Question about Kenwood VR-407 Receiver
Receiver will not work by remote
I have a Kenwood VR-407 receiver that recently developed a problem. It no longer will work via remote. All functions on the receiver itself still work fine using the buttons on it. Ive tried different remotes as well.
Any ideas?
  • 3 more comments
  • Anonymous Sep 07, 2008
    same problem
  • Anonymous Sep 27, 2008
    likewise - and it's been like this for three years (I've worked around it, but am now at the point that I'd really like it fixed!)
  • kashifs Oct 01, 2008
    I have the same problem
  • twistedwedge Oct 11, 2008
    Fixed it! Thank you so much!!
    Did the reset method..forgot to add that. Thanks again Bob
    Scholar:
  • 47 Answers
Hi!
Here are suggested solutions for you!
Unfortuntately, you and many others have this problem. I will point you in the direction of two "fixes" I have found.
Fix 1 is from Kenwood themselves, per the following quote:
"First try replacing the batteries if you haven't already. If that doesn't help, try resetting the receiver. Simply unplug the receiver, then press and hold the power button on the receiver while you plug it back in. Turn the unit on, and the display should say 87.50 to confirm the reset. If the remote still does not work, use a digital camera as an eye, face it towards the IR of the remote control. Depress any of the remotes buttons; you should see IR flash each time a button is pressed. If not then the problem is with the remote. If the remote works fine, then the problem is with the receiver. In order to determine the cause of the problem, I suggest you take the defective unit to a Kenwood authorized service center for evaluation. You can find information for authorized service centers in your area by visiting our website at www.kenwoodusa.com."
The second fix involves some very simple soldering, and has been endorsed by many as the solution:
http://www.remotecentral.com/cgi-bin/mboard/rc-theater/thread.cgi?3016%2C3
I hope this helps. Good luck and please let me know if this solves your problem!
Bob
Posted on Oct 09, 2008
I have a VR-407 reciever and I am unable to get my CD/DVD rear outputs to work. I am hooking up a DP-3020 and I can get it to work in the Audio L/R jacks in the front. Is there something that I need to do...
A Kenwood VR-407 is a receiver and has an INPUT pair for CD/DVD, not outputs. Plug ANY functioning audio source (except a turntable) into it and select it on the front panel.
If your DP doesn't work on either I'd suspect something is wrong with IT.
May 24, 2011 | Kenwood VR-407 Receiver
I am connecting an amplifier to my VR-407 to accomodate more speakers I have installed throughout my home. Where do I connect the amplifier?
Connect the amplifier input to the VR-407 using the receiver's REC OUT jacks for the MD/TAPE input on the back panel. This is a fixed line-level output for recording, and will work fine for driving the additional amp.
Jan 17, 2011 | Kenwood VR-407 Receiver
Sub woofer output port does not seem to work on my kenwood VR 407, checked sub woofer on another system - works fine, any easy solutions?
Is the 407 set up to drive the unknown sub. It's not just plug n play.
The manual will guide you, around page 15. Also refer to your subwoofer manual. Try retrevo.com for that one.
http://www.retrevo.com/support/Kenwood-VR-407-Receivers-manual/id/480ag200/t/2/
Dec 29, 2010 | Kenwood VR-407 Receiver
I have a Kenwood VR-407. TV and Blue-ray are
Check the manual for "Volume offset" at the input mode. I'll pull the pdf on the unit, If I find it, I will send the instructions. Hope this helps
Dec 23, 2009 | Kenwood VR-407 Receiver
Prologic on Kenwood VR-407 not working
plug front speakers into the a side
May 31, 2009 | Kenwood VR-407 Receiver
Hi, i have a kenwood VR-407 and can't get audio..
You haven't really given any details as to your connections. This would help greatly in troubleshooting I am currently using my TV and DVD trhough my VR-407 with no problems. so.....
More info please :)
Mar 07, 2009 | Kenwood VR-407 Receiver
Kenwood VR-407 Receiver Logo
241 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
