I have loaded the software for a WRT54G2 on the new desktop. As instructed the data for setting up my laptop was saved to a jump-drive and installed successfully on my laptop. When I try to get online with the laptop, I get a "server not found." The icon in the lower tray of the laptop says it is connected to an unidentified network which is named ournetwork. Ournetwork is the name I gave our network when I installed the router software on the desktop. The icon does not have a red x in it, but there is something on it that looks like a yellow rectangle with a black exclamation point. When I right click and select Network and Sharing Center I get my laptop with a bar to the network icon that has the yellow triangle with an exclamation mark. The network is labeled as unidentified network. The bar from the network icon to the the internet has a red x in it. I previously sought help prior to buying a new desktop when I was trying to install the router on the laptop and the wireless on the old desktop. The problem then turned out to be that the WRT54G2 router wouldn't interface with OS's older that XP. That reference # was 080802-020027. This situation is entirely different, so I don't know that referring to the old contact will be helpful.
  • 1 more comment
  • r3dbon Aug 29, 2008
    The problem sounds simple; I'm sure it is for you. I have no idea what the WEP/WAP ios key should be and I have no idea where to find it. I do presume you are talking about changing something on the laptop.
    May I back out of this service I subscribed. If I couldn't understand the first answer, how in the world am I to understand the second? Good Grief!!!!!!!
    I am on the desktop which is connected to the router that is connected to the incoming phone line. It's working. what I want is for the laptop to work.
    If this is the nature of the service, I do want out; so please tell me how to back out. It ain't worth it. If you can't let me back out, please ask a suervisor to contact me.
    I don't understand how or why it is not connected properly. I installed it as directed using the CD that came with the router. What else can I do? The yellow cable is in the yellow slot on the router and the yellow slot on the modem; the blue cable is in slot one of the router and the ethernet port of the desktop. This message will go through the router and reach you.
    I have no idea how to change the connection to make it any different. Is the problem the router?
    Sergeant:
  • 241 Answers
I have this Same Router
Did you set - NETWORK SET UP WIZARD on the PC 1st
Then it will prompt you to follow the same direction as the lap top
It is alway recommend that you use the newest OS on the system that you are using for the server/host computer.
agter you have set up the network on the PC and Then you need to do the same as the lap top
The only thing is make sure you select that you wil be connecting through and another computer for you network
Posted on Aug 29, 2008
  • 1 more comment
  • Jayson Brollini
    Jayson Brollini Aug 29, 2008
    NOW THE LAPTOP SHOULD BE ON THE NETOWRK
    BUT NOW YOUR ROUTER IS GOING TO HAVE TO BE CONFIGURED TOO> BY NOW YOU SHOULD HAVE ALL THE INFO TO CONFIG THE ROUTER>
    NOTE: MAKE SURE YOU NAME YOUR LAP TOP AND PC WITH DIFFERENT NAMES SO THE NETWORK WILL ID THE CORRECT PC TO CONNECT WITH
  • Jayson Brollini
    LAST THING YOU might have to unplugged your modem and router and then plugged them back in But you have to this in order
    1st the modem wait until it is online
    2nd the Router wait for it to receive the buffer packets(signal)
    3rd the pc(host/Server)
    I sure do hope this helped
    PS,THe reset button is your last option this will reset the WEP password it is located on the routers rear Thanks (plZ feel free to rate)
  • Jayson Brollini
    Jayson Brollini Aug 30, 2008
    (Please Rate Expert User --->Kindofcheap
    Thank You FixYa
  • 1,879 Answers
To most effectively support your issue, we require some additional information.
> Your Internet Service Provider ?
> How many computers do you have ?
> Operating system ? XP / Vista / Mac
> Try connecting to the router using an Ethernet cable (hard-wire using the cable that looks like a phone cord but a little bit bigger & fatter), are you able to get online ?
  • monk3ybidzness
    monk3ybidzness Aug 29, 2008
    Please address your response to the proper tech to avoid confusion.
  • monk3ybidzness
    Ok good you're online with a DESKTOP hard-wired to the router.
    What is your Internet Service Provider ?
    Genius:
  • 1,269 Answers
If you can go online wired to the router, please do the following steps:
1. Open Internet Explorer. On the Address Bar type http://192.168.1.1 and press enter.
2. It will prompt you to type in username and password. By default there's no username and the password is admin but if you changed it during the initial setup, please type in your own password for the router.
3. When you have the router setup page opened. Click on WIRELESS tab. Click on Manual then change the Wireless Channel to 11. Make sure the SSID Broadcast is set to Enable then click on Save Settings.
4. Go to WIRELESS SECURITY tab. Please double check the Security Mode. If the Security Mode is WPA-Personal, get the Shared Key/Passphrase (write it down on piece of paper). If the Security Mode is WEP, get the WEP Key #1 (write it down).
