Question about Toshiba Sora PDR-T10 Digital Camera
Focus I can’t focus properly. What could the problem be?
    Novelist:
    Scholar:
  • 104 Answers
The camera uses a precise auto focus mechanism, but under the conditions and with the subjects described below the auto focus function may not work well. Subjects moving at high speed Very shiny subjects such as a mirror or car body Extremely low contrast subjects (such as subjects dressed in the same color as the background, etc.) When there are objects in front of or behind the subject (such as an animal in a cage or a person in front of a tree) Subjects with little reflection, such as hair or fur Subjects with no solidity, such as smoke or flames Subjects viewed through glass In addition, the focus is set on the center of the frame, so if the subject is not at the center (when shooting two people standing side by side, for example), the focus is adjusted on the background and the desired subject (the two people) may be out of focus. In such cases, do the following: Point the camera so that one of the persons is at the center of the viewfinder. Half-press the shutter button. (The focus is locked on the person.) Holding the shutter button in the half-pressed position, reposition the camera to achieve the desired composition. Take the photo. If the focus cannot be adjusted, it is locked to infinity (1.5 meters when using the flash).
Posted on Sep 11, 2005
Nikon l120 focus is off
I don't know what your perception of proper focusing is.
If there is enough light and enough contrast in the subject you want sharp (in focus) on your picture, you only have to point the camera to the point you want in focus on. Then you press the shutter release button half and wait till the camera is in focus. This is indicated by the focus point on top of the screen. as long as you keep the button half way down, you can move the camera and the focus will not be changed. So you can make changes to the composition. Then when you press the button down complete the picture should be sharp, where you focused on.
Don't try to make a picture, by pressing the button complete. as quick as you can, because the camera won't react as fast as a DSRL.
Mar 23, 2014 | Nikon COOLPIX L12 Digital Camera
Focus is off
Check to make sure the focus screen is in properly
Aug 08, 2013 | Canon EOS Rebel XSi Digital Camera
AF 20mm f:2.8 D don't autofocus accurately. It focuses always behind the focus point.
http://www.dofmaster.com/dofjs.html
Make sure that your dof is in the right range for your chosen f value and that your focus settings are set correctly in your camera.....some of the older nikon lenses do not have proper data and will not focus properly on any camera and must be focused manually. That being said 20mm is fairly wide and it is not overly complicated to manually focus
Feb 22, 2011 | Nikon Super Wide Angle 20mm f/2.8 AIS...
The electronic viewfinder will not focus. Photo results, however, are properly focused. LCD properly focuses, but I prefer to frame my pics using viewfinder. What's the fix?
There's a diopter adjustment control near the viewfinder. Adjust it while peering through the viewfinder until the image suits your eyes.
Sep 10, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
My Fuji S5100 now fails to properly focus. I have
1 ensure that your camera is not set in Macro mode test by taking a picture of a subject very close up ie. 10 - 15 cm if the image is in focus then you may be set in macro mode.
2 if lens is removeable ensure it is fitted properly. remove the lens and refit ensureing the connectors are clean.
3 ensure the switch on the lens or camera is set to AF for auto focus.
4 suspect autofocus sensor is defective if you try to focus on subjects which are close and far away and you do not hear to camera re-setting the focus then it is in manual focus or the focus sensor may be defective or in need of adjustment.
5 recommend specialist have a look at this problem.
Nov 16, 2009 | Fuji FinePix S5100 Digital Camera
Jason 313 telescope doesn't focus properly. Can
Put the eyepiece with the largest number written on it into the telescope. DO NOT use the 2x barlow if you have one. Go outside during the day time and practice focusing on a distant object.
The moon should be your first target.
Nov 01, 2009 | Optics
Auto focus is not working properly and will not
You want to charge people for a membership to get answers from your site
but you want me to "tell you how I did it" for free. Hmmmmmm?
Sep 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
Focusing problems
Many things can cause this problem. Here are some ideas:
First be careful not to block the Focus assist light with your left hand while holding the camera.
Some setting won't let you properly focus (like being in macro mode from too far away).
Apr 16, 2008 | Canon PowerShot S5 IS Digital Camera
Toshiba Sora PDR-T10 Digital Camera Logo
113 people viewed this question
Top Toshiba Cameras Experts
Damen Wong
Damen Wong
Hjalmer Lamminen
Hjalmer Lamminen
Simon Flummox
Simon Flummox
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
