Question about Motorola Mobility RAZR V3c Cellular Phone
Frozen keypad What is the flex cable
    Brigadier General:
  • 7,752 Answers
It connects the lcd to the board or vice versa
Posted on Nov 01, 2008
4 Suggested Answers
  • 13 Answers
SOURCE: flex cable
It's fairly simple to replace a flex cable if that's the culprit. This is a flex cable: http://cnn.cn/shop/motorola-razr-keyboard-flex-cable-p-300.html It's got adhesive on it so if you plan on repairing yours, you need to peal your old one off. That's really no big deal, the thing you REALLY need to worry about is damaging your keypad when removing it from your housing. You might want to order a new one just incase for that very reason. Be aware that unlike the V3c's flex cable which is a separate cable that connects to the main board to go up to the upper part of the phone, the V3's keyboard flex has its cable attached, which means you must open the top portion of your phone as well. Opening the bottom part of the phone is simple. Opening the top part is where things get slightly tricky, if you're not careful you could really damage your phone.
Posted on May 15, 2007
  • 18 Answers
SOURCE: HOW TO INSTALL THE OEM Motorola RAZR V3 Keypad LCD Flex Cable
1), remove the bottom part (completelly)
a) do you know how to open the bottom part?
2) remove the cover on the top part
a) disconnect the keypad LCD Flex Cable
3) remove the two chrome "big screws" that allows it to open and close
4) CAREFULL!!!! WHEN YOU READY TO SEPARATE THE TOP PART FORM THE BOTTOM!!
a) make sure the Flex cable is loose, and take a screw driver, push the ping on the other side (try to do this at the edge of a desk or table) keep pressure until this side pops out. KEEP IN EYE ON THE OTHER SIDE!! that the Flex cable does not get cut out by separating the two sides.
5) Replace and pop the two sides together.
6) Put everything back together.
let me know if I need to be more specific
Posted on Dec 07, 2007
  • 4102 Answers
SOURCE: i always get a white
Hi, the problem you are having is with the data ribbon between the screen and the circuit board so you only need to replace the data ribbon for the screen, once you have replaced this your phone should be working once this is replaced, make sure you dont damage anything whilst doing this as the connections can be a bit dodgy,
let me know if you need further assistance ok
Posted on Oct 27, 2010
After change flex cable the phone not working
the phone is not working? or the keypad only is not working? in that case, try to reheat the chips
Dec 08, 2015 | Cell Phones
My keypad on my Katana stopped working. Can only
Friend, Check the flex connection from the keypad interface then clean the board or the doom with pencil eraser
Jul 25, 2009 | Sanyo Katana SCP-6600 Cellular Phone
Phone won't turn on properly
hi Miss_Pink03
most likely those symptoms appears when the phone Flesx cable is faulty
What is the phone flex cable??
its the electronic stuff that connects the keypad to the Main and Mini Display
u most replace it and its not an easy task though
plz do rate this post
Oct 07, 2008 | Nokia 7390 Cellular Phone
Motorola razr freezing
your phone problem is the keypad flex of your phone'
you can fix it by replacing the keypad flex'
motorola dealer has the keypad flex'
ask for a skilled cellular technician to re-place your keypad fle..
i hope it will helf to your prob...
Jan 07, 2008 | Motorola Mobility RAZR V3
Lower key 5, and uper softkey not working
your keypad flex cable has an issue or software caused a keypad mapping error - either a flash for $35 or a flex for $150 is the repair
http://horizonwirelessonline.com
Dec 21, 2007 | Sony Ericsson W550i Cellular Phone
Dec 07, 2007 | Motorola Mobility RAZR V3
V3i keypad problem
change flex cable(patta). Include keypad in flex cable so change It and enjoy your phone
Sep 23, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola RAZR V3 LCD SCREEN went blank - black screen
The LCD flex connector is very sensitive. 4/5 of the RAZR screens I see go out are due to a loose flex connection. It's super easy to fix it. Take off the battery door. There are two T6 screws. Take them out and pop off the bottom of the phone. There are two flex cables: one for the keypad, the other for the screen. Connect the flat cable (screen cable) first. Then connect the bent (keypad) cable. Put back together. Voila.
Aug 16, 2007 | Motorola Mobility RAZR V3
Keypad frozen, still receives calls
Hi, You don't need 2 flash your razr for this problem. What u need is a screen flex cable. The three buttons around the screen are controlled by a flex cable and the voice recorder is connected on this flex cable.This needs replacing but it's very tricky to deal with. I suggest a really good tech that deals with razr's to handle this problem to possibly replace the flex cable. This would solve yor frozen keypad problem. SAM !
Jun 19, 2007 | Motorola Mobility RAZR V3
Flex cable
May 14, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
67 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
