Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Samsung DLP 50
I hope someone could help me with this problem:
I purchased a Samsumg DLP 50" TV about 3 years ago, of course i did not get the extended waranty, and the TV started to go bad after the second year.
The first problem that I had was tha i had green horizontal lines with sahdows across the whole screen. After searching on dirferent forums, it seemed that the video card had gone bad, which will cost over $1,000 to repair.
I did not give up, and i noticed that if I used the TV as a PC monitor, the screen will work perfectly. So i purchase a hardware to concet my digital cable to my PC and projected on my TV as a monitor.
At the end, the software was $25.00, a ste of Wireless key board and mouse for $40 and I fixed the problem for a total of $65 I fixed my screen problem and had digital quality TV at no aditional cost. Woks perfet when seein DVS on your PC.
Now after 6 moths i'm starting to have a second problem:
I now have a Black vertical line on my left side of the TV monitor that seems to be getting bigger as days go by, started at about 1" wide and now is abou 3".
Does any one know what could this be?
you can still see a picture behind this black line, but it is very dark.
Is this the end of my TV, should I finally give up my battle and purchase a new one?
Thanks
Danny F.
  • OSUCHARGER61 Sep 08, 2008
    I have the exact same problem on the left side of my Samsung 56" DLP TV. Dark bar with the image showing through it like a shadow. I'm anxious to hear what it might be.
  • dcooper587 Nov 09, 2008
    I have the same problem with my 50 inch Samsung dlp. I purchased it over 3 years ago. The problem is a dark shadow on the left side of the screen and doesn't matter what picture mode it's in.
From the link http://www.samsungtvshadowclassaction.com/main/home.sfx I followed it's links to http://www.avsforum.com/avs-vb/showthread.php?t=758625 and my HLR5667W looks like new again. thanks to all.
Posted on Oct 03, 2008
2 Suggested Answers
  • 5 Answers
SOURCE: Samsung DLP 50
check the input board for AVI make sure it is not dusty and that all the connections on the board are good you may have a bad solder point or that board is bad ,also possible video ctrl board
Posted on May 31, 2009
Samsung BP96-01653A Model HL50A650C1F I believe that the lamp went out on my Samsung 50 in DLP TV about a week ago. The TV would not turn on and the green lamp light blinks. I ordered a new lamp, fr
This sounds like a case where jumping to a incorrect conclusion has not resulted in the fix your were after. The problem could also be related to the power supply. Before going for another part it is best to consult a Technician who works on these all the time and get a correct direction to go before ordering a lot more parts. if you check on the internet with the symptom and model /brand of your unit- chances are someone else has already had this problem and may have the solution there for you to take advantage of. Of course each TV is different but it might be a better way to proceed than just guessing.
Aug 09, 2012 | Samsung HL50A650 50 in. TV
SAMSUNG DLP SLIM 50" AFTER I TURN IT OFF IT WONT TURN BACK ON TILL 30 TO 50 MINS LATER THE THREE LIGHTS IN THE FRONT BLINK. iT ACTS LIKE ITS GONA TURN ON BUT IT DOESNT IT JUST MAKES THE NOISE AND FLASHING...
Chris,
I had the same problem. I bought my tv at Best Buy and my warranty included a new bulb for the lamp. They only last about 2 yrs or so depending on how much you watch the tv. You can also buy replacement bulbs online that don't cost too much. BUT, you will need to replace every couple of years. The things you listed are exactly what happens when the bulb goes out. Hope this helps!
Sep 14, 2010 | Samsung 50" Slim-Depth DLP HDTV
I am having the same issue with white spots on my screen. My TV is a 50in Samsung HD DLP Rear Projection that was purchased about two years ago. What is the most common fix to this problem? Thanks for...
The DLP chip is failing and must be replaced. You can call 1-800-samsung to find out if this is covered under any special warranty and to find the nearest service center.
Jun 21, 2010 | Samsung SP50L6HX 50" DLP HDTV
Samsung DLP white spots
Are the spots fixed or do they move with the image? Verify that all venting is clean of dust. If the spots are fixed and upon close examination are a square shape, The device is overheating of failing. If the spots are moving with image it's a front end problem, and can be overheating as well.
Jun 27, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP 50
May 31, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Numerous white spots on Smasung DLP TV
If your Mitsubishi TV has white spots in the picture , you can call Mitsubishi @ 1-800-332-2119 and request a free DLP Chip to fix the problem. They will send the New DLP Chip at no charge to a TV Tech in your area to install it for $200 flat rate. That is about a $250 savings if you had to pay for the chip . Call them with your TV's Model number and serial number and let them know when and where you bought the TV.
It saved me some hard earned money and now my TV is like New !
May 02, 2009 | Samsung 50" Slim-Depth DLP HDTV
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
BAD LIGHT ENGINE call UED 1-800-648-6657
Feb 15, 2009 | Samsung HL-S4266W 42" HDTV
See link below for "field of stars" fix:
http://www.avsforum.com/avs-vb/showthread.php?t=1107926
Worked a charm on my 50" Samsung DLP. Read thread carefully as there are 2 different version of the DMD chip you will need to replace. I ended up fixing mine for less than $165!
Chuck
Feb 07, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
921 people viewed this question
Henry  Thomas
Henry Thomas
