Question about Phase Linear UDV9010 Car DVD Player
Can't watch dvd
Started out fine and then the screen turns blue with the word "PARKING"
    Sergeant:
  • 241 Answers
OH YES THE PARKING DEAL
I have a in dash DVD player too
Did you try view a MOVIE while you were driving
if not check the wire that connects to the park brake FUSE
it is located in the (fuse Panel of your car) check it make sure that it is not been pulled out or loose and check th fuse that it is it too to see if it is blown. If that doesn't work you remove the car battery cable to resest it or the RADIO memory fuse inthe car panel.
Or if it was installed by a PROFESSIONAL they should of tapped into the parking brake line..it is also located near the fuses.
And if this keeps happening the newer dvd players are set to have this saftey feature so YOU DO NOT WATCH MOVIE AND DRIVE.
BUT sure you could just put a toggle switch on the wrie that connects the parking brake and BYPASS IT ;)
Posted on Aug 29, 2008
    Sergeant:
  • 243 Answers
I see you closed our chat session?
  • Nathan Ayers
    Nathan Ayers Aug 29, 2008
    if you would like to continue the chat session please let me know so i can further assist you
My dvd & usb is not working. Everytime i put a dvd in or try and use the usb a blue screen appears and says WARNING PLEASE STOP WATCH VIDEO PLAYER.
the parking brake wire must be connected to the parking brake system of you car. When the parking brake is engages, the LCD will be allowed to view your video. If not, the screen will produce an image saying, parking brake. this is a feature designed for the driver not to watch a video while driving. The video output on this unit will not be affected by this, el wire to connect is Pink - parking brake. this is wire connect with ground.
Oct 10, 2010 | BOSS AUDIO SYSTEMS BV9976 Car Video Player
My vm9510 wont play the dvd with out saying parking and screen blue
You have to connect the park wire of the Jensen to your hand brakes that gets a negative signal everytime you engage it or you can try to put in series the park wire to a switch and any ground. Then read your manual how many times you got to switch it on and off until the picture appears when your dvd is playing. Same thing if you connect it to your parking brakes you got to engage your parking brakes on for 1 or 2 secs then back off then back on again for 1 or 2 secs keep doing this varying the secs till you get a picture. That will be the sequence to turn off that blue screen and on the dvd to watch the movie. Read your manual very carefully it will tell you the same thing but you definitely have to hook up the brake wire or else you will never see the picture. Check the manual for the color of the brake wire or just find the longest wire on the harness and thats usually the brake wire.
Apr 07, 2010 | Jensen VM9510 Car DVD Player
Lanzar SD32MU: how do you disable the video screen
ok here is the big secret. There should be a wire that goes to the parking break. In most after market radios, it is a brown wire. The way to get around this is to put that wire directly to ground. It will work at all times.
Nov 06, 2009 | Lanzar SD32MU Car DVD Player
Audio problem
I'm not sure about the cd's and dvd's getting ejected, but you can ground the parking brake wire to any ground in the car and you will be able to watch ur movies.
Mar 30, 2008 | Jensen VM9410 Car DVD Player
Parking Brake Wire
I have not a solution but a remedy. If you would like to be able to watch movies while driving, follow these simple instructions. Take out the dvd player, Get one simple toggle switch, install somewhere easily accesible. Now run the parking brake wire from the dvd player to one of the prongs on the switch. Now find a good solid metal ground under the dash, (mounting brace,etc.). Run a wire from this ground to the other prong on the switch. Now reinstall the dvd player, turn on, when blue screen appears, flick the switch, hold for 5 seconds, then flick it back, in a few seconds it should go to the normal screen.
Feb 19, 2008 | Jensen VM9410 Car DVD Player
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
Hii
This is the way to do it without engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings
Dec 04, 2007 | Jensen VM9510 Car DVD Player
Blue screen will not go away
The problem is that you're trying to bypass a safety feature. Newer video head units are smart enough to know when you've just grounded the brake switch wire so you can watch it while you're driving. Try hooking it up to your parking brake wire.
Mar 03, 2007 | Dual Bravo HRC-0703 DVD Package Mobile...
Phase Linear UDV9010 Car DVD Player Logo
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
