Question about HP iPAQ HX4700 Pocket PC
-SD Card was renamed
I have several programs on my SD card (HP 1gb). I recently installed a "presenter-to-go" program which uses hardware in the SD Card slot. After installing the software and hardware, my SD Card is now named "SD Card2" and the presenter-hardware is considered "SD Card". My SD Card programs are looking for files on "SD Card" rather than "SD Card2", and thus cannot run. What should I do in order to run both the presenter-to-go and the programs on the SD Card? It would seem that since the operating system has renamed the SD Card once, it should be able to rename it back.
    Master:
  • 450 Answers
From what I remember when this happens you empty the SD slot and do a soft reset. When the SD card is put back in it will be SD card. Similar steps when you put your SD slot device in.
Posted on Sep 11, 2005
Sd card password lost
Secure Digital (or SD) memory cards are one of the most popular forms of digital media storage. When using SD cards with a mobile device, you can set a password to protect unauthorized users from viewing the files. However, sometimes, you may lose the SD card password. If you have access to the mobile device, recovering the password is a simple process. If the mobile device is not present, the only way to recover the password is to reformat the device.
Download and install a file explorer application, such as FExplorer, X-plore or Best Fileman onto the mobile device. http://download.cnet.com/f-explorer/3000-2094_4-75758737.html Run the application on the mobile device. Select the "Find" option. Type "MMCSTORE" in the space provided. Connect the mobile device to the computer via either a Bluetooth connection or the connection cable that came with the mobile device. Send the "MMCSTORE" file to the computer. Rename the "MMCSTORE" file "MMCSTORE.txt" on the computer. Open the "MMCSTORE.txt" file on the computer. Write down the password located in the "MMCSTORE.txt" file. b> Using a PC b> Download and install the SD Formatter program from the SD Association website. http://www.sdcard.org/consumers/formatter/ Insert the SD card into the computer's SD card reader. Run the SD Formatter application. Select the SD card from the drop-down menu and click the "Format" button. Formatting the SD card will reset the password. However, the process also will remove any data that is stored on the card. Allow several minutes for the SD card to format. Hope this helps.
b>
Dec 29, 2012 | Computers & Internet
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
I have a 2GB micro sd card,but when i check it into my cellphone,my memory card is error.What is the problem of my memory?
Step One:
Step Two:
Using the HP Drive Key Boot Utility, the first way
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
Oct 07, 2011 | SanDisk 2GB microSD Memory Card
How to unlock micro sd memory card, when i forgot my password
Recover an SD Card Password b> Secure Digital (or SD) memory cards are one of the most popular forms of digital media storage. When using SD cards with a mobile device, you can set a password to protect unauthorized users from viewing the files. However, sometimes, you may lose the SD card password. If you have access to the mobile device, recovering the password is a simple process. If the mobile device is not present, the only way to recover the password is to reformat the device.
Sep 14, 2011 | Kingston 2GB Secure Digital Memory Card
I scanned my micro sd 1gb and 2gb cards with wormblaster and now the 1 gb reads 59mb and the 2gb reads 13mb and will not format does these cards have a MBR that maybe got wiped from the scan because both...
Instructions
Things You'll Need:
* SD card slot or card reader
1. Download SanDisk Formatting Utility
2. Open an internet browser and enter the URL for the free SanDisk formatting utility into the address bar (see Resources).
3. Accept the terms of use by clicking the button labeled "I Accept" at the bottom of the page.
4. Save the executable installation file (sdfv2000.exe) to the computer hard drive.
5. Open Windows Explorer and navigate to the installation file.
6. Double-click the sdfv2000.exe file to begin the installation of the software.
7. Click "Yes" to accept the terms of use for the installation package.
8. Verify the installation location and click "Next."
9. Select a Program Folder for installation and click "Next." The progress bar will monitor the installation.
10. Click "Finish." A text file containing notes for formatting software will automatically open.
Format SanDisk
11. Click the Windows "Start" button.
12. Click "All Programs."
13. Locate and expand the Panasonic link.
14. Double-click the program entitled "SD Formatter."
15. Insert the SanDisk card into the SD slot or card reader.
16. Click the top drop-down box in the SD Formatter interface to view a list of available drives on the computer.
17. Locate the SanDisk drive and select from the drop-down options.
Click the button labeled "Format" to begin the formatting process. A notification will appear to indicate the process has finished.
Nov 04, 2010 | SanDisk 2GB microSD Memory Card
How to use sd card with magellan meridian gold
http://www.mtgc.org/robertlipe/MeridianFAQ/#47.Troubleshooting%20–%20My%20tracks%20have%20the%20wrong%20time%20stamp?|outline
Try this site to trouble shoot your problem! Good Luck! I ran across this today trying to trouble shoot mine.
Dave
Sep 09, 2008 | Magellan Meridian Gold GPS Receiver
Memory card micro sd cannot format
i found something to fix it. or at least it worked for me
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Install that, then run the program and CAREFULLY select your card from the formatting list
then do a low level format
Then format it on windows or phone or whatever
PLEASE BE CAREFULL NOT TO SELECT YOUR HARD DISK IN THE PROGRAM. IT WILL VAPORIZE ALL YOUR DADA
Mar 08, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Memorex MMP3642A - SigmaTel format
A few suggestions:
1] I’ve tried using a 1GB sd card in the MMP3642A with no success. Interestingly, I can transfer files to the 1GB card when it is in the MMP3642A, but when I turn on the player to listen to the files, I get the sigmatel formatter error message. I tried running the sigmatel formatter, but it doesn’t understand the 1GB size. Apparently whoever programmed this braindead formatter program only programmed it for up to 512MB sd cards. Interestingly, I tried flashing this player with the MMP8500 firmware, and then the player does play files off of the 1GB sd card, but the LCD is mostly cutoff and only 25% of the LCD shows up. So it seems the only obstacle to using a 1GB sd card is this stupid formatter program. I tried formatting the sdcard to fat16 instead of Fat32, but that did not help
2] If you want to use a card with more than 64MB, you need to use the CD that was with the player. DO NOT USE AUTORUN! Explore the disc, go into the "products" folder, run the stusbmscformat.exe application. It will show a the drive letter for the player, click the arrow and select the next drive letter down, then press start. This worked for me, I hope it will be useful. Why memorex doesn’t address this issue is beyond me.
3] How do I correct the error: Reformat external media with sigmatel formatter? If you have installed the software disc that you received with your MP3 player, you will need to follow these instructions; -- From your computer, click 'START' -- then 'PROGRAMS' -- then 'MEMOREX' -- then 'FORMAT' -- choose the 2nd drive If this doesn't correct your error, you will need to return the memory card to the retailer for an exchange. connect your memorex mp3 player , then turn it on and click start .....i did the same and its working now.
Jan 08, 2008 | iLO MP3 Player
Tomtom One
If you have the programs downloaded from tomtom home then you need to copy them to the sd card that you purchased. In the home program you can choose to install the programs and map to the sd card. It takes a bit of a search to get the tomtom home program understood. The credit card with the codes is an authorization code for the program.
May 17, 2007 | Tomtom 1D00.081 GPS Receiver
HP iPAQ HX4700 Pocket PC Logo
303 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