5. Now try to connect to your wireless network. Right-click on the wireless icon at the system tray and select Connect to a Network. You should see your network there, click Connect. It will tell you to type in the network key which is the WPA key or the WEP key tha you wrote down then click connect. That should fix your wireless connection.
  • Michael Galve
    Michael Galve Aug 29, 2008
    The solution that I posted needs to be done using your desktop (Steps 1 to 4).
    The Step 5 should be done on your laptop. Sorry for the confusion. Please give it a try again.
    Master:
  • 623 Answers
Go to my network places
and set up wireless network for home or office
goodluck
    Master:
  • 638 Answers
The router is not connected properly to the internet.thats the only problem.remaining every thing is fine.thats why it shows the yellow triangle with exclamation mark every time you try to connect.this shows there is some sort of error in the connection.
thanks.please rate the solution.
  • hemant somaiya
    hemant somaiya Aug 29, 2008
    may be .please check.it could be the problem.
  • 13,433 Answers
Seems the router is not correctly setup or connected to the internet - dsl modem.
Connect the dsl modem into the internet port, you may have to open up the web user internface to configure the connection correctly.
I would definitely say that is configured incorrectly as it is now.
Thanks,
Ekse
  • 6,487 Answers
The only problem here is the WEP/WPA key ios not correct , so better double check the key and try tp reconnect to the wireless network..
Hope that helps.........
  • 1 more comment
  • Mark Gil
    Mark Gil Aug 29, 2008
    Is your network secure?? because if its secure you need to make sure that you're typing the correct security key
  • Mark Gil
    Go to your desktop computer , Open internet explorer then on the address bar type 192.168.1.1 hit enter then it will ask you for a username and password , leave the username blank and type admin for password.
    When you're already on the Linksys setup page, go to Wireless tab then you will see there Wireless security sub tab then there you can get the Security key that you need.
    Then after that connect again to your wireless network with the security key from the router page...
  • Mark Gil
    Mark Gil Aug 30, 2008
    There's no problem with the router, you just need to connect your laptop manually to the wireless name of your router...if you have the user manual for your laptop read it to know how to make it work wirelessly...
Start up repair won't fix problems
If the Repair fails, then you need to re-install the Operating System all over again. If you want to save existing data, such as pictures, documents and music; you must remove the hard drive from the laptop and attach it to a PC. There are Laptop cords with attachments that connect laptop drives to a USB port on a PC. You will have to use one of these cords and get the hard drive open on the PC Desktop. Once open, transfer the data to the file (make one on the PC Desktop) and save it. When complete, you will need to format the old laptop drive so it can be used again in your Laptop. If you don't care about saving your laptop data; then simply put the Windows Operating disk in the DVD and run from your laptop, installing a full new version on the existing hard drive. Windows will seek the Hard Drive for you and prepare it for new start.
Dec 19, 2013 | Compaq Presario M2000 Notebook
Hi, For a week or two now when i put my Sony Vaio on i get a message saying my hard disk is failing & to back up my files but when i put a disk in it fails to back up. It's also telling me the name...
You need to purchase a new hard drive and have it installed, If you have anything important on your laptop right now, that is what you want to create a backup of, or you can have the store you buy the hard drive from do the back up for you and most computer stores will load it all to the new drive for free
Aug 22, 2011 | Computers & Internet
When I power on my laptop instead of saying resuming windows it says hibernating
If you have the recovery disk of your laptop.First boot cd/dvd rom drive and load the recovery software and follow on the screen instructions. That will restore your computer factory settings but be careful and not to forget to back up or save your data or files before recovering your system.
If you can resume or turn back to windows desktop, try updating your windows or downloading updates from Microsoft to fix some bugs or errors.
Please rate me
Nov 19, 2010 | Dell Studio 14z Notebook
Hi I was just wondering... If I have a virus or a few on my Dell vostro 1000 laptop that caused me to be unable to get windows updates or anti-virus updates which disabled or eat my anti-virus software...
Yes it would be better to save your data to an external hard drive or flash memory stick. Remember to scan the this data before you copy them back onto your laptop, if the data files are infected with viruses you will infect your laptop again.
If is best to re-install Windows, the installation process will allow you to delete the old partition, create a new partition and then select a full NTFS format, do not do a quick format.
For further instructions, please click on this link and follow my instructions :-
Normal 0
http://www.fixya.com/support/r6298168-restoring_dell_computer_or_laptop
For your device drivers, please click on this link:-
Normal 0 http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Oct 13, 2010 | Dell Vostro 1000 Mobile AMD Sempron...
I was downloding a backup on my bb, i didnt remember the password so it gave me an error 513 what do i do?
The Blackberry Device Software must be reloaded on to the BlackBerry smartphone.
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps:
1) Open BlackBerry Desktop Manager.
2) Click Help.
3) Select About Desktop Manager.
4) Click the Device Software tab.
5) Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider.
For instructions on how to download the latest versions of BlackBerry Desktop Manager and BlackBerry Device Software follow the steps:-
1) Click the BlackBerry Device and Desktop Software link. 2) Click the Download BlackBerry Device and Desktop Software link.
3) Select the appropriate software from the drop-down list and click Next.
4) Click the Download link.
To perform a full backup of the BlackBerry smartphone data complete the following steps:-
1)Connect the BlackBerry smartphone to the computer running BlackBerry Desktop Manager.
2) Open BlackBerry Desktop Manager.
3) Click Backup and Restore.
4) Select Backup to perform a full backup.
5) Select a location to save the backup file, and then click Save.
To perform a selective backup for one or more databases perform the following steps:-
1) Connect the BlackBerry smartphone to the computer running BlackBerry Desktop Manager.
4) Click on Advanced.
5) Select the database(s) on the right side selection window for Device databases.
6) Select the Arrow that points to the left side of the screen to transfer the database(s) to include in the backup.
7) Verify the database(s) are on the left side selection window for the Computer databases.
8) Click on File in the menu located at the top left hand side of the Desktop Manager.
9) Name the backup file and select a location to save the file.
10) Click the option to Save once the location for the file is selected.
1) Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
2) Double-click Application Loader.
3) Click Next to start the installation process.
4) Type your BlackBerry smartphone password, if prompted, and click OK.
5) Select the check boxes next to the names of the applications to be loaded, and then click Next.
6) Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
7) Clear the check box next to Backup up device data automatically during the installation process.
8) Click Ok > Next > Finish. 9) When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following:-
1) Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
2) Click Next.
3) Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
4) Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
5) Click Next > Finish.
Oct 16, 2009 | RIM BlackBerry Pearl 8100
Its says JVM error 513 reset
2) Click Help.
5) Select the database on the right side selection window for Device databases.
6) Select the Arrow that points to the left side of the screen to transfer the database to include in the backup.
7) Verify the database are on the left side selection window for the Computer databases.
following:-
2) Click Next.
4) Clear the check box next to Backup and restore applications installed wirelessly(if prompted).
I want to transfer data from my dial-up desktop, to my new laptop high-speed broadband. How?
Several ways:
1.) 4GB flash drive
2.) External USB drive (320GB or more)
3.) Burn CD or DVD on the desktop and copy to the laptop
4.) Connect them in a local or ad hoc network (not too easy)
I'm sure other expers will have more ideas...
Anyway, at the desktop, run the "Files and Settings Transfer Wizard" to gather your desktop info, such as favorites, desktop icons, My Documents, etc:
[Start]
[All Programs]
[Accessories]
[System Tools]
[Files and Transfer Wizard] [Next]
At the desktop, answwer [Old Computer] [Next]
Cintinue to answer the questions
If you have a lot of music or loots of pictures, then just transfer the "Settings Only".
After a successful transfer of the settings, run the wizard again and transfer your "Data Only"
Hope this gets you started.
Sep 18, 2009 | Computers & Internet
NEED INSTRUCTIONS ONHOWWO FORMAT MY ACER ASPIRE 5100 SERIES
hi there
there are couple of steps involved in formating the laptop.
i will try to give simple and easy solution
--> save/backup all your important data into external hard drive or DVD/CD so you will not loose the data
--> i hope you have the xp cd with you
--> put the xp cd in the drive
--> restart the computer
--> press del/f2 to go to BIOS (setup)
--> in boot configure first drive should be your dvd drive
--> press F10/ save changes and exit
--> it will ask press any key to load from cd
--> after that the xp setup will start
--> follow the instructions
--> you can delete and create partitions here too or simply format the drive
--> install the xp
--> install the drivers
--> your laptop is ready to go but dont forget to change the BIOS setting to normal again.
hope it will help you sir.
Mar 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
I have an E-Machine W3107 desk top. I recently installed a western digital 120 hard drive as a slave but it would not jump. Can you give me any help in getting my system to jump. Thank you.
Jump? Ha! Never heard that term. How about boot?
Nowadays people just load drives as Cable Select; it should have worked with the old drive set to Master, but try to set them both to that and try again, or boot to a LiveCD or the drive utility disk so you can configure them on that. If they don't appear correctly in the BIOS, just double-check that power and data cables go to each drive, etc. You may need to follow the BIOS instructions or enter the BIOS controls by hitting DEL or F10 on powering up until the menu appears; then you can select the drive to try to boot first, etc. and save your settings.
Jun 23, 2008 | E-Machines Computers & Internet
Help with my laptop
Do you have your Acer restore cd or your original Windows cd? Let me know and I will help you through this. Thanks.
Jeff
(DON'T RATE THIS 'TIL WERE DONE)
May 21, 2008 | Acer TravelMate 2480 Notebook
Computers & Internet Logo
David Payne
David Payne
