SOURCE: check engine light reset for 2001 ford escape
On any car 1996 or newer after a repair is made the memory in the computer has to be cleared the light will not go away by itself. The proper way to clear this is with a scanner or code reader but if you dont have any other way unhooking the battery will force the computer to loose all its memory and start all over and the light will go away. If the light returns after a few days you still have a problim.
SOURCE: Starter/Fuel Pump fuse, or the Relay Fuse blow
the fuel pump comes on when you turn the key on the starter comes on when you turn all the way to start so i would think the short is in the fuel pump if it blows by just turning the key on
SOURCE: Hi. I have a 2003 ford windstar with ford anti
you will have to take your vehicle to the nearest dealer the theft system is the issue most likley you will have to replace the ignition switch but you will have to get it properly diagnost do yourself a favor and save u time and money
Testimonial: "Well this is one place to start from.Hope it works.Thanks for your support and help."
SOURCE: 2003 k1200lt abs fully integral. rear reservior
As the break pads wear it creates a greater volume(capacity) at the caliper piston/s.This causes the fluid in the reseviour to go down.(even though you have no leak) then you top it up & it will again reduce fluid level as the pads wear further.When the pads are replaced you are required to push the pistons back in to accomadate the new(thicker) pads. Before you push the caliper pistons in at brake pad change you will need to drain out some fluid(from the resivour) to stop the resivour from overflowing. This is typical of all hydrolic braking systems on both bikes & cars.Check the pads, If they are wearing this symptom is compleatly normal.
SOURCE: Trouble code 42 ignition module failure
I have a 1993 astro van. I started my van and pulled out of a parking lot and up to a stop sign the van stalled I started it back up and it stalled again now it will not start and I have no flashers, turn signals but I do have headlights a dashlights. I turn the key and nothing happens any ideas
