage are the koss 'older' computer/CD speakers that would take 3 'C' batteries each. I have a variable voltage adapter and am not sure if I should switch it to 9 volt or another setting for AC...
C cells are 1.5 volts each. If the speakers use three of them that means you'll need a 4.5 volt supply. If each speaker needs batteries, you'll need to feed that voltage to each speaker, and the supply should have enough current for the total load. A 1-amp rating is probably fine.
Dec 24, 2010 | Koss HD 50 Computer Speakers
Which transformer to use
To solve the problem I tosted the whole mess of wires and equipment and bought new equipment. $8,024 spent and now all the new converters are labeled. The industry needs to mark all equipment with DC-IN 9V or whatever. This is a real problem if you have kids and grandkids and too many different standards.
Dec 13, 2008 | AOpen AOR-401M Router (90.18R10.402)
Adaptor
Hey,
Have a look is this the power adapter,
CLICK HERE EBAY PRODUCT
Aug 29, 2008 | Umax ActionBook 333T Notebook
Umax ActionBook 333T Notebook Logo
108 people viewed this question
Top Umax Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
tdk1988
Are you an Umax Computer and Internet Expert? Answer questions, earn points and help others
