We have a magnavox lcd tv 15MF170V/17, and the power went out and wouldn't come on. So my husband took off the back cover and during his fiddling aroun with his fluke, the power started working. So he put it all together and it came right on, but now we can't see the video..it is darker on th eleft side and a little brighter on the right side, and the audio is fine. Before we decide to chunk it, could you tell us which part we may have damaged to cause this? Thanks,jd Lowe
  • jello67 Aug 29, 2008
    how would we identify this part and is it worth replacing?
  • jello67 Aug 30, 2008
    We cannot locate a tuning button..not really sure what the video controller looks like..
  • 2,071 Answers
Just click below and go to LCD TV trouble shooting, and for the spare parts click monoserv.com...
http://www.lcdparts.net/Secure/BasicUser/Default.aspx
www.MONISERV.com
Hope this may help;
Regards,
VOTIT
Posted on Sep 01, 2008
  • 1 more comment
  • LORETO LACARON
    LORETO LACARON Sep 07, 2008
  • LORETO LACARON
    Do a hard reset. Unplug the TV and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.There is no tuning button,only you can get fine tuning by using remote.
    If still nothing happen all the above procedure.Then it's better you bring this unit to authorized service center.
    Hope this may help;
  • LORETO LACARON
    LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
    Symptom: No picture on screen but LCD TV still has sound.
    Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem.
    Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
    Symptom: Blue Screen but no picture
    Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Screen.
    Symptom: Power light stays on but no display and sound
    Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board.
    Symptom: No Power or Power indicate light does not lits
    Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board).
    Symptom: Screen is half dim and half bright
    Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
    Master:
  • 521 Answers
Technical help is much necessary.its located internally.
Posted on Aug 31, 2008
  • 446 Answers
The inverter of your LCD is either damaged nor loosely connected, see if you can find small piece of board independently connected thru your LCD,
cheers
Posted on Aug 30, 2008
    Genius:
  • 2,920 Answers
Send it to a shop and end the guesswork here.there are alot of different things that could cause the problem and its best to let a serbice tech fix it right
    Sergeant:
  • 241 Answers
Well If I were you try something simple like reset the tv bak to the FACTORY settings this will be on you menu.
Thanks please post
  • Jayson Brollini
    Jayson Brollini Aug 30, 2008
    I have been looking for the the answer and when the back of the TV was opened was it on..or plug in
    if so can you smell anything BURNT in the rear of the TV
    ALSO try to use a different conections for your VIDEO like a HDMI or COMPOSTIE cable just try all the video inputes and play a dvd or some media device
    Please Rate your FixYa Expert Kindofcheap
    Genius:
  • 1,269 Answers
Look for video output wires. It might have been tripped. Resoldering it could fix the video. Double check any cold solders from neighboring parts as well. In addition, please do check any blown capacitor, resistor and transistor on the circuit board. If you found one, replacing it will fix the problem.
Posted on Aug 29, 2008
  • 1,879 Answers
I'll go with michealm's answer
  • 435 Answers
Replace c2074 in the power supply 2200Uf at25volts.
    Master:
  • 638 Answers
The inter nal settings of the video controller is little bit moved .while you took it off.just remove the back cover again ang readjust the video settings.its like a tuning button.wind it anticlock wise in the open unit and check till the video is not comming right.
thanks.please do rate the solution.
  • 37 Answers
You could have damaged one of the what i call energizers that is used to illuminate the LCD in certain areas.
My 98 Sentra does not turn over
Has the battery been load tested? do that first.
Apr 30, 2017 | 1998 Nissan Sentra
Where do I purchase a power cord for a magnavox 15mf605t/17
its the same as a computer power cable you can find these all over the place. try ebay
thanks
michael
Mar 25, 2011 | AOMNI Corporation Magnavox 15MF605T/17 15...
I have a Philips Magnavox 17MD255/17 LCD TV. I can not find the actual ac/dc power adapter, they are no longer available. Which one would I be able to use?
http://cgi.ebay.com/NEW-AC-Adapter-Philips-Magnavox-17MD255-17-LCD-TV-/270636758732
try this they are all 12v 5a so you can do it on your own
Sep 22, 2010 | Philips 17MD255V Combo
Troubleshooting magnavox television model 20mt1331-17
I have a model 20tm1331-17 magnavox tv and when i go to turn it on it will turn itself back off. Any suggestions as to the problem?
Sep 27, 2009 | AOMNI Corporation Magnavox 20MF500T/17 20...
My tv won't go past channel 17
Please try this free Philips Flat Panel Television owners manuals, user guides & how to ... A B C D E F G H I J K L M N O P Q R S T U V W X Y Z ... 13" LCD-TV PF7835 - Philips 20" LCD-TV Product Brochure ... 13MC3206 - Magnavox TV/DVD Combination ...
tv.manualsonline.com/manuals/mfg/philips/philips_flat_panel_televis... - 674k - Cached
Aug 21, 2009 | Philips Magnavox 20MS233S 20" TV
Magnavox lcd tv not turning on
Also changed swollen C2074 and C2081 and it now works perfectly! a bit daunting for a novice like myself but with a steady hand and decent 'put it back the way you took it apart' skills, all went well!
Mar 22, 2009 | Toymax Magnavox 37MF231D 37 in. LCD TV
Philips Magnavox 17MD255/17 LCD TV had AC voltage applied.
It seems your "power regulator" a small unit inside tv device has damaged due to wrong power supply. In this case usually the power capacitor burns and few other electronic components like triodes. Get the help of a electronic chip technician to replace the damaged components.
Hope it works.
Mar 28, 2008 | Televison & Video
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
