Question about HP iPAQ H2210 Pocket PC
IPAC 2210 + 2GB SD Cards
Hi all Sorry if this has been covered before, couldn't find it. My 2210 seems not to recognise a Sandisk Ultra 2GB SD Card...? Is there a patch or something i am not doing..? Any help appreciated.
    Master:
  • 450 Answers
FYI - Use the SDIO update from the HP site, then do a hard reset and maybe even a couple os soft resets. Interestingly, it takes a while for it to appear (the SD Card). Even if you take it out and put it back, you will need 1 or 2 soft resets to get it to show up.
Posted on Sep 11, 2005
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Will sandisk mirco sd cards work?
You didn't buy a microSD card at all, you bought a microSDXC card.
The Eclipse 180 works with microSD cards (2GB or smaller) and microSDHC cards (32GB or smaller). It does not work with microSDXC cards.
Jul 26, 2014 | Mach Speed Eclipse 180 MP3 Player
My IPAC hx2790b will not recognise my 4gb sd card
PCM, Backup the data on the card to a computer. Format the card. Try on your iPAC. If still not recognized. the format in a different computer. Try on your iPAC. Repeat the process till it is recognized by your phone. When and if you get fed up of trying, throw the card away as useless/unusable.
Jul 04, 2011 | HP iPAQ hx2790 Pocket PC
I have an Ultra II 4gb memory card that is locked and I can't seem to unlock it. I've tried from multiple cameras, card readers, and computers, but can't seem to get it to work.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 11, 2011 | SanDisk Ultra II 2GB Secure Digital Memory...
I cannot format the sandisk Ultra on my Kodak easy share camera. pdavis610@triad.rr.com
The Ultra card is larger than 2GB, isn't it? The Z612 uses SD cards. If your card is larger than 2GB then it's not an SD card but an SDHC (Secure Digital High Capacity) card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller in the Z612.
Nov 24, 2010 | Kodak EasyShare Z612 Digital Camera
Is Sandisk Ultra 8 GB SDHC card compatible with a Panasonic Lumix DMC-FZ30GN camera? When inserted in Camera error message check card flashes
No. The DMC-FZ30 was designed to work with SD cards. While SDHC cards will fit into the slot, they do not work. You'll have to use SD cards, 2GB and smaller.
Jul 06, 2010 | SanDisk Cameras
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
SD Card
They have not had a good reputation for reliability here, you might want to do a search on SanDisk. The consenses on SD cards seems to be Panasonc, SimpleTech & Lexar (32x best), in that order. Some (Pixy) have had good luck with th Ultra II, but several others have had SanDisks of all kinds fail.
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Panasonic SD card
> The Panasonic 256MB SD card is twice as fast as the cheap SanDisk > 256MB I bought from Costco for $65. Saving the 5-shot burst at > 4MP, the Panasonic card takes only 2-3 seconds to save, whereas the > SanDisk card takes 5-6 seconds. Although the SanDisk works just > fine in video mode - I was able to fill the card with video. The > extra speed is also very noticeable on the Panasonic SD through my > 8-in-1 SanDisk USB2 reader on WinXP copying the files to my hard > disk. > > Has anyone tried SanDisk's "ultra" or other performance versions? > Any reason why the Panasonic is so much faster? the panasonic SD is rated at 10Mb/sec. ditto for the Sandisk Ultra II. I've got both versions of the Sandisk. the regular Sandisk is only rated at 2 Mb/sec which explains the slow save speed. the Sandisk Ultra II is much faster compared to the regular Sandisk.
Sep 04, 2005 | Panasonic SV-AS10 Digital Camera
HP iPAQ H2210 Pocket PC Logo
129 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
