Question about Apple eMac G4 Desktop
Where is line-in port?
I thought I had everything I needed to record cassette tapes onto my eMac G4 computer: software, cable, tape deck, etc. But now I can't find the "Line-In" port on the computer. There are 2 holes on the right side, one for earphones and the other—for a microphone? Recording instructions say not to use that, but I can't find any other holes the cable will fit. What do I do?
  • 21 Answers
I would just use it, chances are the instructions were made assuming you had both line in and microphone ports. But since you only have one, it looks like it is your only choice. I would go into System Preferences in Sound and make sure everything on the input tab is looking ok. There should not be a lot of difference between the internal workings of microphone and line in ports. If it doesn't work, let me know.
Posted on Sep 07, 2008
How do i record cassettes
If you mean on to a computer you just have to get the deck connected by a lead into your computer. Then you need some audio recording software, such as the free Audacity and play back the tape and the software will record it.
Apr 15, 2016 | Audio Players & Recorders
I want to begin converting music from my computer onto cassette tapes using a device i've just bought. Can i use this device to firstly, override tapes? And Secondly does my record button even work?
check the top of the tape cassette if plastic removable tabs missing it will behave like a read only cassette if missing sticky tape can be used to cover the holes to make cassette recordable.
Jul 11, 2015 | Audio Players & Recorders
No sound or recording to computer
You need a program to interface between the tape deck and your computer. Try Audacity. It's free.
Feb 22, 2015 | Pyle PT659DU Dual Stereo Cassette Deck...
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
I need to know how I can hook up my Teac EQA 5 equalizer to my Sansui AUD 9 power amp.. I lost the manual to the E/Q
It is very easy, you don't need a manual for this. The EQ line in and Line out get hooked into the record out and Tape in of one of the tape loops on the Sansui amp. Record outs go to EQ in and the EQ out goes to tape play.
Oct 10, 2013 | Sony TC WE435 Stereo Dual Cassette Deck...
Hookin equalizer to tape deck and recever
The equalizer I have seen have Line in, line out, tape in, tape out and that is how you utilize a unit like this. The line IN goes to the receivers tape record out. The line out goes to the receivers Tape play in or monitor, The tape deck hooks to the equalizer. The record or input of the tape deck hooks to the EQ record out, the Tape decks output hooks to the EQ's Tape in connectors. All these are stereo so there are left and right sides which you need to keep consistent. Red on a cable means Right, the white or black on cables mean Left or the top RCA connector on most equipment.
When playing back a tape the tape monitor is turned on with the receiver and left on. The way you record on tape from any source of the receiver is to select that source and it should go to the equalizer. Then the deck should record that source. To play a tape of the deck hooked to the equalizer then just press the tape monitor button on the EQ otherwise the Equalizer will just act as a loop and equalize any signal source that is coming from the receiver and the tape monitor on the receiver should stay on most of the time. Some equalizers have two tape inputs so you would hook another deck to that input and the owners manual of the equalizer should say how to select buttons to transfer tape signals from one to the other. If you master the concept of inputs and output of audio equipment then this hookup becomes another easy thing to do.
Sep 22, 2012 | Sony TC WE435 Stereo Dual Cassette Deck...
How to record a cassette tape to a cd
Your question is posted under a "CD Shelf System" heading. If you really have one of these, the answer is "you can't". The CD player is a player only, not a recorder.
On the other hand, if what you're asking is how to transfer cassette tapes to CD using a computer, there are a couple of ways. One is to connect a cassette player (boom box, component system cassette deck, etc.) to the line-in jack of your computer's sound card. Download and install Audacity, which is free software for recording and editing sound. Then you can record the sound from your cassettes as you play them into the computer.
Another option, If you want to be fancy and spend a little money, is to buy a USB cassette deck. It automatically converts the cassette audio to digital and sends it to your computer over a USB cable. Recording software is supplied (sometimes the Audacity program mentioned before). Several companies make them. Here's one from a company called ION that some friends of mine have, and it seems to work well for them. They've been converting a lot of tapes of family members, and Audacity has been good for cleaning up tape hiss and enhancing the sound.
Either way, once you have the sound in your computer and processed to your liking, you just need to burn it to a CD using whatever burning software you have. (I use CDBurnerXP. It's free, easy to use, and does everything needed for normal CD and DVD burning.)
Aug 10, 2011 | Crosley 4-in-1 Entertainer CD Shelf System
How can i download my cassettes to my computer
If you want to be fancy, a company called ION makes a cassette player that plugs into a USB port on your computer. You can look at it here. The unit comes with software to capture the audio as you play your tapes.
You can also connect the tape player you already have to your computer's line-in audio jack. You'll need a cable with a 1/8-inch mini stereo plug at one end to fit the computer, and the appropriate plug(s) at the other end for the cassette player. If you use a boombox or other portable deck, the cable will need the same mini stereo plug and you can use the headphone jack. For a component cassette deck you'll need RCA plugs. Download and install Audacity, which is free software for recording and editing sound. With Audacity, you have tools to process the sound after it's in your computer to split tracks, add effects if you want, and to try cleaning up hiss or other quality problems. It's a great way to preserve tapes with voices of family members!
Aug 09, 2011 | Computers & Internet
Technics M14 cassette deck has hum. Bought used and had hum but I got it to go away by switching the tape select dial to metal,etc. but hum came back later. I'm thinking ground or a wire to that switch. ...
If the hum is audible without monitoring a tape playback it has nothing to do with the oxide formulation or any aspect of the media.
Determine the conditions present whenever the hum is present:
Player just turned ON?
Tape deck Playing or Paused?
Tape deck Recording or Paused?
"Tape" selected at the receiver?
Any source selected?
What switch are you referring to? You could have a floating ground or shield through a Tape Monitor or other control. Audio cables between the Deck and the receiver could be faulty or require reseating with a twisting motiuon to remove oxide build-up.
Hum can enter any unshielded cable running near any motor, magnetic field or some light sources. Sometimes simply reversing the polarity of an AC power cord will cure it.
Feb 02, 2011 | Yamaha KX-393 Cassette Deck Dual Cassette...
I need to know how to record 1 tape onto another tape on a Technics rs tr-575 dual cassette deck
press the synchro start button, the tape deck should now go to REC PAUSE, press the SPEED button till you get the required recording speed then press the synchro start again and it should start to record from deck 1 to deck 2.
make sure the tabs at the top of the tape you want to record on are intact,
if not just put a bit of sticky tape over holes.
hope this helps?
Feb 05, 2010 | Technics RS-TR575 Single Dual Cassette...
Apple eMac G4 Desktop Logo
1,766 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
